Headlight levelers Retrofit Mod.
Discussion in 'Lighting' started by bobeast, May 29, 2016.
  1. May 29, 2016 at 8:01 PM
    bobeast
    bobeast [OP] really old member
    Bob
    Hollister, CA
    2008 DC
    Beginning in 2010, some Tundras came with a magic rotary thumb switch on the dash allowing the driver to adjust the headlights up and down. This is especially useful when tow hitch weight changes the rake of the truck, and causes the headlights to point at the sky.
    I set out to determine what it would take to retrofit my 2008, to include this cool new feature. One thing to note is that Toyota tends to prewire their trucks for all the options. If you have a 2010+ (without this feature) check first if you are pre-wired, in which case, you won't need most of the parts in the following list. Look for an unused triangular shaped 3-pin plug near each headlight
    If your truck is not pre-wired (or you have a pre-2010 2nd gen), you'll need to make up your own wiring harnesses using the information in this thread. Also, note, this is not a step-by-step on how to make these harnesses. One could argue (and I do) that if you are not able to read a wiring diagram and perform basic electrical work, then this mod would be best left up to someone with the appropriate skill-set.
    With all that said, here are the parts you will need.
    90980-11016 headlight motor connector x2 (unless pre-wired)
    82998-24400 headlight motor terminals x6 (unless pre-wired)
    90980-11909 switch connector x1 (unless pre-wired)
    82998-12690 switch terminals x5 (unless pre-wired)
    841520C010 switch x1
    811100C070 headlamp assembly (RH) x1
    811500C070 headlamp assembly (LH) x1
    With all of these parts in hand, you'll need to make up a wiring harness that runs from the switch on the dash, out to the headlights, referencing the following diagram. As you can see from the diagram, you need run only 2 wires from the interior out to the headlights. I went through the grommet above the brake pedal.
    Note: looking at the following diagram, you can just tie pin 4 of the switch to ground.
    Depending on where you mount the control, you can pick up illum. + and - up from the nearest dash switch. Just tie into the appropriate wires on the selected switch referencing the following diagrams.
    AYANG0003 likes this.
  2. May 29, 2016 at 8:10 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Why have you been holding out on us @bobeast ? Some great mods you've been posting. Will add them to the mod list soon.
  3. May 29, 2016 at 8:13 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
    Hehe. I've been too busy modding to write them up. I'll try to do better in the future :)
    csuviper[QUOTED] likes this.
  4. May 29, 2016 at 8:21 PM
    csuviper
    Broomfield, CO
    Right on. Thanks again and more are welcome.
  5. May 30, 2016 at 3:22 AM
    Ancient1
    Ancient1 New Member
    Tallahassee
    2012 rclb tundra 4x4
    So....that's what that rotary wheel thingy is for
  6. Jul 11, 2019 at 10:36 AM
    AYANG0003
    AYANG0003 New Member
    good write up. any chance did someone make any kit i can just buy instead of making my own? thanks
  7. Jan 16, 2020 at 12:49 PM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    Thread revival .. has anyone completed this? Want/need to do this for my 08 SR5
  8. Jan 17, 2020 at 12:16 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Zebruaj likes this.
  9. Jan 17, 2020 at 12:20 PM
    bobeast
    Bob
    Hollister, CA
    2008 DC
  10. Jan 17, 2020 at 12:34 PM
    BrandonL812
    Brandon
    Ive had it on my Watching List over 6 months now. Keep thinking, 1 day, 1 day i will get to it. It definitely simplify the installation.
  11. Jan 17, 2020 at 12:48 PM
    minter66
    minter66 2007 TSS CrewMax
    I bought it, April of 19...still haven't put them in yet.
    I actually had a small issue, the seller sent me a harness with two female connectors. The language barrier kept causing us issues, but he finally shipped the right harness after about 3 months.
    I lost interest in it at that point, but maybe someday I will get around to it. Im about to tear into my 66' Mustang so I have my hands full for the time being.
    BrandonL812 likes this.
  12. Apr 3, 2020 at 4:10 PM
    sensei
    sensei master and teacher of nothing
    trd boosted, trd bbk, fox stage 4, corsa, amp, jl/kenwood
  13. Feb 7, 2021 at 4:40 PM
    willhaman21
    willhaman21 New Member
    Will
    Has anyone had any luck sourcing OEM parts for a DIY harness? I don't really want to spend $95+ on a foreign made harness when I can make my own, but the pricing on these wiring parts is pretty insane as well.
    So far I've found these two:
    Ballenger Motorsports has the best deal I can find so far. $9.99 for 1 connector, 4 terminals, and 4 cable seals. https://www.bmotorsports.com/shop/product_info.php/products_id/4498
    Still need help tracking down the others:
    McGeorge Toyota has the switch for $68.85, and the connector for $4.63, which I can live with... But the terminals are $15.75 each?!
    EDIT:
    I found these switch terminals thanks to this very helpful thread: Terminals are $0.21 each, but shipping is ~$20. I ordered 50 terminals for the hell of it. https://www.hi-1000ec.com/product/1258
  14. Feb 7, 2021 at 5:45 PM
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    It's nothing new to the automotive industry. It's been around a long time in cars in Europe. My grey market '84 Mercedes had it. It too had a rotary wheel but worked off the engine vacuum to raise or lower the headlight beams via vacuum pods. Neat system among other things the car had that US models didn't.
  15. Nov 17, 2023 at 6:11 PM
    Yupers
    Yupers New Member
    Stephen
    2010 toyota tundra
    On my 2010 tundra ,i removed the level adjuster motors on my original headlight assembly , now can i just replace the adjuster on the aftermarket headlight assembly ,which is just the manual adjuster, and install this motor in its place?
    rdelator likes this.
