headlight input
Discussion in '2nd Gen Tundras (2007-2013)' started by tundraman24, Sep 9, 2019.
  1. Sep 9, 2019 at 6:46 PM
    tundraman24
    tundraman24 [OP] New Member
    my 2011 is in need of a headlight upgrade. I’m on the fence about restoring them because it seems like a band aid solution that works sometimes and comes right back others... For those that have replaced headlights on their 2nd gens please give me advice and reviews of your upgrades.
    Thanks!
    Mountun Goat likes this.
  2. Sep 9, 2019 at 6:59 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    The newer OEM Sequoia headlights looks BA
  3. Sep 9, 2019 at 7:06 PM
    tundraman24
    Picture?
    If it’s something that’s going to be a pain in the George Dickel to install then I’m out.
    Tundyfundy likes this.
  4. Sep 9, 2019 at 7:50 PM
    You better pull this out....:spending: You are looking at about $1800 for that setup.
  5. Sep 9, 2019 at 7:50 PM
    FXFormat
    FXFormat New Member
    Easy to install but expensive as shit. I spent 1700 for mine with harness and the headlight trim piece. Worth it though
    Quebec likes this.
  6. Sep 9, 2019 at 8:23 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    King 2.5s custom gold rock warrior wheels 2020 sequoia LED headlights
  7. Sep 9, 2019 at 8:25 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    Do it!
    Worth it! And easy as too install. Easier than plug and play led bulb set up!
  8. Sep 9, 2019 at 8:50 PM
    4Runner
    4Runner New Member
    Columbia, SC
    2017 Black Limited FFV
    Magnuson Supercharged, FOX 2.5 DSC front and rear, TRD Exhaust, TRD Rear Sway, and many more....build thread coming
    Would go retro before that and save money.
  9. Sep 9, 2019 at 8:58 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    I’ve had both. I have top of the line ls460 retro headlights too.
    Retrofits can offer better lighting if the right projectors and bulbs are used.
    But nothing beats OEM plug and play wow factor.
    But in the end it’s peoples money, peoples taste and do what ever you want to your own truck. Op wanted different options on lights and he is getting plenty of suggestions.
  10. Sep 10, 2019 at 8:15 AM
    sf319
    sf319 New Member
    Utah
    2014 CM Barcelona Red SR5 5.7
    Dash Cam|PowerStop Z36|DIY bed rails|DIY Pop-n-Lock|LED interior
    One thing I learned about restoring, you will want to put a clear coat on them. Take them off the truck, not too difficult, the hardest part of our headlights is the plastic peice under the headlight, remember to pull straight forward, don't bend them left or right. I ended up going back to OEM because they just worked.
  11. Sep 10, 2019 at 8:40 AM
    tundraman24
  12. Sep 10, 2019 at 8:45 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
  13. Sep 10, 2019 at 8:50 AM
    Trooper2
    JR
    Houston, TX (Suburban South)
    Restoring can help buy you some time. Haven't clear coated, but treat or wax often to help preserve.
    McGuire's Heavy Duty restorer worked well for me.
    Brings much life back to them
  14. Sep 10, 2019 at 9:09 AM
    tundraman24
    Ok kparrow those are very tempting. Anybody have any tips on installing or obstacles I might face?
  15. Sep 10, 2019 at 10:45 AM
    kparrow
    kparrow New Member
    Kevin
    Nampa, ID
    Removal is easy, it’s 3 10mm bolts. The filler piece the two tabs at the back may break off (mine did) and I just threw some super glue on the filler piece ends when I stuck it back on and that worked.
    https://youtu.be/ZimKKr3X-VQ
    For the AlphaRex from what’s I gather it’s plug and play but you have to tap one or two wires for the DRL tube. Use Posi-Taps super easy. I think they have an install video and if not that have instructions. Trying to convince my wife to buy them for me now for Christmas since mine are oxidized on the inside now, already restored once
  16. Sep 12, 2019 at 10:15 AM
    FJC
    FJC New Member
    2008 Tundra
    I'm liking the AlphaRex a lot, aftermarket without looking too aftermarket!
    Big J and Mountun Goat like this.
  17. Sep 12, 2019 at 10:58 AM
    wktjr
    wktjr New Member
    Maine by way of New Jersey
    2013 Tundra SR5, Black Crewmax
    How is the housing? I've read other posts where people complain about the housing melting on other brands?
  18. Sep 12, 2019 at 11:06 AM
    TheBeast The Beach
    the upcoming ones look nice too
    https://alpharexusa.com/product/07-...va-series-led-projector-headlights-jet-black/
  19. Sep 12, 2019 at 11:21 AM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    2017 TRD PRO Barcelona Red
    a few
    Neighbors truck with the alpharex pro headlights
  20. Sep 12, 2019 at 12:10 PM
    tundraman24
    I’m torn between the Alpharex option and the factory style Spyders with black housing....
    Spyders are only $115ish
    Anybody have experience with these?
  21. Sep 12, 2019 at 1:34 PM
    parker44
    parker44 New Member
    2008 Tundra - Desert Sand Mica
    Sub'd to this thread. I keep restoring my OEM lights, but definitely curious on the different options. I just saw the AlphaRex and those look sweet!
  22. Sep 12, 2019 at 5:23 PM
    tundraman24
    Did he change out the bulbs?
    What about his fog lights?
  23. Sep 12, 2019 at 5:34 PM
    Ryuu
    Ryuu Hwat!?
    Oz
    SouthEast, TX
    a few
    I'm not sure honestly, guy comes and goes a lot so never really struck up a convo with him. This was just a walk up to my fence and snap a pic deal.
    I've seen him drive by at night though and light output looked decent from what i could tell, but if i happen to see him outside I can ask him.
  24. Sep 12, 2019 at 6:09 PM
    tundraman24
    I just caved and ordered these...if anybody has any install advice please let me know.
  25. Sep 12, 2019 at 8:10 PM
    TheBeast The Beach
    post pics and feedback when you get them. I'm also interested.
    tigerpaw1129 and Mountun Goat like this.
  26. Sep 12, 2019 at 8:23 PM
    Mountun Goat
    Mountun Goat She baaaaaahd
    EhBerta, Canadia
    It’s a Goat.
    Nice I like that style. Curious to see them installed. :popcorn:
    TheBeast likes this.
  27. Sep 12, 2019 at 8:29 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Or these ones :drool:
  28. Sep 12, 2019 at 8:29 PM
    Mountun Goat
    EhBerta, Canadia
    It’s a Goat.
    Damn I’m glad someone came out with a new higher end headlight style for us second genners. I thought we were done for!
    *edit* that aren’t $3000 cad haha
  29. Sep 17, 2019 at 5:22 PM
    2011Tundra_RW
    2011Tundra_RW New Member
    Are there any headlight upgrade that you don't lose the headlight leveling option?
  30. Sep 17, 2019 at 5:59 PM
    Jwood562
    Jwood562 New Member
    2013 Tundra 4x4
    I am not sure if aftermarket.
    I know some people were adapting the oem leveling motors to spyder lights.
    My ls460 retrofits kept oem leveling motor use
