Headlight housing swap question
Discussion in 'Lighting' started by Whocares, Aug 20, 2017.
  1. Aug 20, 2017 at 11:34 AM
    Whocares
    Whocares [OP] Member
    Hello all,
    I swapped out the oem headlight housing and noticed one plug that did not have a female end on the new headlights.
    Photo of the plug (located in the middle and if looking down in engine bay, the bottom of the headlight)
    Circled in red, is where I disconnected it from the oem headlights.
    After the install, I checked all actions of the headlights (e.g., low and high beams, blinkers, etc) and everything seemed to be working properly. In the meantime, I sealed them up with some electrical tape. Anybody know the name of the plug and what it's function is? Thanks in advance!
  2. Aug 20, 2017 at 11:39 AM
    konzz77
    konzz77 New Member
    buddy
    2015 Black Tundra
    Yeah, that is the plug for the manual headlight leveling. There should be a switch on your dash for that.
    Your new lights dont have that feature.
    But, you did the right thing. Just tuck it out of the way, and there will be no problems.
    MotoTundra likes this.
  3. Aug 20, 2017 at 12:21 PM
    konzz77
    konzz77 New Member
    buddy
    2015 Black Tundra
    Not a problem. I only know because I also changed my lights out.
  4. Aug 20, 2017 at 6:33 PM
    Borgs
    Borgs New Member
    PA
    Did you get Spyders? You can install the leveling motors on them. I did it this week.
  5. Aug 20, 2017 at 7:29 PM
    Whocares
    Negative, but thanks anyways.
  6. Aug 20, 2017 at 7:56 PM
    MotoTundra
    MotoTundra The Ocho
    Don
    We need to see the finished project!!
    :worthless:
    SouthBoundSteve likes this.
  7. Aug 21, 2017 at 5:13 AM
    Whocares
    Haha, it's nothing special, just replaced them with blacked out headlamps. Definitely adds an aggressive look to dark trucks.
