Headlight fog
Discussion in '2.5 Gen Tundras (2014-2021)' started by Electonicsfanatic, Mar 8, 2020.
  1. Mar 8, 2020 at 11:41 PM
    Electonicsfanatic
    Electonicsfanatic [OP] New Member
    Wesley
    2017 Tundra Crewmax Limited 4x4
    Anyone have any issues with water inside the stock headlight housing? I find it hard to believe the plastic could already have a crack in it or maybe its the seal around the bulb? I don’t think its the seal around the bulb. I’ll post a picture when daylight comes.
  2. Mar 9, 2020 at 5:36 AM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    Warranty it.
    Ruggybuggy likes this.
  3. Mar 10, 2020 at 5:47 PM
    Electonicsfanatic
    Wesley
    My truck has 39,00 miles on it so its out of the bumper to bumper warranty.
  4. Mar 10, 2020 at 5:59 PM
    BrandonL812
    Brandon
    Well, that stinks.
    Best option now is, remove from headlights from truck, leave it out on a hot sunny day to let all moisture dries out.
    Thm reseal. See if you can find any crack or split. Then get some silicon selant and run a bead all around the headlight.
    More expensive option, beside buying new, is contacting retrofitting company. See if they are willing to open and reseal.
    I would do option 1 first. Check dust cap for split. Check bulbs rubber seal. All bulbs..
    Electonicsfanatic[OP] likes this.
