Headlight Conversion
Discussion in '2.5 Gen Tundras (2014-2021)' started by Frank1848, May 5, 2021.
  1. May 5, 2021 at 12:12 PM
    Frank1848
    Frank1848 [OP] New Member
    2014 Tundra
    I’m sure there is a thread already, but I just put on the Alpharex Pro headlight on my 2014 tundra, and for some reason the DRL is amber? Any suggestions on how to keep the DRL white while still using the turn signal option?
  2. May 5, 2021 at 1:09 PM
    Taco-Spike
    Two Trucks
    There are two options I thought? One for amber and one for While DRL.
    Edit: NVM that's Morimoto
  3. May 5, 2021 at 1:17 PM
    timsp8
    NY
    If these are the ones, it says white drl light. Could be a mfg defect. I wouldn’t think there would be a setting or wiring it wrong would cause it to change colors. Call the mfg.
    Jim LE 1301 likes this.
  4. May 5, 2021 at 1:22 PM
    ^^What Tim said.^^
    Welcome from NY.
    timsp8[QUOTED] likes this.
  5. May 5, 2021 at 1:38 PM
    Frank1848
    2014 Tundra
    I called and it has two option, the difference is the wiring configuration, if I plug the DRL in directly it’s white, if I use their harness to add the DRL turn indicator it stays amber at all times, thank you for the responses
