Headlight bulb mod
Discussion in 'Lighting' started by swede78, Jan 15, 2016.
  1. Jan 15, 2016 at 8:46 PM
    swede78
    swede78 [OP] Not so new member
    Lars
    westminster co
    2019 tundra platinum mgm crew max
    Nothing yet
    Has anybody done the low beam mod by removing the h11bulb and installing a 9005 or the h9 bulb in it's place.
  2. Jan 24, 2016 at 6:05 PM
    jimig
    jimig New Member
    2010 Platinum Crewmax
    What's the result of doing this?
  3. Jan 25, 2016 at 12:43 AM
    CMB
    CMB New Member
    Cecil County MD.
    2010 Tundra DC 4X4 SR5
    Not nearly enough room here!
    65 Watt H9 bulb instead of 55 Watt H11.Last time I bought H 9's,Amazon had the best price on Philips "Standard" bulb. A Dremel makes the mod really simple.Do a search for H 11 to H 9.
  4. Feb 21, 2016 at 2:12 PM
    alalmcgrath
    alalmcgrath Old Fart at Large!
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Aren't our headlights H10 bulbs?
  5. Feb 21, 2016 at 5:10 PM
    swede78
    Lars
    westminster co
    Nothing yet
    no
  6. Feb 21, 2016 at 5:14 PM
    CaptTyler
    CaptTyler Life’s too short to have an ugly boat.
    Tyler
    2018 Ram 2500 Cummins
    I have done it. Got the H9, 10 seconds with a dremel and you're done.
  7. Feb 22, 2016 at 3:40 AM
    swede78
    Lars
    westminster co
    Nothing yet
    captTyler,how do you like them? any glare/flashed by other drivers
  8. Feb 22, 2016 at 6:13 AM
    CaptTyler
    Tyler
    Not at all. But it is a quite noticeable upgrade.
    You'll be happy with it.
    I got the Philips Xtreme Vision.
  9. Feb 22, 2016 at 6:30 AM
    AMRE2ME2
    AMRE2ME2 New Member
    2016 DC 4x4 Limited TRD
    Capt, are those H9s? I can't find the Extreme Visions in H9.
  10. Feb 22, 2016 at 6:55 AM
    1G3-TRD
    1G3-TRD New Member
    Aaron
    2014 double cab TRD off road
  11. Feb 22, 2016 at 7:51 AM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Looks like an easy enough mod if the light output is greater.
  12. Feb 22, 2016 at 7:51 AM
    csuviper
    Broomfield, CO
  13. Feb 22, 2016 at 12:29 PM
    alalmcgrath
    Al
    Boulder Creek Ca
    2016 SEQUOIA SR5
    Just ordered an inexpensive rotary tool so I can give this a try.
    Any advice on which H9 bulbs work best?
  14. Feb 22, 2016 at 1:11 PM
    CaptTyler
    Tyler
    Sorry, got mixed up on my own mod!
    I kept the H11 bulb in my low beam, I talked to a guy named Daniel Stern (google him) and he helped me out. He said the upgrade should only be done if you have projector headlamps. With regular reflective lamps like in my '12 Tundra, he recommended against it just because of blinding everyone. The bulbs I recommended before is what he suggested for a H11.
    I did upgrade my high beams however.
    They are a 9005 and I upgraded to a 9011. Huge upgrade. Same thing, just use a dremel to make a tiny adjustment and they slide right in. Same wattage, different output. Hope this helps.
  15. Feb 22, 2016 at 6:11 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
