Head unit replacement/amps question
Discussion in 'Audio & Video' started by skip1980, Feb 1, 2025.
  1. Feb 1, 2025 at 3:01 PM
    skip1980
    skip1980 [OP] New Member
    Columbia, Missouri
    I am thinking about replacing my stock head unit with the Kenwood 1057xr and have a question. I currently have the Rockford Dsr1, JBL 8 channel DSP amp setup from tech12volt. No more factory amp. Right now the rca's from Dsr1 are front and rear set go to JBL dsp amp and sub set goes to Audio Control amp for sub. Spare set is not used. Once I install the Kenwood head unit I will no longer need the Dsr1 and will simply run 3 rca's from back of head unit directly to amps, front and rear to JBL dsp amp and sub to Audio control sub amp correct? No other changes will need to be made at amps correct. I know the maestro is needed for the Kenwood head unit.
    Thanks
    Sleeper16plat likes this.
  2. Feb 3, 2025 at 7:39 PM
    Iamsecond
    Iamsecond New Member
    Kevin
    2019 Limited Tundra
    you are correct.
    sell the dsr1 and at least cover some of your cost to the kenwood.
  3. Feb 9, 2025 at 1:42 PM
    20manny1996
    20manny1996 New Member
    Manuel (Manny)
    2017 Limited Super White CrewMax
    Yes sir. The only changes you will have to do to the amps is set the gains again. The 1057XR has 5V RMS rca outputs, so adjust gains accordingly.
    I actually had the exact same set up as you with stock HU (except for sub amp) & also upgraded the it to the 1057XR :cool:
    If you need any help feel free to reach out :thumbsup:
    freerider8 and bradj1 like this.
  4. Feb 9, 2025 at 3:11 PM
    skip1980
    Columbia, Missouri
    Awesome, thank you for the reply.
    20manny1996 likes this.
  5. Feb 19, 2025 at 8:50 PM
    bradj1
    bradj1 Ol' Blue
    Salt Lake City
    2018 CM TRD Limited Calvary Blue
    I hope I’m not hijacking the thread.
    I have the tech 12 volts JBL 8 channel DSP amp and want to add a Kenwood 1057XR. I just need to add 3 RCA’s and adjust the gains? The plug and play was pretty easy but I’m a car stereo novice. Not sure how to adjust the gains.
    Thanks!
  6. Feb 21, 2025 at 4:40 PM
    20manny1996
    Manuel (Manny)
    Here is a video that explains how to set your gains pretty well:
    https://youtu.be/hQOPP-l3AMo?si=TJSOmU76NXXa2PQX
    It will be slightly different with the DSP since it doesn't have physical knobs. Instead you have a level adjustment bar per each channel. I'm not too familiar with tech12volts packages, but I believe his DSPs come pre-tuned for you. If that's the case & you like how it sounds, then I wouldn't touch anything in the DSP. Disconnect the speakers & verify the signal doesn't clip. If it doesn't, you're set. If it does, you might have to lower the level bar on that channel.
    With that being said, I already have the 1057XR in my truck & the same DSP & I've verified the signal doesn't clip in any of the channels. HOWEVER, that might not be the case with yours because I have no idea how your DSP is tuned so I would still verify.
    bradj1[QUOTED] likes this.
  7. Feb 22, 2025 at 9:34 AM
    bradj1
    bradj1 Ol' Blue
    Salt Lake City
    The amp came pretuned and I feel I don’t need to make any changes at this time. Other than the harnesses, adapters and maestro do I need any additional parts? RCA cables?
    Thanks!
  8. Feb 22, 2025 at 12:44 PM
    1lowlife
    1lowlife New Member
    DADA
    THE GREAT STATE OF TEXAS
    2014 MGM DC SR5
    Which JBL DSP/amp do you have?
  9. Feb 22, 2025 at 4:43 PM
    20manny1996
    Manuel (Manny)
    RCAs should be the only additional parts you need :thumbsup:
    He said he has the JBL 8-channel DSP from tech12volts, so that should be the JBL DSP 4086.
    1lowlife[QUOTED] likes this.
  10. Feb 22, 2025 at 7:54 PM
    freerider8
    freerider8 Trucks Rule
    Fairview PA
    2014 Tundra, Lift Kit aftermarket wheels and tires. One Badass Toy!!
    Fuel Wheels. Lift Kit. Duel Exhaust.
    I still have my factory unit installed in my 14 Tundra. It has a CD player, Sirius XM, Backup camera, steering wheel controls and Bluetooth built in with other controls for the vehicle. I am considering changing it out for an aftermarket unit that can be a good equivalent to this unit. Anyone have any good recommendations? I have already installed a aftermarket amp and sub to the current system.
  11. Feb 22, 2025 at 8:56 PM
    bradj1
    bradj1 Ol' Blue
    Salt Lake City
    Great. I have some parts to purchase. Thanks for your help!
    20manny1996[QUOTED] likes this.
  12. Feb 23, 2025 at 5:31 AM
    2010bigdog
    2010bigdog New Member
    Chuck
    Chicago
    2018 MGM SR5 TRD
    how much better does it sound just adding the amp and sub ?
    freerider8[QUOTED] likes this.
  13. Feb 23, 2025 at 8:38 AM
    freerider8
    Fairview PA
    Much better. I am happy with it, just thinking of changing out the head unit for something different. I did find a few that I saw on Youtube as possible replacements that are plug n play for an easy install. They also seem to interface with all the hookups for camera, steering wheel controls which is something that I don't want to lose changing it out.
  14. Feb 23, 2025 at 8:56 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Crutchfield & Trail Grid Pro will set up any unit you buy from them as PnP if you choose the option, but I think Dasaita is the only unit that will be PnP out of the box. Maybe the Phoenix/Tesla style radios too...
  15. Feb 23, 2025 at 1:19 PM
    20manny1996
    Manuel (Manny)
    I've got a Maestro RR2 with my DMX1057XR. The Maestro allows me to keep all OEM functionality the stock HU had, like steering wheel controls, rear backup camera, Bluetooth, etc. On top of that, it provides so much more vehicle data that the stock HU lacks. The things you would lose would be stock navigation (if equipped) & SiriusXM. Navigation is no biggie since you can use maps on Carplay/Android Auto or get an aftermarket HU with navigation. For SiriusXM, you'd need a separate tuner to keep that.
    All in all, the Maestro allows you to keep most of OEM functionality & gives you so much more. Just find an aftermarket HU you like & make sure it's iDatalink compatible.
  16. Feb 23, 2025 at 1:28 PM
    freerider8
    Fairview PA
    Thanks for the input. Where did you purchase the unit you have? Do you know if the stock unit has built in Sirius XM? My stereo connects to it automatically without having a separate tuner and also has the antenna already installed on the roof of my truck.
  17. Feb 23, 2025 at 1:33 PM
    freerider8
    Fairview PA
    I actually found the unit you have and I think I looked at that one before. The one unit I have found currently is a plug n play and nothing else is needed to connect to the vehicle make the steering wheel buttons work. It is also much cheaper than this one. I am trying to keep cost down
  18. Feb 25, 2025 at 7:56 PM
    freerider8
    Fairview PA
    So I finally bit the bullet and chose a unit that I was looking at after some reviews I saw on Youtube of the same unit. Has all the necessary wiring and connections to be able to use the wheel controls and backup camera. I will post pics once I have it installed so all can see what it looks like. I have been looking at a bunch of different options and for the cost this is what I was looking for without needing to buy a bunch of extra stuff.
  19. Feb 25, 2025 at 7:59 PM
    20manny1996
    Manuel (Manny)
    Excited for you man! Wish you an easy & trouble-free install :D
    freerider8 likes this.
  20. Feb 25, 2025 at 8:07 PM
    freerider8
    Fairview PA
    Thanks man. I hope it all goes as planned. Can't wait to see how it looks and sounds. The one thing I will miss is playing CD's, but most of the music I have on them I have on my phone so it's not a total loss. :)
  21. Feb 26, 2025 at 9:12 AM
    Sleeper16plat
    Sleeper16plat New Member
    Near Vancouver
    2016 Silver Platinum
    TRD Rear Sway Bar Bilstein 6112/5160 Pop Lock, Kenwood MX 1057 XR, Pioneer amp/speakers/subs, Tech12Volt dual sub box
    You got it! I just did the same and installed the 1057xr. I suggest considering installing a front camera while you have the dash open.
  22. Feb 26, 2025 at 9:20 AM
    1lowlife
    1lowlife New Member
    DADA
    2014 MGM DC SR5
    Just something to think about;
    I have the separate Sirius/XM tuner for my aftermarket HU I installed 8 years ago.
    I never use it anymore, I run Sirius off the phone app now.
    Sounds better although it's a little more challenging to navigate.
    Good luck with your new HU.
    There are a couple things you might need, like the adapter to connect your OEM USB plug to the HU.
  23. Feb 26, 2025 at 5:41 PM
    freerider8
    Fairview PA
    It comes with an additional USB cord to be able to do this. Everything that comes with it does appear to make this a smooth transition. The videos of the guys that have installed it say they are very happy with the results. Fingers Crossed.
  24. Feb 26, 2025 at 5:43 PM
    freerider8
    Fairview PA
    Just curious how you like this setup? I have looked at stereos like this and wondered if I would like it sticking out like that.
  25. Feb 26, 2025 at 6:09 PM
    20manny1996
    Manuel (Manny)
    I really enjoy it man. Since the Tundra is such a big & spacious vehicle, I feel like the bigger floating screen just goes better with the truck. With the stock unit, the screen felt kinda small. The floating screen also puts the screen closer to the sitting position, which makes it much easier to reach. Do keep in mind I'm short at 5'7" & kinda blind, so a bigger & closer screen is just better for me. I do understand everyone is different & some just like a flush screen better, & I respect it.
  26. Feb 26, 2025 at 7:06 PM
    freerider8
    Fairview PA
    Nothing wrong with that :) I did end up going with a flush mount but it too is bigger than the stock unit and sits in the total space that the stock one does but minus all the buttons and knobs. So I am excited to see how it will look and work once installed. I will share pics when complete.
  27. Feb 27, 2025 at 1:31 PM
    MogwaiBoogie
    MogwaiBoogie New Member
    Justin
    TEXAS
    2020 Tundra Platinum
    Curious if you are still able to access the door lock and cabin light behavior settings that are in the OEM HU?
  28. Feb 27, 2025 at 4:48 PM
    20manny1996
    Manuel (Manny)
    Can confirm:
    1lowlife and freerider8 like this.
  29. Feb 27, 2025 at 4:56 PM
    MogwaiBoogie
    Justin
    TEXAS
    Bad ass! Headed to the shop
    In the AM. I’m excited
  30. Feb 27, 2025 at 6:07 PM
    20manny1996
    Manuel (Manny)
    If you have any questions or need help I'm glad to help out :thumbsup:
