Head Unit Issue
Discussion in 'Audio & Video' started by OHwendTrd, Jul 27, 2022.
  1. Jul 27, 2022 at 9:09 PM
    OHwendTrd
    OHwendTrd [OP] Aging Member
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    I searched on here and wasn't able to find anything relevant regarding this specific complaint. Recently experiencing multiple issues with my infotainment system when using Android Auto and Bluetooth. My question is anyone else experiencing some of these issues, am I doing something wrong, should I visit the dealer?
    • Bluetooth - when a phone call ends, the gauge cluster screen (green & red phones) and console screen freeze and display that the call hasn't ended yet and the timer continues. I have to push and hold for about 20 seconds for in to clear off and state "call has ended". The phone button on the steering wheel does nothing.
    • Android Auto - when I make a call, it displays it ringing, but I can't hear anything and the other person picks up and I can't hear them unless I disconnect my phone and switch away from bluetooth.
    • Overall infotainment feels very slow and has constant delays when pushing buttons on the screen.
    Thanks in advance for anyone who might have some insight. I have a 2021 SR5 Sport with 11k miles.
  2. Jul 28, 2022 at 4:41 AM
    pursuit2550
    pursuit2550 New Member
    2020 Tundra SR5 Maggie 1900
    I would try a different android or an iPhone first to rule out a phone issue. This way the dealer can’t say it’s a phone issue. If that fixes it then good. If not then dealer time. Me personally, I haven’t had any issues using my iPhone with BT or when hooked up to Apple Car Play via the usb cable. I also use an iPhone cable by the way. Sometimes aftermarket cables are problematic.
  3. Jul 28, 2022 at 5:14 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Replace with aftermarket HU.
    OHwendTrd[OP] likes this.
  4. Jul 28, 2022 at 6:24 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    I know in 2020 the head unit changed so I can only speak to the 2019 Bluetooth (no android auto or car play). Mine worked fine with a galaxy s10 on Bluetooth until I switched to the s21 ultra last year. Non stop connection issues, calls would sort of "cut out" after 4 minutes every call, I couldn't hear them/they couldn't hear me. Head unit would become unresponsive during a call and no way to end a call so I would have to pick up and unlock my phone and even sometimes that didn't work and i would have to reboot my phone. I got another s21 from Verizon thinking it was a phone issue because it worked fine with my s10 then went through multiple resets and even set it up as a brand new phone without moving any data over from a backup, nope still same issue. THEN my other half got a new iPhone and her phone wouldn't work right with it anymore either. I talked to the dealership here a few times and they told me they didn't have any known issues with newer phones. I waited for another head unit software update to come out and tried updating but nothing helped. Called James at tech 12 volts and ended up with a new head unit, maestro rr, amp, door speakers, tweeters, subs.
  5. Jul 28, 2022 at 6:31 AM
    vtl
    vtl New Member
    Boston 'burbs
    2019 Red SR5 DC 4x4
    No problem with '19 + very old Android. I some times have to spend > 1 hr on the call, never been any issue.
  6. Jul 28, 2022 at 6:28 PM
    OHwendTrd
    Josh
    21 SR5 3UR-FE
    ATF Cooler
    I've considered, recommendations? Not a cheap route.
  7. Jul 28, 2022 at 6:35 PM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
    Honestly, no because anything quality is hella expensive right now. I was gonna go with Alpine and stay away from anything 9" or bigger due to exponential price increase.
    I've pulled the trigger on a Tesla style Phoenix radio though. Came across a deal I couldn't pass up.
