Head unit display
Discussion in 'Audio & Video' started by Darren509, Aug 26, 2019.
  1. Aug 26, 2019 at 5:11 PM
    Darren509
    Darren509 [OP] New Member
    Darren
    Dayton NV
    2016 White Tundra TRD
    Recently I installed a remote start on my 16 and cant be more happier with it. Ever since the install though I have a problem where the head unit goes dark to the point where you cannot see anything on it as soon as I turn my headlights on. I spoke with the remote start guy and we went through and completely removed the remote start from the car and it still does it. So somewhere something happened and I need help in isolating it. I do not see any bare wires or anything obvious that could have happened while I did the install. If anyone here has any suggestions or extensive knowledge with the factory head unit please PM me or point me in the right direction. Here is a video https://youtu.be/Ks2d1aN16m8
  2. Aug 26, 2019 at 5:18 PM
    TRDFerguson
    Jake
    Southeast Greater Basin, AZ
    2018 MGM CrüeMax
    Have you messed with the brightness settings under the Display section on the head unit?
  3. Aug 26, 2019 at 5:20 PM
    Darren509
    Darren
    Dayton NV
    I have adjusted everything I could and it’s bright but goes almost black when the lights turn on
  4. Aug 26, 2019 at 8:31 PM
    matthew1992ya
    matthew1992ya New Member
    Matthew
    Louisiana
    2015 sr5 4x4 tundra
    Level sequoia wheels I like factory mods don't care to much for aftermarket
    Make sure your software is updated you should be able to check the last time it was done in the settings should have been done at least once
  5. Aug 26, 2019 at 8:40 PM
    Darren509
    Darren
    Dayton NV
    Ill check that tomorrow.
  6. Aug 27, 2019 at 8:04 PM
    Darren509
    Darren
    Dayton NV
    Updated software and no change so i just removed the headlight trigger wire. Looks like its an internal component that failed.
  7. Aug 29, 2019 at 9:59 AM
    Twinky
    07 double cab work horse
    You could check to see if you somehow tied into the illumination wire for the headunit.
