Head light adjustment.
Discussion in '2.5 Gen Tundras (2014-2021)' started by TRDPRO's4-2, Jul 13, 2015.
  1. Jul 13, 2015 at 3:14 PM
    TRDPRO's4-2
    TRDPRO's4-2 [OP] New Member
    Rob
    2015 TRD PRO
    Storage Under the seat
    Can anyone tell me if you can adjust / move the range of travel of the headlights? W/ the lights @ the max upper position I still am limited on how far I can see / out run the lights.
    Thanks.
  2. Jul 13, 2015 at 7:27 PM
    I don't believe you can, as the motor is connected to the light...there may be a manual adjustment for it...but I'm not sure.
  3. Jul 13, 2015 at 10:18 PM
    bobeast
    bobeast really old member
    Bob
    Hollister, CA
    2008 DC
    There is a manual adjustment behind the adjuster motor. Turn it CCW to raise, and CW to lower. That said, you probably won't get a whole lot of additional height out of it. The manual adjustments are really just to fine-tune the lights so they are at the same height.
  4. Jul 14, 2015 at 5:28 AM
    chphilo
    chphilo Tundra addict
    Western PA
    There are two screws behind each headlight. One is for the side-to-side adjustment and the other is for the up-and-down adjustment. When I got the OME kit, the headlights were aiming too high. I had to adjust them down. There's actually quite a bit of room for adjustment.
    One tip: the right side adjuster is easy to get to. The left side, not so easy. If I were to do it again, I would probably take the battery out.
  5. Jul 15, 2015 at 7:04 PM
    TRDPRO's4-2
    Rob
    2015 TRD PRO
    I did see a hex head behind each headlight w/ a shaft that has a disc w/ detents that I was guessing could be used to adjust & as you mentioned. Thanks for the direction of rotation info' as well. Hope to raise them some & equal them out as well for the passenger side is lower than the drivers side but w/ out damaging anything
  6. Jul 15, 2015 at 7:10 PM
    TRDPRO's4-2
    Rob
    2015 TRD PRO
    I will look again for the screws you mentioned & that is what I was looking originally to adjust as I have any other vehicle I have had but the motor adjustment is a new one to me. Thanks
  7. Jul 15, 2015 at 7:11 PM
    TRDPRO's4-2
    Rob
    2015 TRD PRO
    All. Thanks for the replies & information.
    Rob A.
