Head Gasket Leak
Discussion in '2.5 Gen Tundras (2014-2021)' started by Vector W8, Aug 21, 2018.
  1. Aug 21, 2018 at 9:27 AM
    Vector W8
    Vector W8 [OP] Old guy with a lot of expensive habits.
    FFV, TRD Supercharger, Bullydog FFV Tune, 2014 Fit Kit, TRD Dual Exhaust, Sequoia Front Sway Bar, TRD Rear Sway Bar, TRD Skid Plate, TRD Pro Grill, 040 White Mirror Covers, 040 White Door Handles, Ready Lift 3"/2", Anzo 3rd Brake Light, Winjet LED Tail Lights, LED Fog Lights, LED Rock Lights, Axle Vent Mod, SDHQ Hidden Winch Mount, 12,000lb Winch. Storm Trooper Shift Knob. BMF BATL Wheels.
    Well Sunday was rather interesting I drove off from a stop light and looked out my driver side mirror as I was accelerating away from the light and watched a nice long stream of white smoke come pouring out of the left hand exhaust tip. The cylinder head gasket has taken a dump, or worse a cracked head or block. I will be taking her in this Saturday and dropping her off. I am hoping it is just a head gasket.
    ColoradoTJ likes this.
  2. Aug 21, 2018 at 9:48 AM
    Did you check the oil to see what it looks like?
  3. Aug 21, 2018 at 10:59 AM
    It’ll look milky if it’s a head gasket.
    Antifreeze is a sweeter smell
    If OP is FFV, ECU may just need an update.
  4. Aug 21, 2018 at 11:17 AM
    TheBeast The Beach
    tag for update :popcorn:
  5. Aug 21, 2018 at 12:36 PM
    andy9743
    andy9743 New Member
    andrew
    nw ohio
    08 tundra cm 4x4 trd sc, +2 pulley, 4.88s, 37's, other things
    in bc blower.
  6. Aug 21, 2018 at 1:47 PM
    B737
    B737 Throbbing Member
    Jersey Shore
    2015 Tundra Double Cab Limited
    because supercharger.
  7. Aug 21, 2018 at 2:21 PM
    I didn’t see OP was SC’d
    Is it Magunson? Good luck with Toyota. Been there done that if that’s the case.
    Black Wolf and ColoradoTJ like this.
  8. Aug 21, 2018 at 2:42 PM
    I beleive he SC when he first purchased his tow truck.
    Hope he doesn’t have the same issues as you did Sean, that wasn’t fun for you.
  9. Aug 21, 2018 at 2:47 PM
    That’s not cool. If I remember correctly, this is your tow rig to take the Vector to car shows? I remember you having a C6 and Porsche for racing/fun.
    Either way, glad you have a warranty.
    NewImprovedRon likes this.
  10. Aug 21, 2018 at 3:40 PM
    Vizsla
    Vizsla 2 = 2.5
    That stinks. Please let us know the outcome. Might want to feed it the beans a few times to help make it easily diagnosed.:rolleyes:
  11. Aug 21, 2018 at 4:57 PM
    Vector W8
    Yeah, oil is clean and free from any antifreeze. It will only blow by under load, normal driving and nothing seems to be passing tbrough. But if I get on it it pushes through the gasket. I will let everyone know what the outcome is.
    rodm1, 15whtrd, Black Wolf and 2 others like this.
  12. Aug 22, 2018 at 8:58 AM
    Vector W8
    Dont be nervous to SC. This is a gasket failure. it would have let loose with or without the SC. Toyota provided a full warranty if you had the platinum plan on your non FFV SC'ed Tundra it was covered for the 100,000 miles. So gasket failure is not a common occourance with SC'ed engines. Also Toyota uses the same head gasket for the FFV as they do the Non FFV so under Magnuson Moss they would have to prove that the SC caused the gasket failure, and the gasket did not fail on its own. Then the argument would come in to play as to why they would cover the head gasket failure on a non-FFV but it would not be covered on a FFV as it is the same part number performing the exact same function. So I am not concerned about that.
  13. Aug 22, 2018 at 9:08 AM
    B737
    Jersey Shore
    really? This is speculative at best. There is nothing to back this up.
    Do you know this works? You are the one who has to prove your modification did not cause the failure, the onus is on you, not the dealer.
    You are crazy to think a super charger does not put added stress on a head gasket. Add in aftermarket tune, the dealer could hang their hat on that alone and hand you the bill. I would prepare to be on the hook for this repair.
    as an aside, i thought this was the toyota SC on this vehicle? I was under the impression the toyota one carried the warranty.
    stomachbuzz likes this.
  14. Aug 22, 2018 at 9:24 AM
    You probably don’t know his background in the auto industry, but I’ll wait for his reply.....
    Sas, Sunnier and 15whtrd like this.
  15. Aug 22, 2018 at 9:25 AM
    Vector W8
    Apparently you have never read Magnuson Moss. I have worked in the Auto Industry my entire life. The Onus is on the manufacturer to prove that the failure was caused by the modifications made to the vehicle. If you were taken to the cleaners by a dealer than you needed a better lawyer. Yours apparently did not understand the law. Magnuson Moss was written to protect the little guy and prevent him from being bullied and taken advantage of by the auto manufacturers.
    The MagnusonMoss Warranty Act (P.L. 93-637) is a United States federal law (15 U.S.C. § 2301 et seq.). Enacted in 1975, the federal statute governs warranties on consumer products. ... The law was created to fix problems as a result of manufacturers using disclaimers on warranties in an unfair or misleading manner.
    What will void the warranty on a car?
    Although car enthusiasts commonly believe that any modifications will void a warranty, the truth is a little less straightforward. In fact, a modification won't void a warranty unless an automaker or a dealer can prove that an aftermarket part caused the need for repairs.
    Sas, Jengel451, Sunnier and 4 others like this.
  16. Aug 22, 2018 at 9:35 AM
    Vector W8
    In my case there are no aftermarket parts on my truck. The Blower and fit kit are not Magnuson, they are TRD. I am using a Bullydog Flash, but it is based off the same flash that Magnuson provided to Toyota for the TRD supplied blower by Magnuson. Which Toyota would cover under warranty if it was not a FFV. So now they have to prove that the same head gasket in a FFV wont survive being supercharged. Also I could put the dealer in a very precarious position if I wanted to. My dealer installed the SC on a FFV. They did not make me sign any waivers and they did not recommend against doing it. They were more than happy to install the SC on my vehicle. So I could technically sue them. It wont ever come to that. They are good about servicing my truck and they understand the law.
    TexasTundra27, Watt maker and 15whtrd like this.
  17. Aug 22, 2018 at 9:36 AM
    B737
    Jersey Shore
    I'm not an attorney, no lawyers or repairs needed here. but anyways, the dealer could hang their hat on the aftermarket tune alone and call it done. To say "the supercharger has nothing to do with the failure" is foolish.
  18. Aug 22, 2018 at 9:39 AM
    B737
    Jersey Shore
    Ok so the dealer states the cause of the failure, and they offer "proof". You will still bear the burden of proving them wrong.
  19. Aug 22, 2018 at 9:51 AM
    Vector W8
    Yes but being an ASE certified Master Mechanic, an Engineer and Engineering Manager who has worked for OEM's and Tier 1's for over 31 years, I stand on pretty firm ground as I will require them to show me a vehicle with the same set up that has failed. This will mean that the dealer and Toyota will have to prove beyond a shadow of a doubt that the Bullydog Tune is the cause of the failure. They would have to put it in a lab and test to failure. Then provide the court with documented proof of the failure.
    If you are going to play in this arena then you need to know how to stand up to the big dogs. I come a little better equipped to fight the fight, but it will never get to that. If it does I have no problem going toe to toe in court. I spent several years as an automotive expert witness testifying in court for lawyers.
    Sas, 15Yota, Tundra101 and 4 others like this.
  20. Aug 22, 2018 at 9:57 AM
    Smack....
    Sas, boostedtrdpro and 15whtrd like this.
  21. Aug 22, 2018 at 10:04 AM
    B737
    Jersey Shore
    @ColoradoTJ sorry there's no smacking here bud.
    While W8 is prob better prepared for this than anyone else, he is still on the hook to defend his case. The same resources the dealer would use, he would be in a similar position to counter their argument. It adds up fast, and toyota has bigger pockets. I hope this works out in W8's favor. It's not like he put on junk, or sketchy parts but these are the risks we incur doing stuff to our cars.
  22. Aug 22, 2018 at 10:10 AM
    I have no doubt this will be covered.
    Guess we shall wait and see....
    To be continued.
    15whtrd likes this.
  23. Aug 22, 2018 at 11:39 AM
    15whtrd
    15whtrd Mr. Blonde
    In for results. My $$ on covered
  24. Aug 22, 2018 at 12:01 PM
    I would be surprised if Toyota warranties the BD tune, where BD claims is the same tune as TRD or not.
  25. Aug 22, 2018 at 8:47 PM
    Albertaundra
    Albertaundra aka...IgnorantlyAlberta
    David
    '16 SR5 crewmax TRD, '06 Taco walletbreaker
    Bone stock tundra...
    Interesting
  26. Aug 22, 2018 at 9:04 PM
    Danimal86
    Daniel
    Sacramento, CA
    2017 White Tundra SR5
  27. Aug 22, 2018 at 9:08 PM
    big_jarv
    big_jarv New Member
    2021 TRD Pro
    In for results
  28. Aug 22, 2018 at 9:12 PM
    TexasTundra27
    TexasTundra27 Moby Dick
    Mark
    2011 Tundra CM 4x4 5.7
    Icon stage 3, Icon billet UCAs, 5.29s, ARB lockers F+R, Coachbuilder +2s and shims, Rago fab ditch light brackets and bed stiffeners, Rago Fabrication sliders, ARE camper, 17x9 XDs and 37/12.5/17 stt pros, DT long tubes, xpipe with dual magnaflows, Full skids, TrailToys front and rear bumpers
  29. Aug 22, 2018 at 9:16 PM
    boostedtrdpro
    boostedtrdpro voided warranty
    Jeremy
    2024 GMC Sierra 2500HD AT4X 2020 Sequoia TRD Pro 040
  30. Aug 23, 2018 at 4:10 AM
    plumber802
    plumber802 New Member
    Andy
    Vermont
    2018 White Platinum CM
    I'm in...
