Having trouble getting used to this...
Discussion in '2.5 Gen Tundras (2014-2021)' started by RussellVaughan, Sep 22, 2016.
  1. Sep 22, 2016 at 7:42 AM
    RussellVaughan
    RussellVaughan [OP] New Member
    Houston
    2015 Gray TSS 5.7 CM SR5 4x4
    AMP Research PowerSteps; Katzkin leather seats (Nightrunner, all black, no perf/logo); TRD 18" BBS Forged rims; Nitto Terra Grappler G2 LT295/70R18) tires; LT295/70R18 spare tire; Rough Country speedo calibrator; Fox 2.0 IFP front & rear w/1" leaf blocks; TRD PRO black headlamps w/Headlight Revolution harness; TRD PRO grill w/color match hood bulge; RCI engine skid plate; BakFlip MX4 tonneau; Baja Design Squadron Sport fog lights w/clear wide lens; front/rear color match bumper covers; K&N CAI; Pedal Commander throttle controller w-trailer brake bezel; SE Toyota wireless charger tray; VLEDS interior and exterior LED lights; AJT Designs interior chrome delete; Sparks Parts driver side grab handle kit; Pop&Lock tailgate lock; ICS Fab dash mount w/support plate; ICS Fab center console mount; SNS Custom Design ABS sensor guards; TRD PRO shift knob; Undercover Swingcase bed storage; Rad Rubber Design engine splash guards; Bull Ring bed rail tie-downs; exterior debadge w/black & engine badge and black 4x4 badge; Charvonia Design billet bed tie-down anchors; rear console USB port; TRD rear sway bar; Fumoto Oil Pan Valve; Toyota metal oil filter assembly; Vexing R1 dash cam; X2Power 24F Battery.
    So i've had my 5.7 two months. Put about 2000k miles on it. I love it.....but...the thing I still can't get used to is how loud the engine (fan?) is when accelerating from stop. To me, it sounds like a big ass diesel trying to get up to speed. I can't tell if the truck is actually sluggish, but it def sounds sluggish. Is it just the 4.30 gearing and all 5.7s are like this, or is my truck different?? My previous truck was a 5.3 silverado, and I've driven the 5.4 triton...and man they have serious pick-up from stop. Thoughts?
  2. Sep 22, 2016 at 7:50 AM
    Netmonkey
    Netmonkey Don't be a Dumbass
    Georgetown, TX
    2016 Texas Edition, 5.7, CM, MGM
    Icon stage 2 lift, 295 60 20 nitto ridge grapplers, fuel kranks, TRD dual exhaust, TRD rear sway bar
    hmm... I have the 5.7 and I love the sound of it. It is also very snappy off the line and gets up to speed very quickly. I think read somewhere that the 0-60 time for the 2016 tundra is 6.6 seconds. I am extremely pleased with its performance.
    aperezsh, 2cID and zcarpenter92 like this.
  3. Sep 22, 2016 at 8:24 AM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    If you want snappy... Try the Tow/HaulAss button.
    aperezsh, 2cID, Backslider and 4 others like this.
  4. Sep 22, 2016 at 8:30 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    The fan on mine does that as well, it drives my pal crazy. Any chance to aggravate my buddies!
    This is normal.
  5. Sep 22, 2016 at 8:30 AM
    Not sure if this is a new truck or a used truck that you put 2000 miles on. You should fill out your profile so we know.
    Anyway, this is just your clutch fan engaging at low air flow conditions to maintain temperature. Not sure what part of the country you are in, but this time of year is hot, and the added engine cooling is needed.
    Under normal conditions, you should hear the fan when taking off and then stop after 10-20 seconds depending on your cooling system needs. If the fan is staying on more than that empty and you're not in 110*F weather, you may have a good complaint about sound and power. (the clutch fan fully engaged takes a bit of power)
    Recently on a trip of mine towing in the mountains at 92*F, 8-10K feet of elevation I noticed my fan was on more than normal too. I did check out my screen I installed to catch all the bugs, wasps, and grasshoppers in CO. Sure as hell, the damn screen was packed full of bugs. Another good mod to do when you purchase a truck. The AC condenser, radiator, power steering, trans cooler will thank you years later when others cooling performance takes a crap and yours does not. I just buy the screen material at Home Depot for cheap. Get the synthetic fiber material.
  6. Sep 22, 2016 at 8:50 AM
    RussellVaughan
    Houston
    Great info! You taught me a lot. It is a used truck, has just under 18k miles. Also, I'm in Houston, and its been very hot...After reading your response and the other responses I feel better about it. Only question I have now is...does Ford and Chevy fan clutch behave like this? I've never noticed this sound on other trucks.
  7. Sep 22, 2016 at 9:00 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Some others may use an electric fan, often they're quieter and run at a lower speed but more continuously. They're not connected to engine RPM either, so it's likely not as audible.
  8. Sep 22, 2016 at 9:45 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    I've read where a few others do this. Where do you attach the screen to? I assume it is behind the grill, between grill and radiator? Thanks
  9. Sep 22, 2016 at 10:36 AM
    davesnothere
    davesnothere New Member
    Dave
    Down South, Texas
    2016 Tundra Limited 4x4 5.7ffv
    Pro Comp stage 2 6" lift- 20" XD Rockstars- 35" pro comp a/t sport- Hypertech Interceptor- 7" BA Muffler- 4.88 Yukon gears
    What kind of screen? Like a metal grate, diamond shape? House screen, man these migrating butterflies or killin me with the cleanin
  10. Sep 22, 2016 at 11:09 AM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    House window or door screen.
    ColoradoTJ likes this.
  11. Sep 22, 2016 at 12:19 PM
    Home window screen
    I'll take a pic in a bit of mine.
    davesnothere[QUOTED] likes this.
  12. Sep 22, 2016 at 12:25 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Awww....if you do that I'll have to do this mod....dangit.:annoyed:
  13. Sep 22, 2016 at 12:35 PM
    Kaerntner
    Kaerntner New Member
    2016 tundra sr5
    OP,FWIW,if fanclutch runs continuously, may need to check clutch. Uncommon to wear out at that mileage, but not unheard of
  14. Sep 22, 2016 at 1:17 PM
    I just cut the screen in a somewhat close shape of the inlet, then used the factory bolts. Do not use the horn mounting bolts. I believe this is the ground for the horn and they will not work.
    This screen has 75k miles on it.
  15. Sep 22, 2016 at 4:39 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Looks like a beekeepers hat.
  16. Sep 22, 2016 at 6:12 PM
    dave91gt
    dave91gt New Member
    West Virginia
    2016 SR5 TRD Crewmax 4x4
    Ford uses an electric fan. I believe GM and Ram do as well. Toyota has stuck to the tried and true mechanical fan. And yes- it's loud.
    As far as sluggish, hit the tow haul button. It's pretty aggressive. I came from an Ecoboost F150 and the tow haul button makes them "feel" similar.
    Wynnded and ColoradoTJ like this.
  17. Sep 22, 2016 at 6:23 PM
    Ditto on the Tow Haul button, mechanical fan. I like that screen idea. I just happen to have some left over window screen material. Cool.
  18. Sep 22, 2016 at 7:45 PM
    That is my second career choice....kind of a pain in the ass though.
    The amount of rocks sitting at the bottom of that screen every two weeks is amazing. My AC condenser would be trashed by now.
  19. Sep 22, 2016 at 8:26 PM
    Backslider
    Backslider Thirsty...
    Tooele, UT
    I had no idea - gonna try this out tomorrow. Thanks for the tip!
  20. Sep 22, 2016 at 8:39 PM
    Next weeks post from Backslider:
    My Fuel Economy Sucks ASSSSSSSS!!!!! Help.....
    LOL
  21. Sep 22, 2016 at 8:45 PM
    BB Stacker
    BB Stacker New Member
    So. Cal
    2016 White 1794 TRD 4X4
    Sway Bar, TRD Catback Exhaust, Morimoto LED fog lamps, running boards, paracord wrapped oh-shit handles, Bak-Flip bed cover.
    I really like the idea of the screen. I've had radiators get pretty gunked up from all of the high speed collisions with bugs and they are pretty hard to clean up after they have had a chance to bake on. I've also noticed that some insect innards are pretty corrosive. Looks like another project coming up this weekend.
    ColoradoTJ and ChucklesToy like this.
  22. Sep 22, 2016 at 8:45 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    Thanks for the pictures. I am amazed at how many bugs get stuck in the radiator and we have some BIG bugs here in Texas LOL. I assume there is no issue with air flow?
  23. Sep 22, 2016 at 9:08 PM
    panorod
    panorod New Member
    Pano
    N. NEVADA
    2014 SR5
    none yet but looking for ideas
    GREAT IDEA, GONNA TRY THAT THIS WEEKEND!
  24. Sep 22, 2016 at 9:13 PM
    Only issue I have with air flow is on my last trip. I did a bunch of towing miles next to a river and it seemed like every bee, grasshopper, and bug was bound and determined to see what its ass looked like one last time. I wish that a picture was taken, but the screen was pretty plugged up. My fan stayed engaged a little longer going over Vail Pass (Ike Gauntlet), but it was pretty hot out and I pulled the pass at speed limit with ~8500 lbs.
    The lower part of the front end can be sealed up too, but I didn't do that part. I mostly just covered the top to save the AC condenser and possibly the radiator. So far, the bottom part is pretty clean.
  25. Sep 23, 2016 at 7:48 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Wait a second. Might you be suggesting that using the T/H button on our 380HP Tundras will make them feel similar to 365HP EcoBurp? :p:D
  26. Sep 23, 2016 at 7:50 PM
    Ahh...381 HP
    Wynnded[QUOTED] likes this.
  27. Sep 23, 2016 at 7:55 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    Perfectionist. Ready to give up that bed extender yet?
  28. Sep 23, 2016 at 8:03 PM
    I'm a Metrologist. I can get anal at times. No. I really like it. You got something to trade for it???
  29. Sep 23, 2016 at 8:19 PM
    Wynnded
    Wynnded What MPG...
    Rockies
    Souped up truck
    LOL, not really. Some nicked up stock alloys and a stock t-case. But the case isn't a fair trade.
    gosolo likes this.
  30. Sep 23, 2016 at 8:25 PM
    Don't you live in the sticks?? No Bison jerky to trade??
