Having a brain fart (yes ANOTHER offset question)
Discussion in 'Wheels & Tires' started by Cement, Apr 24, 2019.
  1. Apr 24, 2019 at 4:22 PM
    Cement
    Cement [OP] ...
    2019 Cement Trundra TRD
    I'm confusing myself. Set me straight:
    Stock TRD 18" wheel = +60mm offset, correct?
    If I currently have 1.25" spacers, that effectively means my stock TRD 18" wheels have an "offset" of +28 1/4mm. Correct?
    So if I were to remove the spacers, and go with a wheel that has a +12mm offset, my new wheels would stick out FURTHER than my current wheels by 16 1/4mm, or 0.64" MORE than they do right now.
    Do I have all that right?
    PS: What do the stock TRD 18" wheels weigh?
  2. Apr 24, 2019 at 4:28 PM
    Sas
    Sas Humor is everywhere
    OKC, OK
    '17 SR5 CM TSS 4WD MGM 5.7 FF
    Lost track after #1.
    That sounds right to me.
  3. Apr 24, 2019 at 4:32 PM
    jewsNbrews
    Jewiston Idaho
    2019 TRD PRO
    Bolt on
    Give or take a mm yes. 25.6 mm per inch. Not sure on stock wheel weight.
    Edit: if I did my math right, .63975905512 inches difference.
    Cement[OP], BTBAKER and Black Wolf like this.
  4. Apr 24, 2019 at 4:39 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    2019 Tundra SR5 TSS Double Cab
    Wheels, sound system, antenna, tailgate letter inserts, Grill/Hood Bulge, Exhaust, Leather
    Looks correct....not sure if the offset is different on the 18” factory TRD compared to the 20” tss but I believe the offset on my factory wheels was ~+.52
  5. Apr 24, 2019 at 4:47 PM
    What's cool is we have a Keysight Reference DMM with 8.5 digits of resolution. It could measure 0.63975905 VDC.....heh....heh....
  6. Apr 24, 2019 at 5:22 PM
    Cement
    Cement [OP] ...
    Sweet! The voices were right! (this time).
    Thanks ya'll :)
    Black Wolf, Sas and jewsNbrews like this.
  7. Apr 24, 2019 at 5:28 PM
    BTBAKER
    BTBAKER .
    Brad
    Castle Rock
    2022 Ram TRX Level 2
    Sounds right to me.
  8. Apr 24, 2019 at 7:03 PM
    DCB500
    DCB500 New Member
    David
    Oklahoma City
    When I said factory.....I meant the TSS wheels that came on my truck from the dealership, my bad
  9. Apr 24, 2019 at 7:41 PM
    aRabidLunatic
    aRabidLunatic Professional Hobo
    Central Texas
    2015 Tundra SR5 Black
    Too much math in here....
    BlackSheep and Black Wolf like this.
