Have Tundra oil changed at Lexus Dealership?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nflguy, Mar 22, 2023.
  1. Mar 22, 2023 at 8:10 AM
    Nflguy
    Nflguy [OP] New Member
    I have a 2021 Tundra TRD Pro. I usually get my oil changed at a Toyota Dealership but its a hassle getting to them (hour drive). There is a Lexus dealership 10 minutes from my house though. I'm curious if anyone here has had their Tundra oil changed at a Lexus dealer.
  2. Mar 22, 2023 at 8:30 AM
    MedCityMoto
    MedCityMoto SciTech Nerd
    2.5gen CM SR5 TRD OffRoad
    Bet it'll be spendy, my nearest Lexus dealership is about that same hours drive away but their site says at least $100 for the oil change. My next 4 oil changes will cost me - let's see - $168 or so for the filters and oil, around $42 each? I just bought a 4-pack of filters and grab oil when I find it on sale, I stick to Mobil1 or Castrol generally. I swapped the drain plug to a Fumoto so don't even need to factor in the crushwasher there.
  3. Mar 22, 2023 at 8:32 AM
    Nflguy
    What's crushwasher?
  4. Mar 22, 2023 at 8:39 AM
    TundraMidwesterner
    TundraMidwesterner What?
    Northern Illinois
    2019 Magnetic Gray Metallic CrewMax TSSOR 4x4
    Katzkins, Rostra heated seats(4), Tint (all), TRD rear sway bar, TSS wheels, OEM black lug nuts and wheel locks, OEM LED black fog lights, Driver side grab handle, Rough country LED Bumper bar, Rough Country Hard tri fold tonneau cover, AVS ventshades, Bilstein 5100's on top setting in front, Ready lift 1 inch ready block in the rear with Bilstein 5100's. Fluid Film. ESP under seat storage. LED interior lights and cargo lights swapped. Rear USB charger port swapped for 12v port. Remote start. Leather wrapped steering wheel kit. TRD shift knob. Kenwood dmx1037s. Hertz K170 door speakers/ tweeters, Infinity Reference 7005A 5 channel amp, 2 JBL WS1000 10 inch subs. DDI Seat Jackers. RCI engine Skid and Vahalla's Shields (front and rear) 1/4 aluminum. Stillen intake. LED Pro Headlights with iHacker harness. Cartrimhome auto up and down window switches. Coupe's aluminum battery tie down. Color matched mirror caps. Color matched door handles. Chalk bag cup holder. NFab podium step bars, herculined. Powerstop z36 drilled slotted brake discs w/ceramic pads.
    Crush washer goes between drain plug and oil pan and is one time use / soft metal. Helps get the right torque on the drain plug without damaging threads on the pan.
    Lexus technicians would have a higher hourly rate than toyota. I'm not sure by how much. might be marginal depending on your area.
  5. Mar 22, 2023 at 8:42 AM
    MedCityMoto
    If cost isn't a concern, they're going to have the technical know-how for sure, as Lexus is essentially Toyota with premium bling after all.
    Heck, I'd argue the experience would probably be cushier than usual since their dealerships tend to be even better stocked for coffee and snacks. I'd bring the work laptop and make a morning out of it!
    Soupbean77 likes this.
  6. Mar 22, 2023 at 9:13 AM
    SPOirish28
    SPOirish28 New Member
    Ontario, Canada
    2014 SSM SR5 DC
    Satin black roof, 18” KO2’s, satin black powder coated steel rims, tri fold tonneau cover. Led lights interior, exterior. Trd pro grill. 13” ryonnair antenna. OEM LED headlights.
    Toyota changes the oil on my Lexus all the time. I always buy my own oil on sale and would pay $50 total for the oil change - at Lexus. The Toyota dealership is a lot closer to us after we moved in Sept. Lexus might charge you a bit more but I doubt it.
  7. Mar 22, 2023 at 6:18 PM
    Kbar691
    Kbar691 Hmmm
    Kenny
    2019 TRD Pro
    My wife has a GX460. Dealership wanted $250 for oil change and tire rotation.
  8. Mar 22, 2023 at 6:26 PM
    AZTundra
    Paul
    Phoenix, AZ
    I've used the Toyota dealership where I purchased the truck new for services the last five years. This most recent year I switched over to Lexus due to the Toyota service advisor taking a new position over at Lexus. I wanted to stick with the same service advisor because he's been great to work with and also works with my extended warranty w/o blaming things on aftermarket installs or the supercharger.
    The oil changes and brakes I had done at Lexus also showed up on the Toyota owners website in the vehicle history which is nice.
  9. Mar 22, 2023 at 6:46 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    Only Capstone and 1794 trims are allowed into the Lexus maintenance area.
    JK, since the 5.7 is common for Lexus makes sense to me.
    panicman likes this.
  10. Mar 22, 2023 at 8:28 PM
    MedCityMoto
    :eek:
  11. Mar 23, 2023 at 2:22 PM
    pman9003
    pman9003 New Member
    2020 Platinum 4x4
    Ask for a quote on just the oil change. I have an LX470, oil change only is usually around $80. Adding a tire rotation took it $220ish last time I asked, but that was a while ago.
    Lexus and Toyota dealerships can service either vehicle no issue, other than the premium price for Lexus service. All the training and software tools the dealers use are the same.
    Kbar691[QUOTED] likes this.
  12. Mar 23, 2023 at 2:27 PM
    I’d love to know what is involved in a $140 tire rotation. Single use white silk gloves? For that price I would want a balance and alignment included in the rotation.
    Kbar691 and Gravy like this.
  13. Mar 23, 2023 at 2:27 PM
    omgboost
    omgboost The Accountant
    East Coast
    2012 Sequoia Platinum
    Has a dealership ever turned away money?
  14. Mar 23, 2023 at 2:49 PM
    Randy Morton
    Randy
    Deepinahearta, Texas
    2012 Tundra Double Cab (I call it my Land Yacht)
    I go to a Toyota/Lexus independent for oil changes. I tried the dealer a couple of times, but the 3+ hour wait was just too much. It was amusing that they had big posters up telling you the wait could be up to 3 hours if you didn't have an appointment. I booked an appointment and it always took over 3 hours. It was a little over an hour yesterday, but they checked brakes and a few other things at the same time. It's a bit pricey, but I'd rather pay a little more to someone that wants to keep me as a customer and has proven to do top notch work in the past. For those interested, it's https://www.davenportmotorco.com/
  15. Mar 23, 2023 at 3:25 PM
    AZTundra
    Paul
    Phoenix, AZ
    I'll have to find my receipt from Lexus. I just had the oil changed and tire rotation/rebalance completed about a month ago.
  16. Mar 23, 2023 at 3:32 PM
    AZTundra
    Paul
    Phoenix, AZ
    Found it. This was just completed on 2/15/2023 at Earnhardt Lexus in Phoenix, AZ.
    Oil Change and Filter came to $116.06. Rotate and Balance all four tires totaled $90.00.
  17. Mar 23, 2023 at 4:12 PM
    Charvonia Design
    Charvonia Design Enthusiast-Owned Small Business Vendor
    Keith
    Huntersville, NC
    2024 Tacoma TRD OffRoad Bronze Oxide
    It’s the same parts so why not? I would ask them to honor the Toyota price, worth a shot.
