Have an interesting problem
Discussion in '2nd Gen Tundras (2007-2013)' started by Ryder, Sep 5, 2019.
  1. Sep 5, 2019 at 7:53 PM
    Ryder
    Ryder [OP] New Member
    2007 Tundra with 2014 wheels Smittty built bumper and winch
    2007 TRD. Gets hot and won't start. Only a little over 100k. coolant full and clean. running mobile 1 synthetic. Ideas?
    Rica25 likes this.
  2. Sep 5, 2019 at 7:57 PM
    4x4_Angel
    Bree
    Funky Town, Texas
    2014 SR5 CM Silver Sky
    Gets hot as in over heating? If so it might be the thermostat stuck closed
  3. Sep 5, 2019 at 8:11 PM
    Ryder
    No, gets hot as in won't start if you shut it off. Had to wait 20 minutes one day. Embarrassing.
    GNTundra and Rica25 like this.
  4. Sep 5, 2019 at 8:25 PM
    HappyGilmore
    HappyGilmore Ex 1st Gen Member
    Trent
    Lakewood CA
    2018 White Limited TRD 4x4
    I don't follow.
    Are you saying the motor gets too hot to start? Does it throw a check engine light? Does your temp gauge show over heating?
    Rica25 likes this.
  5. Sep 5, 2019 at 8:54 PM
    Scuba
    Scuba Sober member
    Austin, Tx.
    2012 Texas Edition CM.
    Sounds like “gets to normal operating temp, shut the truck off and it won’t start back up.”
    YardBird, Mountun Goat and Rica25 like this.
  6. Sep 5, 2019 at 9:10 PM
    Windsor
    Windsor Why do I do this to myself?
    Homeless in Oregon
    2008 Tundra Crewmax 5.7L
    Some.
    Check your battery cables. If they have corrosion inside the wiring, the resistance increases when they get hot and there isnt enough juice to get the starter to crank.
    GNTundra likes this.
  7. Sep 5, 2019 at 9:24 PM
    TrooperDC4x4
    TrooperDC4x4 New Member
    Nor Cal
    2017 BBP Double Cab 5.7L TRD 4X4 OR
    Bilstein 5100 2.5", 1.5"
    Read this thread. No definitive answer but some ideas. I had a similar problem on my 07. Was a problem with a computer and the anti theft system. Only happened when at operating temp after being under load.
    https://www.tundras.com/threads/2007-starts-and-died.52015/
    Edit, this is the engine cranking and either not starting or starting and dying.
  8. Sep 5, 2019 at 9:54 PM
    Windsor
    Homeless in Oregon
    Some.
    @Ryder, clarify please.
    Are we talking crank no start, crank/start/die, or no crank?
  9. Sep 5, 2019 at 10:58 PM
    3rdgenButtrunner
    3rdgenButtrunner New Member
    1996 4runner
    Ignition/starter relay is bad. Friend had a few gm cars with the same issue, after driving a while even more so when it's hot out, once shut off the car wouldn't start, after sitting for a bit usually 15-20 minutes, would fire right up.
    Grumpy Uncle likes this.
  10. Sep 6, 2019 at 3:38 AM
    Rex Kramer
    Rex Kramer Vinyl Spinner
    Georgia
    My '07 had a similar problem, a new immobilizer key chip and fuel pump fixed it at a little over 270k.
  11. Sep 6, 2019 at 6:54 AM
    bcancienne
    bcancienne New Member
    Fuel pump or fuel filter could be the culprit. I would definitely check fuel pressure, if its not high enough, injectors will not supply fuel.
  12. Sep 6, 2019 at 6:57 AM
    bcancienne
    Are you saying engine wont turn over (as in dead) or won't fire up while turning over engine?
  13. Sep 6, 2019 at 7:07 AM
    RickC
    RickC NOT a new member
    Rick
    Knoxville TN
    2017 CrewMax Platinum 4x4 5.7
    SCS Wheels, Line-X, WeatherTech, UnderCover Flex bed cover
    I had that issue on my camry. Turned out to be the starter. I could drive it 2 miles up the road and it was enough that it appeared the battery was dead when turning the key. Once it cooled off, it would start like normal. I replaced the starter after some Internet research and that fixed it.
  14. Sep 6, 2019 at 8:57 AM
    Ryder
    Temp gauge never goes above 1/2. I wish Toyota could manage a digital gauge, they have been available for 30 years at least. Throws no code, and the battery is new and it cranks, it just wont start.
  15. Sep 6, 2019 at 8:59 AM
    saybng
    saybng Just a member.
    Gary
    Ventura CA
    16 Tundra 1794 CM in BLACK!
    Check starter and or cables..
  16. Sep 6, 2019 at 9:01 AM
    Ryder
    Thanks, I will try that key thing. Don't understand why it only does it when hot, however.
  17. Sep 6, 2019 at 9:03 AM
    Ryder
    Only did it when hot?
  18. Sep 6, 2019 at 9:04 AM
    Ryder
    It cranks fine, just doesn't catch.
  19. Sep 6, 2019 at 9:10 AM
    Ryder
    It cranks all day, just won't catch. The starter and battery are fine.
  20. Sep 6, 2019 at 9:31 AM
    saybng
    Gary
    Ventura CA
    Where are you located?..have you tried tapping on the starter while cranking her over?
  21. Sep 6, 2019 at 9:49 AM
    PCJ
    PCJ New Member
    State of Jefferson
    2004 DC Limited 4X4
    Lift, Rims, Bigger Tires, Nerf Bars, Black Out Emblems
    If it cranks and does not start you are missing either fuel or spark. Verify which one is missing and then you can start trouble shooting in the right direction.
    RickC likes this.
  22. Sep 6, 2019 at 10:42 AM
    Stainlesst
    Stainlesst everybody loves an Inky. Inky Inky. go Inky go!
    going to the big D and don't mean Denver...
    09 trd crewmax, 13 TWReX stage III
    In the "Zone"...
    happened to mine a while ago the tumbler in the keyed ignition was cracked from over weight on the the key chain... i got rid of the excess keys and got a new tumbler and ignition keys under warranty. how bad does your key look? is it all bent up or worn?
  23. Sep 6, 2019 at 11:29 AM
    Marcus like
    Marcus like New Member
    Do you hear the fuel pump when you turn the key on prior to cranking the truck? If not they expected to fail at around 7-10 years.
  24. Sep 6, 2019 at 11:32 AM
    RickC
    Rick
    Knoxville TN
    This is your issue. For some reason, when it's hot, you are missing either fire or fuel. Since you said it's cranking, just not firing, then it's definitely not the starter. My guess it's missing spark but you will need to figure out which.
  25. Sep 6, 2019 at 11:54 AM
    7.62Tundra
    7.62Tundra Chromeaphilliac
    SA Texis
    2015 5.7 Crewcab
    Do tundras cut off fuel with a crankshaft sensor?. Had a car that did similar.
  26. Sep 6, 2019 at 12:23 PM
    Ryder
    Why? The starter doesn't control the computer.
  27. Sep 6, 2019 at 12:27 PM
    Ryder
    I have never heard the fuel pump. It is located in the tank. I will have to wait for next year to check, we are into the fall, and it won't get hot again until next June at least. Thanks for the suggestion.
  28. Sep 6, 2019 at 12:28 PM
    Ryder
    Keys are like new. This rig only has 100k on it. Just getting broke in.
  29. Sep 6, 2019 at 12:34 PM
    Stainlesst
    In the "Zone"...
    yeah mine only had 70k on it when i happened must have been prior owner that loaded the keys up. but it did about the same thing crank and no fire... do you just turn the ignition once and just let it do the one touch crank or do you hold the key in start position while it cranks? the ignition is a one touch system will crank till start or go for i believe five seconds or till key is switched off or back to acc...
  30. Sep 6, 2019 at 12:37 PM
    Stainlesst
    In the "Zone"...
    defiantly have someone check it with tech-stream cause it was not throwing any codes when mine did it... just waited 10 minutes to retry starting. the code that did show was key relearn failure.
