Hauling two 11' kayaks?
Discussion in 'General Tundra Discussion' started by LuvniForce, May 21, 2021.
  1. May 21, 2021 at 7:14 AM
    LuvniForce
    LuvniForce [OP] New Member
    2008 Silver Crewmax 2wd ARE topper
    What’s the best way to haul 2 kayaks on a crewmax with ARE shell? Our kayaks are 11’ long basically… pics or info appreciated!
  2. May 21, 2021 at 7:31 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
  3. May 21, 2021 at 7:51 AM
    Bprose
    Bprose Old member
    VA
    17 Tundra CM TRD
    6843C9C8-E729-4762-8722-8CF7DEA544C7.jpg 3E306E6A-7C39-4DFC-8DBB-695E65C818D8.jpg 4EA54DEF-0C82-4142-8EBD-637F63D2ADD3.jpg I’ve found I can also strap them strait onto the racks without the kayak cradle. Roof rack is no drill. Inno rack.
    cradle is for a single or double.
    LuvniForce[OP] likes this.
  4. May 21, 2021 at 4:59 PM
    a522467
    a522467 Life’s short. Live now.
    Michelle
    Ohio
    2020 Black Tundra Doublecab 4X4 SR5 with SX pkg
    Rear spring upgrade, rear shock upgrade, front & rear sway bars, bed step, bed mat, console organizer & tray, black lug nut covers, rear underseat storage box, black seat covers, Bluetooth CarPlay adapter, LED fogs, blue footwell lighting, LED cargo, reverse, tail, and stop bulbs, tinted tail and 3rd stop/cargo lights, tinted glass all around, tinted front emblem, matte black tailgate emblem inserts, retractable tonneau cover w/trac system and load bars, front facing camera, 8” exhaust upgrade, LED bed lights, 8-ball shifter knob, shifter boot, LED headlights, custom wheel center caps, 3”x30’ tow recovery strap, bed rail clamps, LED puddle lights, phone mount, OBD2 scanner, touchscreen glass protector/overlay, trailer hitch lock, tire traction aid, tinted license plate cover, power relay module, 6-way fuse block with cover, stainless mesh cowl screens, LT265/70R18 A/T tires, driver’s side swing case toolbox, dual air horn kit, rear Husky Liner, cat converter theft deterrent covers, front & rear dash cam, LED tail light bar, trailer plug wiring harness, locking fuel door, matte black interior door handles, glovebox & fuel door keyhole decals, TUNDRA sill plates decals, chalk bag cup holder / trash can, HD Roadmaster active suspension kit, HD front struts, Backlit window control panel, tailgate gap cover, matte black radio surround. https://www.tundras.com/threads/740-yota-2020-sr5-4x4-dc-w-sx-pkg.79742/
    My Tacoma TRD Pro with 5’ bed has an ARE topper. It has Yakima racks on top, but I prefer to use a bed extender for hauling my 10’ kayak (easier to load). I got my bed extender from Amazon.
    https://www.amazon.com/ECOTRIC-Truck-Extender-Extension-Lumber/dp/B01AW6BEBK
    It stuck out a bunch at first, so I shortened the lower bar a little. It adjusts to 49” wide, so two kayaks would probably fit fine in it with a Tundra. I wrapped mine with foam and gorilla tape to soften the ride a bit after adjusting it to the width I wanted.
    If you want to keep the kayaks out of your bed, and your topper has roof racks, the extender can be oriented differently too. I haven’t used it this way (since I modified it), but here’s someone else’s photo.
  5. May 22, 2021 at 4:07 PM
    LuvniForce
    Awesome! These are all really good options… thanks!
