Hauling a full size tire in the spare under carriage?
Discussion in '2nd Gen Tundras (2007-2013)' started by JROCK915, Jan 28, 2015.
  1. Jan 28, 2015 at 6:19 PM
    JROCK915
    JROCK915 [OP] Trust noone, and be prepared!
    Jeremy
    Palm Desert, CA.
    2011 Trail ready SR5
    Icon 1.5" leaf pack, w/ Pro Comp 1" block Rear Pro Comp SS shocks ToyTec/Eibach coil overs, on Pro Comp SS shocks, SPC UCA AFE Stage II C.A.I, and throttle body spacer N-Fab nerf bars N-Fab RSP front bumper with Hella Optilux 30" LED bar, and Hella Optilux 4" (2) HID driving lights Federal Couragia 33x12.5x20, wrapped around 20x9 Fuel Boost Fender flares Spyder LED tail lights (smoked out)
    Any 2nd Gen guys out there, hauling a full size (33-35), in their spare under carriage?
    I've seen one article about it. He had 35s on 20", and removed the guiding brackets. I'm running 33s on 20". I think I can w/o any mods.
    Just wanted to see if anyone else has tried this! It'll be a hell of a lot cheaper than a "Tire Gate".
    Thanks!
  2. Jan 29, 2015 at 6:39 AM
    FunkinTundra
    FunkinTundra New Member
    Cody
    2012 Tundra 5.7 CM
    OME614 full suspension\ Ekstrom design 3" shackles and poly bushing kit\ 295/70r18 Toyo MTs/ +20 offset Fuel Anzas\ 8" BAmuffler....etc...
    I think you can unless you have bigger/extended shackles...but I think I read you have a block back there so you "should" be ok... Hopefully someone with more experience can help ya:) :bump:
  3. Jan 29, 2015 at 5:22 PM
    JROCK915
    Jeremy
    Palm Desert, CA.
    The block is gone now. Just replaced them w/ Icon's 1.5" replacement pack leafs.
    I crawled under there and measured her up. Looks like I may have 1" give on either side.
    Was just wandering if anyone else has tried it. Thanks for that info though. Good to know about the shackles.
  4. Jan 29, 2015 at 6:29 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Give her a try and let us know.
    JROCK915[OP] likes this.
  5. Mar 27, 2015 at 2:47 AM
    tacoma7829
    tacoma7829 New Member
    Ed
    2013 CrewMax
    I have coach builder +3" and a full size 275/65r20 (34.1") spare with no issues. However I did hve to grind and cold chisel the rivets out of the brackets for the factory spare to allow this.
