Has anyone went with a staggered wheel and tire set up?
Discussion in '2.5 Gen Tundras (2014-2021)' started by Nebz, Apr 28, 2015.
  1. Apr 28, 2015 at 8:00 AM
    Nebz
    Nebz [OP] New Member
    Orlando
    2014 Magnetic grey SR5
    Front Mesh Grille upper and Lower, Factory Steps, Flipbak cover, Spray in liner, Ballistic Sythe wheels, weather tech liners with tundra badges
    Im thinking of going 275/50/22 with 22x9 wheels in the front and 305/55/22 22x10 in the rear. Just a thought, I went staggered on a previous truck I owned and really liked it.
  2. Apr 28, 2015 at 8:27 PM
    If I was drag racing it, maybe I would consider it.
  3. Apr 28, 2015 at 8:38 PM
    Mike Tread lightly.
    south carolina
    Why would you? You cant rotate tires or anything with that set up. If you have a tire that (cups for example) you cant rotate it to the back to try and get the tire to wear even again.
  4. Apr 28, 2015 at 8:56 PM
    Nebz
    Orlando
    I hear you on both points. Just thinking of a different look.
  5. Apr 28, 2015 at 8:58 PM
    Mike Tread lightly.
    south carolina
    Mind if i ask how you had it on your previous truck?
  6. Apr 28, 2015 at 9:27 PM
    csuviper
    Broomfield, CO
    2019 TRD Sport CM 5.7L 4X4
    Can't do it with 4x4 if diameters are different. Haven't looked up diameters to know. Obviously it's a width difference. Not sure it makes much sense on a truck. Might make handling around corners rough and put excessive wear on one set. I do not have any experience with this setup though.
    Relentless likes this.
  7. Apr 29, 2015 at 7:16 AM
    Nebz
    Orlando
    I had a ford ranger, 315/70/15 in the back with Lund wide side flares so the tires were flush with the flares. I had 255/50/15 in the front.
    It was nice, billet grille and Gaylord air dam, cowl induction hood, Gaylord Fiberglas cover, Lund roll pan, grant boomerang steering wheel, flow master exhaust, chip, etc.. all black with silver stripes down the middle.
  8. Apr 29, 2015 at 7:19 AM
    chphilo
    chphilo Tundra addict
    Western PA
    I have not seen a truck with different size tires like you mentioned. Does this set-up put more stress on the truck components?
    edit: auto -correct seems to work too well sometimes, haha.
  9. Apr 29, 2015 at 9:54 AM
    Mike Tread lightly.
    south carolina
    I see what you are doing now just wanted to make sure. That set up really is for drag racing as stated before. The look you want is nice but the ride it will handle like crap, do to how heavy the tundra is up front. You would have the play with spring loads to find one that would work best on that set up to do the heavy v8 in the tundra.
  10. Apr 29, 2015 at 10:43 AM
    Dave333
    Dave333 New Member
    Dave
    2015 Platinum CrewMax
    Like everyone else has said, that setup is mainly meant for performance, but based on an entirely different chassis platform. I'm currently building a 70 C10 with a staggered set up...BUT it has a 5" ride height, engine recessed and Corvette C4 suspension components. Our Dodge Charger SRT8 has a staggered set up. For a truck, it's completely different. The weight ratio and ride height is all wrong. Unless you plan on lowering your Tundra, you'll run into suspension wear nightmares and and harsh ride. I'm ASE certified and work at a custom/rod shop. If you do it, let us know how it turns out.
  11. Apr 29, 2015 at 2:28 PM
    Mike Tread lightly.
    south carolina
    Not to derail the tread here.
    this i would like to see when your done. Never seen a c10 staggered before like this.
  12. Apr 29, 2015 at 4:15 PM
    Dave333
    Dave333 New Member
    Dave
    No problem. Drop member is being mocked up this week. By going with a C4 spindle and hub, UCA's upper and lower I gain more for pro touring and lose a lot of weight. The all aluminum LS1 and C5 rack and pinion help too.
    Mike likes this.
  13. Apr 29, 2015 at 7:53 PM
    Nebz
    Orlando
    Good insight Mike, I'm hesitant to mess with ride height but it seems that nearly everyone does at least the leveling kit so you can run a larger wheel and tire set up.
  14. Apr 29, 2015 at 8:39 PM
    Mike Tread lightly.
    south carolina
    Im only part right, dave333 hit it on the head and beat me to it about ratios and ride height.
