Has anyone seen this?
Discussion in 'General Tundra Discussion' started by Cement Pro, Oct 11, 2017.
  1. Oct 11, 2017 at 3:45 PM
    Cement Pro
    Cement Pro [OP] New Member
    2017 Toyota Tundra Pro
    Stock
    I just walked out in the garage and noticed part of my back door handle is missing. I don’t drive the truck much but did take it out to Walmart this morning. I don’t see where anything collided with the door handle or anything. The back part is simply missing. I put some furnace tape over the hole so water doesn’t get in there until I can get it fixed. Has anyone else had this happen?
  2. Oct 11, 2017 at 3:47 PM
    Cement Pro
    Stock
    Here’s another picture
  3. Oct 11, 2017 at 3:50 PM
  4. Oct 11, 2017 at 3:55 PM
    Not here either.
  5. Oct 11, 2017 at 3:56 PM
    Maybe an attempted vehicle burg? Ford handles pop off hence the theft rate.
    Law323 and 4x4_Angel like this.
  6. Oct 11, 2017 at 4:03 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    There isn't even a keyhole there. Anyways, do they have color matched in cement yet? Now would be a good time to swap.
    4x4_Angel likes this.
  7. Oct 11, 2017 at 4:05 PM
    BakNBlk2014
    BakNBlk2014 So Impossibly Black
    Donald
    Virginia Beach VA
    2014 limited cm attitude black 4x
    BDS 4 1/2 Nitto Terra Grappler 35x12.5/18 BW Fender Flares Moto Metal 970 Wheels Leer Tonneau Bed Cover Black Plastidip Grill CF Wrap Interior AJT Shift Knob 35% Tint Weather Tech Mats Toyota Bed Mat AFE Intake
    I 've taken my handles off to plastidip and the big handle part you have left is just pushed in and slid back into place. The small part you are missing locks both in when you tighten the torx bolt in the door jam. Open the door, locate round rubber seal handle high on the inside door and remove. Make sure Toyota put one in, if you have one there take the torx screw driver with you to dealership, tell them it wasn't tight or worked itself loose and to GIVE you the new end piece to the handle and put it on yourself while there. Make sure it isn't stripped out or anything before you leave. The torx bolt will remain in place even when completely loose. Hope this helps.
  8. Oct 11, 2017 at 4:06 PM
    Pudge
    CT
    2015 Blue Ribbon Platinum
    Roman and TundraTss like this.
  9. Oct 11, 2017 at 4:12 PM
    040Tundra
    040Tundra Teddy 2013-2019
    Aaron
    Las Vegas, NV
    040 '16 CM LTD 4x4
    I’ve never seen that. I doubt it could just fall off but crazier things have happened. I tend to lean towards what Sean said about the stealing of your truck.
    If it did “fall” off then Toyota should replace at no charge.
    T-Rex266 and 4x4_Angel like this.
  10. Oct 11, 2017 at 4:13 PM
    Masshole
    Masshole Lovin' The Great North Woods
    New England
    2014 DC MGM 4X4 SR5 TRD
    Happened to the rear passenger doors on the sedan I traded in when I got the Tundra. Many years after I bought the car. It's likely a part defect covered under warranty.
    NewImprovedRon likes this.
  11. Oct 11, 2017 at 4:13 PM
    Cement Pro
    Stock
    Do you think the piece remaining is in danger of falling off without the piece that locks it in?
  12. Oct 11, 2017 at 4:23 PM
    joonbug
    joonbug °°°°°°°°°°
    Joon
    NorCal - Dublin
    2020 LT DC
    no
  13. Oct 11, 2017 at 4:25 PM
    BakNBlk2014
    Donald
    Virginia Beach VA
    No. The piece in the door that screws into the small handle part to lock it in will stay in place. Although there is a small rubber gasket that goes between the part you are missing and the door. It might be in place but check that way you get both parts when you go to the dealership.
    Cement Pro[QUOTED][OP] and Pudge like this.
  14. Oct 11, 2017 at 4:31 PM
    Masshole
    New England
    Nope
  15. Oct 11, 2017 at 4:57 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    Most likely a botched theft. Some asshats did the same to my truck except they left a nice gash up my door and could see where they tried to pry and pop my lock off.
  16. Oct 11, 2017 at 5:08 PM
    Cement Pro
    Stock
    ^ that sucks, I really don’t think anyone tried to steal it. There’s not any tool marks or even a scratch. The part is simply missing. I have an excellent dealer that I’m sure will simply put a new one on it.
    NewImprovedRon, 040Tundra and Law323 like this.
  17. Oct 11, 2017 at 5:09 PM
    This would suck big time.
  18. Oct 11, 2017 at 5:57 PM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    It did suck initially, but thankfully the officers that handled the case were top notch and I have comprehensive coverage, so I only had to pay a couple hundred deductible out of 800-1000 IIRC. Plus they didn't get in, and I was only out my tundy for four days. Got a rental car taken care of by insurance. Doc (my wife) wanted to drive the new rental so I drove her car and let her have the rental LOL
    Happy wife happy life huh?
    All in all, it turned out just fine. Still hate dickbags that can't seem to get it in their head to get a freaking job instead of vandalizing others property.
  19. Oct 20, 2017 at 8:42 AM
    Cement Pro
    Stock
    I finally got my truck in to the dealership and had the handle replaced. I was told a bracket was defective. I incurred no charges.
  20. Oct 20, 2017 at 10:39 AM
    SullyMoto19
    SullyMoto19 New Member
    Tyler
    Houston, Texas
    2017 Magnetic Gray SR5 5.7 4X4
    8" ReadyLift w/ ReadyLift and Bilstein Adjustable Coilovers w/ Reservoirs, 3" PA Body Lift, Fox 2.0 Shocks, 24x14 RBP Atomics (custom powdercoat Gloss Black), 40x15.5r24 RBP Repulsor, Relentless Fabrication Stealth bumper, N-Fab side steps, Bedlined/Paintmatched Honeycomb Grill, 2019 LED Headlights, 4 Backlit RBG Cubes, 16 RGB PlashLight Rocklights, 5% Tint & Brow, 2 10" Kicker CVT Subs with Kicker Amp in custom sealed box, Husky all weather floor mats, LED White interior bulbs
    I had someone break a key off in my door..... cost $250 for a new cylinder.. no including the 3 weeks later where someone smashed my window.. haha so I feel your pain
  21. Oct 20, 2017 at 10:40 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    THAT is a pain!!
    some people are just general asshats!
  22. Oct 20, 2017 at 10:42 AM
    SullyMoto19
    Tyler
    Houston, Texas
    Good thing they stole my gun, cause I would've used every bullet! :frusty:
  23. Oct 20, 2017 at 10:49 AM
    Law323
    Law
    Baton Rouge, La
    2012 4.6 L MGM DC
    that's even worse! Man, it's one thing to vandalize someone else's truck, but i'd be livid if they stole my gun!
    SullyMoto19[QUOTED] likes this.
  24. Oct 20, 2017 at 11:11 AM
    kenomouth64
    kenomouth64 New Member
    Tetrus
    2007 Toyota Tundra Sr5 4x4 (TRD Off Road) Crewmax 5.7L
    Hold the Line! If you are not holding the line, abandon your ship. Destruction is inevitable without more to hold the line!
    Never seen it break unless someone was trying to break into the truck. Most likely you just got some bad plastic. I would rather have bad plastic than bad rubber.;)
