Has anyone needed aftermarket UCAs to get a good alignment with a 1.5" lift?
Discussion in '1st Gen Tundras (2000-2006)' started by nickrick78, Jan 25, 2023.
  1. Jan 25, 2023 at 11:50 AM
    nickrick78
    nickrick78 [OP] New Member
    Nick
    Pittsburgh PA
    2004 DC
    2004 DC 4x4.
    Looking at 4600s with Dobinsons springs and an Icon AAL. Should lift about 1.25-1.5" all around.
    Has anyone done this and needed aftermarket UCAs to get a good alignment?
    Planning on running 265/70/17.
    Thanks!
  2. Jan 25, 2023 at 11:53 AM
    SAGE63
    San Diego County
    no way.. not until approaching 3"....then again you are talking 1st gen... so.... my 2.5 gen not in the same ballpark
    nickrick78[OP] likes this.
  3. Jan 25, 2023 at 12:01 PM
    memario1214
    Colton
    Missoula, MT
    '21 Limited MGM CrewMax
    You should be just fine with stock UCAs on 1.5" of front lift.
  4. Jan 25, 2023 at 12:41 PM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Why 4600s instead of 5100s?
  5. Jan 25, 2023 at 12:48 PM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    I don't want to go higher than 1.5", the only benefit to 5100s is ability to go higher. Keeping these truck mods mild.
  6. Jan 25, 2023 at 12:59 PM
    Elevatorguy
    James
    I didn’t know you can run any lift spring on the 4600. Aren’t the 5100s longer?
  7. Jan 25, 2023 at 1:01 PM
    Elevatorguy
    James
    Also I’m running that size tire at stock height. Hoping to go to 285s soon with dobinsons and 5100s.
  8. Jan 25, 2023 at 1:02 PM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    1stgenoffroad.com says I can run a Dobinsons c59-300 and it will achieve a 1.5" lift. The only benefit to 5100s is the ability to go higher.
    4600s and 5100s are identical inside.
    I am at stock height right now with the 265/70/17, staying at this size tire. Just want a better ride, appearance, and performance than the Monroes that are on it.
    Elevatorguy[QUOTED] likes this.
  9. Jan 25, 2023 at 1:07 PM
    bmf4069
    Beau
    TX
    02 AC sr5 4wd v8
  10. Jan 26, 2023 at 10:58 AM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    Thanks guys
  11. Jan 28, 2023 at 9:00 AM
    kieljon
    kieljon New Member
    Southeast US
    2005 Double cab 4x4 TRD
    This sounds like what I might want to do to my truck. I don't want the hassle of 3"+. But I'd love a little more leveled look.
    Didn't realize the 4600s were the same as 5100s. What's the total cost you're looking at?
  12. Jan 28, 2023 at 11:02 AM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    1stgenoffroad.com
  13. Jan 28, 2023 at 11:03 AM
    kieljon
    kieljon New Member
    Southeast US
    Thank you!
  14. Jan 28, 2023 at 11:53 AM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    Update, I misread the response from 1stgenoffroad.
    They said for a double cab 4x4 it'll be 1.25-1.5" lift roughly. So might not exactly be 1.5"
    kieljon likes this.
  15. Jan 28, 2023 at 2:41 PM
    shifty` All my rowdy friends have settled down
    That lift may potentially leave a double cab with about 1" of rake in the rear, beyond the stock rake.
    I'll be really interested to see pics once complete and things settled.
  16. Jan 28, 2023 at 3:45 PM
    kieljon
    kieljon New Member
    Southeast US
    As in, 1" more rake?
  17. Jan 28, 2023 at 4:18 PM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    You definitely have a point.
    In fact, I'm second guessing doing the AAL. I am contemplating doing everything else and seeing where the front ride height lands.
    But I do want some rake (rear higher than front), and I just discovered ATS springs and General springs, so I may skip the AAL and get new HD springs from one of them.
    shifty`[QUOTED] likes this.
  18. Jan 28, 2023 at 8:27 PM
    Yes.
    Consider any rake you have now. Add that setup. You may very well land with 1/2" to 1" more rake after the fact.
    Some people love rake. I know I do - when I see a perfectly level truck, it almost looks like the ass-end is squatting to me. It looks "off" to me. Trucks are meant to have at least a little rake, the fender-wheel gap should always be lesser in the front than the rear IMO.
    But you do you. Everyone has their taste. I know guys who prefer totally level, some who like a little squat, and others who prefer rake. It's a personal preference.
  19. Jan 30, 2023 at 11:39 AM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    I just got confirmation from ATS that their HD springs fit the AC and DC. So I'll probably go that route, for a couple hundred bucks more I'll get new leaf packs.
    Quote from ATS
    "Once installed and settled you should expect the rear to sit about 1.5-2" taller than factory spec. These are not lift springs but due to the extra capacity of the spring it won't sag under its own weight as easily."
    Elevatorguy likes this.
  20. May 9, 2023 at 1:24 PM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    Ended up going 5100s all around with Dobinsons coils and HD leaf springs. JBA UCAs
  21. May 9, 2023 at 1:48 PM
    Pics or it didn't happen :rofl:
  22. May 9, 2023 at 2:04 PM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
  23. May 9, 2023 at 2:11 PM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    Not identical angles but gives you an idea of the before and after the 5100s/UCAs. The HD leafs were already on there
    tpope and shifty` like this.
  24. May 9, 2023 at 2:11 PM
    Awesome! Now do the headlights! :militarypress:
  25. May 9, 2023 at 3:06 PM
    nickrick78
    Nick
    Pittsburgh PA
    2004 DC
    Next is tires. Thinking LT255/80/17E Toyo Open Country ATIII.
    Right now I have P265/70/17 Coopers.
