Has anyone had a long cranktime on your tundra?
Discussion in 'General Tundra Discussion' started by Daflynkauaian, Feb 2, 2024.
  1. Feb 2, 2024 at 7:34 AM
    Daflynkauaian
    Daflynkauaian [OP] New Member
    Edward P
    2017 Tundra
    Has anyone had a problem with long cranktime before engine turns over and starts? I may have the answer
    koditten likes this.
  2. Feb 2, 2024 at 7:47 AM
    koditten
    Kirk
    Midland of the Mitten
    Only when the emmobilizer gets pissy.
    Remove the key and insert it back in, the opposite position and it starts right up.
  3. Feb 2, 2024 at 7:48 AM
    People with FF trucks and incorrect ALC% stored in the computer do. There’s a TSB for that.
    Daflynkauaian[OP] likes this.
  4. Feb 2, 2024 at 7:56 AM
    Daflynkauaian
    Edward P
    2017 Tundra
    Correct, im sitting at a toyo dlr waiting for them to flash my ecu to recalculate the ALC for a flex fuel vehicle.
  5. Feb 7, 2024 at 8:53 PM
    WrongwayUp
    WrongwayUp New Member
    Andrei
    working on them.
    how much did they charge for that?
  6. Feb 7, 2024 at 8:54 PM
    WrongwayUp
    Andrei
    working on them.
    I'm having the same issue... need to replace the fuel pump...
  7. Feb 8, 2024 at 7:15 AM
    Daflynkauaian
    Edward P
    2017 Tundra
    What year is your tundra?, reflashing of the ECM on 2009 thru 2019 is a must. There is a TSB out on this issue
  8. Feb 8, 2024 at 7:17 AM
    Daflynkauaian
    Edward P
    2017 Tundra
    I did the reflash and now its going into a fuel pimp replacement. Not necessary need a replacement if the reflash takes, if not a pump replacement and reflash together is due. This is about $1500 to complete by toyota.
  9. Feb 8, 2024 at 7:18 AM
    Daflynkauaian
    Edward P
    2017 Tundra
    A diagnostic is about $99 and just a reflash of the ecm is about $172
  10. Feb 8, 2024 at 7:20 AM
    AZBoatHauler
    So.Arizona
    I’ve been doing this on my own with Techstream the last couple years. Free.99 once you have the software and cable.
