Has anyone ever actually solved a 2714 code?
Discussion in '2.5 Gen Tundras (2014-2021)' started by ToyotaTundraMike, Jun 3, 2024.
  1. Jun 3, 2024 at 9:28 AM
    ToyotaTundraMike
    ToyotaTundraMike [OP] Not A New Member
    2015 Tundra
    2015 Tundra 4.6L 169k miles. P2714 and P0761 codes popped up a few weeks ago.
    Sat at a transmission shop for 2 weeks before they recommended rebuilding ($6500) the transmission. Pretty sure they didn't do a thing besides look up the codes and the mileage and make a recommendation based on that.
    Has anyone got these codes before and solved it by replacing solenoids etc? The debate between finding a used transmission vs finding a good deal on a 2021 5.7L is starting to heat up.
  2. Jun 3, 2024 at 9:35 AM
    Tyman
    Tyman Isaiah 41:10
    Tyler
    Indiana
    2020 Tundra Sport 4wd MGM
    I’d get a second opinion for 6,500. What’s your trans doing?
  3. Jun 3, 2024 at 9:52 AM
  4. Jun 3, 2024 at 10:09 AM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    In general those codes don’t indicate what they seem to indicate, aka that there’s something wrong with the solenoids. What it usually means is that one or more of your clutch packs are slipping and or torque converter resulting in those error codes (from the ecu not liking the input/output shaft speed and other symptoms). Overall it likely means you would need to rebuild the transmission via replacement of whatever clutch packs are having an issue. Few places want to touch these transmissions, even toyota just replaces them in the dealership and won’t open it. Very few companies will actually rebuild them. I would recommend either finding a junkyard transmission or sending to IPT for a rebuild or selling for a 5.7 as long as you don’t lose your shirt with the error codes.
    ToyotaTundraMike[OP] likes this.
  5. Jun 3, 2024 at 10:16 AM
