Has Anyone Added An Electric Fan?
Discussion in 'General Tundra Discussion' started by trdprobped17, Aug 16, 2018.
  1. Aug 16, 2018 at 6:46 PM
    trdprobped17
    trdprobped17 [OP] New Member
    Hi All, has anyone added an electric fan to their Tundra? I’m thinking of adding one to the front of my radiator and am eager to know if any here has done so as well. Thanks.
  2. Aug 16, 2018 at 6:49 PM
    For additional condenser cooling to improve AC function?
  3. Aug 16, 2018 at 6:51 PM
    trdprobped17
    Was thinking that an electric radiator fan would provide much more cooling to the radiator and coolant, etc.
  4. Aug 16, 2018 at 6:51 PM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    What r u trying to achieve?
  5. Aug 16, 2018 at 6:54 PM
    trdprobped17
    I want to add more cooling to the radiator and transmission cooler, for better performance.
  6. Aug 16, 2018 at 6:57 PM
    nk1794
    San Jose, CA
    I see. Another option, more expensive but it’d look really cool is to swap out the radiator with a high performance after market one.
  7. Aug 16, 2018 at 6:59 PM
    Well you will need a SPAL pusher fan that can be mounted as close to the radiator as possible, which might be troublesome with what’s in from of the radiator.
    Personally, I would cool the AC condenser. You might be surprised how much relief this gives to your cooling system. Much easier to mount and wire up.
    Are you having problems now?
    Your trans cooler isn’t even functioning until 240* if I remember right, unless you have the thermostat pinned open.
    nk1794 and trdprobped17[OP] like this.
  8. Aug 16, 2018 at 7:06 PM
    trdprobped17
    I am thinking of doing that as well. Also thinking of getting rid of the belt driven factory fan and replacing it with a new high performance radiator with electric fan attached to it.
    nk1794[QUOTED] likes this.
  9. Aug 16, 2018 at 7:08 PM
    14burrito
    14burrito IG @14burrito
    2014 SR5 CM 4x4 5.7
  10. Aug 16, 2018 at 7:09 PM
    trdprobped17
    That’s an interesting option. I’m not having any problems whatsoever with my truck or cooling. Have been reading a lot of forums and other stuff and I kept seeing chatter about upgrading the tindra’s cooling system for better performance.
  11. Aug 16, 2018 at 7:10 PM
    trdprobped17
    Will do. Thanks.
  12. Aug 16, 2018 at 7:10 PM
    14burrito
    2014 SR5 CM 4x4 5.7
    Pretty sure he has done a few
  13. Aug 16, 2018 at 7:13 PM
    News to me. I was always really impressed with all the cooling the Tundra offered and how well it worked.
    I towed pretty hard with mine, high elevation, high heat, and never questioned the power steering cooler, trans cooler, engine cooler ever.
    Do you have some links to what you have read?
  14. Aug 16, 2018 at 7:16 PM
    trdprobped17
    I totally agree with you. That’s why I’m asking for everyone’s opinion regarding this modification.
  15. Aug 16, 2018 at 7:17 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    I have a buddy with a taco who did exactly what you are asking. He removed the stock belt driven fan and replaced with the a dual high flow fan. He said he noticed a considerable difference. I know it was a royal pain in the rear to do and it’s not a cheap project. If you do this please post up a build on it. I would love to see this done.
  16. Aug 16, 2018 at 7:22 PM
    trdprobped17
    Cool. That’s what I have been reading about online. Many of the people who have done that type of mod, swears that their trucks runs much better and faster.
  17. Aug 16, 2018 at 7:23 PM
    I removed the mechanical clutch fan from my Jeep on my last build.
    Every time I take it out I want of get out, kick my own ass, punch myself in the cocksucker, squeeze my balls until they look like a sea wart.
    I miss my reliability, simple function of my factory fan.
  18. Aug 16, 2018 at 7:24 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I can see how possibly prolonged rock crawling on long grades uphill in low range, southwestern desert, summertime the electric fan could be a real advantage.
    trdprobped17[OP] likes this.
  19. Aug 16, 2018 at 7:25 PM
    trdprobped17
    :rofl::rofl::rofl:
    ColoradoTJ[QUOTED] and 1UPPER like this.
  20. Aug 16, 2018 at 7:27 PM
    1UPPER
    TEXAS
    Flux capacitor!
    I’m sure there are some other people who have done this. I remember him having his fan on a switch with a relay. If it’s not a big increase of power versus the money, I wouldn’t do it.
  21. Aug 16, 2018 at 7:27 PM
  22. Aug 16, 2018 at 7:34 PM
    Grumpy Uncle
    Pat
    CO
    So, you're saying you didn't like it?:D
  23. Aug 16, 2018 at 7:41 PM
    the_midwesterner
    the_midwesterner New Member
    Luis
    None, yet....
    Mechanical fans have actually been measured to move more air. I HIGHLY recommend you don’t put an electric fan in front of the radiator while running the mechanical fan. The key to cooling is flow, putting an electric fan in front of the radiator is creating turbulent air for the mechanical fan to pull. Turbulent air being pulled by a turbulent source reduces overall flow. The key to an electric fan is to build an airtight shroud. Forcing the air to have to move through the radiator vs going through other areas or leaking through seams is what reduces efficiency.
    Can I ask what issues you are having that’s making you want to consider this? There is a ton of R&D that goes into ensuring the cooling system can keep up to the load.
  24. Aug 16, 2018 at 7:51 PM
    Tierhog
    Tierhog SIG-AHOLIC
    2016 Tundra Crewmax Limited 4WD
    Mostly stock/TRD accessories/Morimoto XBs
  25. Aug 16, 2018 at 8:08 PM
    trdprobped17
    Very interesting information...I never knew that by placing the fan in the front of the radiator, it could pose other problems. The electric fan has been a permanent staple on high performance sports cars and supercars, so, I am sure that it's advantageous to have for HP and torque. Thanks for the information.
  26. Aug 16, 2018 at 8:16 PM
    trdprobped17
    True. My thoughts are that I would have a cooler running truck, less wear and tear from the heat. As far as cost is concerned, I am not sure what it would run. The type of fan(s), size, etc., would definitely make that determination.Not even sure that I would do it, to be honest.
  27. Aug 16, 2018 at 8:39 PM
    the_midwesterner
    Luis
    None, yet....
    Technically, yes. While you gain some HP in reduction of friction and resistance from turning the fan, the amount of electrical load required to cool a radiator the size of the tundra will be significant. Which ultimately means a very minimal net gain in efficiency or power. If you do look at high end HP build, they choose the electric fan simply from a packaging stand point. Much easier to package, but a shroud is mandatory. Period.
    This seems to be a common misconception. See my message above. The overall load decrease may not be significant, while potentially creating issues. Cooling fluid is a science, more cooling is not always good. The transmission fluid in your truck is WS fluid and extremely sensitive to temp swings, in either direction. There is a million mile tundra for a reason. As mentioned, tons of R&D goes into this.
    Not saying don’t do it, but plenty of things to take into account. Also, I’m a nerd. So the devil is in the details.
  28. Aug 16, 2018 at 8:53 PM
    Oh I love it! I’m into the freaky shit.
    Yeah, I don’t like it. When I do the LS swap, I will be trying as hard as possible to install a mechanical fan and a shroud. If I have to cut firewall out, so be it.
  29. Aug 16, 2018 at 8:56 PM
    trdprobped17
    I certainly do appreciate your technical expertise in this discussion. Boy, don't I know what it is like to have cooling system issues. I had a buick many years ago and it certainly taught me a thing or two about cooling and over heating:rofl::rofl::rofl::rofl::spending::spending:I think that it is better to leave trouble alone where the radiator is concerned:rofl:
    ColoradoTJ likes this.
  30. Aug 16, 2018 at 8:57 PM
    trdprobped17
    :rofl::rofl::rofl::rofl::rofl:
