Has anyone’s warranty been voided by using a JB4?
Discussion in '3rd Gen Tundras (2022+)' started by MateoAirborne, Jan 15, 2023.
  1. Jan 15, 2023 at 8:00 AM
    MateoAirborne
    MateoAirborne [OP] New Member
    Mateo
    2023 iForce Max 1794 TRD Off Road Package
    I want to install a JB4 on my ‘23 hybrid, but I’m chicken because I’m worried about denial of any warranty work.
    Any advice, comments, suggestions, concerns?
    RickyBobbysTundra likes this.
  2. Jan 15, 2023 at 8:21 AM
    TundraWorkHorse
    TundraWorkHorse New Member
    2023 Toyota Tundra Platinum
    The JB4 will not necessarily void warranty .If there is a failure or a part that could be attributed to the aftermarket device, that warranty claim could well be denied
  3. Jan 15, 2023 at 8:34 AM
    As long as you don’t leave it connected at the dealership….
    SC4333, Mater, ryanwgregg and 3 others like this.
  4. Jan 15, 2023 at 3:00 PM
    Kap1
    Kap1 New Member
    San Francisco, CA
    I've read at other threads that dealership can run reports on their computer and see if the components of the engine were working too hard, out of spec - and therefore they will make a conclusion that you used an aftermarket device to make components work harder than they should have. And then then can deny your warranty coverage. (e.g won't replace your engine or turbos)
  5. Jan 15, 2023 at 3:26 PM
    Durtywrench
    Durtywrench New Member
    Lou
    23 Tundra platinum
    None
    An experienced mechanic that knows how to read freeze frame data can possibly figure out that a tuner has been connected when the failure occurred . I’m not certain that they’ll catch it but it definitely is possible
  6. Jan 15, 2023 at 6:31 PM
    moonrover
    moonrover New Member
    2022 Tundra SR5 TRD OR
    Assuming data is recorded when the vehicle is driven and they can access the data, they can see timing, boost, and more, they will be able to tell if you have a tuner involved in the whole process.
    Kap1, Durtywrench and AZBoatHauler like this.
  7. Jan 15, 2023 at 6:33 PM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
    Haven't heard of it happening. I've taken mine off when it's been in for service though...no need to risk it
    jeosbor1 likes this.
  8. Jan 15, 2023 at 6:49 PM
    mass-hole
    mass-hole New Member
    Except the JB4 spoofs the pcm into thinking its making less boost than it is. So as far as the pcm knows, nothing is different
  9. Jan 15, 2023 at 6:51 PM
    mass-hole
    They would have to dig really deep and somehow infer it from Fuel trims or wastegate duty cycle. The pcm doesnt know the engine is getting more boost with the jb4
  10. Jan 15, 2023 at 7:49 PM
    DeafJam
    DeafJam New Member
    Louisiana
    2023 Toyota Tundra Hybrid, 1794 edition
    Cosmetics for for a pavement princess.
    If you need to replace the engine or the transmissions, I would expect Toyota to pull controller data. There will be more than enough there to deny the warranty.
    Other forums with vehicles that the JB4 is more common on do have people bitching about denied warranties after knowingly or unknowingly trying to commit fraud. I would not expect Toyota to be any different, particularly when their reliability numbers mean they can pay more attention to serious failures.
    Coal Dragger, Kap1, raylo and 3 others like this.
  11. Jan 19, 2023 at 11:14 PM
    YOTA_IL
    YOTA_IL New Member
    I had the JB4 on my 2022 3.0 Supra, it leaves a trace of course. This isn’t the old days where you rip it off and computers don’t record that info, they do. If you use a JB4, I’d highly recommend someone tune it for you. I know certain Maps when used for Supra’s were blowing turbos, would hate to see that.
  12. Jan 20, 2023 at 1:22 AM
    SDTundra1794
    SDTundra1794 New Member
    At least not yet. I have the 1794 hybrid and feel like it have more than enough power/torque for a truck. I wouldn’t risk it for a little bit of gain, not like you can race with a half ton anyway
    YOTA_IL likes this.
  13. Jan 20, 2023 at 1:28 AM
    Coal Dragger
    Coal Dragger New Member
    Kung Fu Dick
    If you can’t afford to pay for a new engine, transmission, transfer case, or other driveline hardware out of pocket; then you can’t afford to use a tuner on your new truck. At least while under warranty.
    Pretty simple concept.
    If you need or want a more powerful, more capable truck buy one that is already more powerful and more capable. There’s a bunch of options out there for trucks that pretty thoroughly outperform the Tundra in a variety of ways if you need more power or capability. I have a tough time understanding why so many guys want to try to make their 1/2 ton Toyota Tundra into something it will never be.
    1.) The Tundra is not a race car. You could spend $5,000 on go faster parts, labor, and tuning for your Tundra and still get your dick kicked in at a stoplight by a new 5.0 Mustang GT with an automatic transmission driven by a 17 year old. All you’ve done is made your slow truck marginally less slow in the grand scheme of things.
    2.) The Tundra is not a heavy duty truck. No amount of tuners, air bags, heavier springs, or other bandaids is going to put it on par with a 3/4 ton HD gasser…. much less a diesel. Buy a bigger truck.
  14. Jan 20, 2023 at 6:04 AM
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    Those of you concerned over warranty denial should brush up your incantation and arcane knowledge skills.
    (tee hee!)
  15. Jan 20, 2023 at 6:09 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    So Toyota technicians can dig through computer data models but can’t replicate wind noise
    Toyotoholic, SC4333, DexterL and 4 others like this.
  16. Jan 20, 2023 at 6:16 AM
    Chris996
    Chris996 New Member
    2018 TRD Sport
    None
    JC, you must be a blast to hang out with.
    You must of missed that there is an entire aftermarket to enhance just about every performance aspect of almost every vehicle. Going beyond what a manufacturer deemed “enough’
    Or perhaps they just didn’t get your memo
    LarryDangerfield and Peak23 like this.
  17. Jan 20, 2023 at 9:37 AM
    Coal Dragger
    Kung Fu Dick
    LOL, I might be a bit harsh on this one.
    I’m all for modifying vehicles to maximize the core functional attributes where it makes sense. Make an already fast car faster etc.
    Pickup trucks though? Adding a few HP at the very real expense of voiding factory powertrain warranty is a juice not worth the squeeze. The reward of a slightly less slow truck isn’t worth the risk in my estimation.
  18. Jan 20, 2023 at 9:39 AM
    Coal Dragger
    Kung Fu Dick
    I’ll bet the dealer tech will not be the one digging on a warranty claim for a blown up engine or transmission.
    In the event they are the ones digging their motivation to do so might be higher because non warranty work is going to pay them more than warranty work in most cases.
  19. Jan 20, 2023 at 11:04 AM
    Chris996
    Chris996 New Member
    2018 TRD Sport
    None
    Perhaps I was too.
    I agree that modifying a car to do something it wasn't designed to do is a fool's errand. Particularly if one complains about the outcome.
    But adding a bit more hp to enhance the fun factor? Have at it.
    Is it worth voiding the warranty? That's the OP's call
  20. Jan 20, 2023 at 11:10 AM
    Coal Dragger
    Kung Fu Dick
    That’s the big problem for me, and why I leave vehicles stock under warranty.
    Plus leaving the daily driver alone aside from regular maintenance for max reliability is usually wise.
    Project car/truck or toy? Play to your heart and wallet’s content!
  21. Jan 20, 2023 at 11:47 AM
    Durtywrench
    Lou
    23 Tundra platinum
    None
    This isn’t that hard to think through . If you add tuner then also be ready if the dealer denies claim for whatever if you have modified said system . I mean if you buy an iPhone and you crack it open to modify you can’t expect it to be surprised if they deny your claim later .
    I think it would be quite easy as a Toyota engineer to prove the program has been changed . Lots of clues within one freeze frame that could indicate tampering . Boost value ain’t the only one but you could get lucky and get the tech that don’t care
  22. Jan 20, 2023 at 12:59 PM
    Hadelson
    Hadelson New Member
    Allentown - Pennsylvania
    23 Tundra TRD Pro. Fun Ride 2019 RS3 Roush SC Mustang
    My 17 4Runner had a complete brake system failure while I was driving. On local road at 30 MPH. Coming up to Stop sign-Brake pedal goes to the floor and no stop. Pucker factor immediately maxed out. Started pumping the pedal for very marginal brakes and applied E-brake. Got it stopped middle of 4 point intersection and fortunate no car in front of me or at the other points. Anytime you applied brakes, the pedal went to the floor. Toyota picked it up on a flatbed and took it dealer. Brakes were completely out when we rolled it into the bay. Tech shut it down, hooked it up to the diagnostic and behold, now brakes fully functional. Toyota after a full diagnostic told me could not replicate and wanted me to pick up and drive it. I refused. Took about a month and finally the region senior tech arrives with computer. We drove the truck for 50 miles on the interstate, local roads, in 4x4 and brakes worked fine. I dug in and told them I am not taking the truck back and figure out what happened. At this point, they pull it back into the service bay and sync the truck OBD with some mainframe location and complete a full dump of stored data. They then asked me date and time of incident. They found it and it showed complete brake loss and the brake pumping by me within some deep records stored within the OBD system. Very politely told them--your initially denied the event occurred. Imagine me driving this and being behind you or a family member when it happened again. Fix the problem and not band aide it or your next correspondence from me would be via my legal counsel. The brake system and all components were replaced. Anyone doubt this, go over to the 4Runner site and its fully documented there when it happened.
    So the long answer to your short question, yes then can find a lot via OBD Computer records.
  23. Jan 20, 2023 at 1:47 PM
    osu1978
    osu1978 New Member
    Wow, that is nuts.
  24. Jan 20, 2023 at 8:08 PM
    moonrover
    Crazy, glad you and others on the road were ok.
  25. Jan 20, 2023 at 10:37 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    You would be amazed at the data we can pull up with Techstream in these newer trucks. The computer logs many things, harsh acceleration, shifting too fast from reverse to drive, abs operation, etc.
    With that being said if somethings spoofing the computer to think a value is reading less than it really is, I dont think we’d pick that up directly, but through all the other PIDS the guys in Texas we send the files to on warranty jobs could likely pickup “something third party is messing with something”
  26. Jan 20, 2023 at 10:46 PM
    mass-hole
    Exactly. Like via harsh acceleration maybe. Or wastegate duty cycle, or something else.
    Youd have to know what ur looking for though
  27. Jan 20, 2023 at 10:50 PM
    empty_lord
    05 rollover special
    Especially with them being new new, any engine or transmission failure will most likely require a TAS case. If it does they’ll want Techstream data and Texas will go over it all with a fine tooth comb
  28. Jan 22, 2023 at 3:50 AM
    RickyBobbysTundra
    RickyBobbysTundra New Member
    Phoenix
    2023 Solar Octane TRD Pro
    Terrifying. But good on you for sticking to your guns. Solid reminder that safety puts us in a position to demand techs to do their jobs, regardless of what they say.
