Harrop Supercharger regear?
Discussion in 'Performance and Tuning' started by Gungho, Jul 31, 2023.
  1. Jul 31, 2023 at 10:33 AM
    Gungho
    Gungho [OP] New Member
    Michael
    2019 Tundra TRD Pro
    Hello,
    i have a 2019 tundra trd pro with the harrop supercharger with d3 tuning and smaller pulley. I also switched to 35 inch tires but liked the stock trd pro wheel so went with nitto ridge grappler 35x12.50R18LT F 128Q.
    i was wondering if i should do a rear locker and do a regear. If so then what gear should i get. What would the benefits be?
    Leo's first likes this.
  2. Jul 31, 2023 at 4:52 PM
    Mdl
    Mdl Hey there...
    PNW, WA
    2007 TRD SC'd
    JBA Longtubes, Snivs 2.0 SC pulley, ASP crank overdrive pulley 6.71 in, DD Full 3inch dual exhaust, IPT valve body, Airbox mod, 4.5inch intake, Denso 750, 450 Walbro, W/M injection, GM 95mm TB, SABM, Camburg UCA, Icon shocks, Speedmaster LSD, Motive 5.29 Gears, Mickey Thompson Baja Legend EXP 35's, Solid Offroad engine and transmission mounts, DIY Traction Bars, Tuning by Snivspeedshop.com
    Most would say Powertrax ls for the rear with 5.29. I'm running 35's with stock 4.30's magnuson and don't notice any issues.
    2mchfun, Gungho[OP], reywcms and 2 others like this.
  3. Jul 31, 2023 at 5:42 PM
    Silver17
    Northeast
    2017 TRD 4x4 Harrop SC
    I have a powertrax with stock gears and 34s and basically the same blower setup. I didn’t feel the expense for the gears was worth it with the blower, but if you got the cash it’s not a bad idea while you’re getting the powertrax installed. I’d have done it if the expense was half the price. The powertrax is must have for these trucks in my opinion though!
    Mdl, snivilous and reywcms like this.
  4. Jul 31, 2023 at 7:39 PM
    reywcms
    reywcms New Member
    Rey
    North Plains,Oregon
    2017 Tundra Platnium
    Too many mods to come
    I think 5.29s and blower is too much gear. You don’t take advantage of the tq the blower makes. 4.88s on a whipple and smaller pulley and it does well on the old man’s rig. My truck has stock gears
  5. Jul 31, 2023 at 8:18 PM
    snivilous
    snivilous snivspeedshop.com
    SW UT
    300k+ Supercharged 2008
    Rey is wrong :D 5.29s fuck. Gearing felt like as much of a change as adding a stock blower. Absolutely zero issues, though over 100mph it starts to lose steam but it'll keep on pulling past 120.
  6. Aug 3, 2023 at 8:06 PM
    Gungho
    Michael
    2019 Tundra TRD Pro
    What made you get power trax instead of harrop elocker?
  7. Aug 4, 2023 at 1:55 AM
    Silver17
    Northeast
    The powertrax is better suited for how I use my truck. It sees a lot more time on road than off. I like that the powertrax is always there at play working to keep traction and I don’t have to remember to push a button. It’s also safer in the rain and snow than an engaged locker. Offroad wise it has also made the truck more capable than I even need I would say. Also, it’s more affordable than a locker and no wiring is involved. If it was a dedicated low speed trail rig I’d prefer a locker for that.
  8. Aug 4, 2023 at 3:13 AM
    Elevatorguy
    Elevatorguy Yotas and JD Green!
    James
    05 DC, 4.7, 4wd, LSD.
    Beautiful truck, Love the voodoo.
    Gungho[OP] likes this.
  9. Aug 4, 2023 at 7:09 AM
    1UP
    1UP Truck Gang
    2019 Red CM TRD sport 4x4
    https://www.powertrax.com/traction-...t_modelandsubmodel=tundra&crt_enginesize=5.7l
    Which of those did you purchase? The limited slip or locker?
  10. Aug 4, 2023 at 7:19 AM
    Silver17
    Northeast
    Saltyhero13, 1UP[QUOTED] and reywcms like this.
  11. Aug 4, 2023 at 11:49 AM
    Saltyhero13
    Saltyhero13 Throbbing Member
    ARB makes an air locker, can't remember who makes the e-locker/magnetic locker at the moment. Powertrax makes a torsen gear LSD. There is another torsen LSD (Speed something?) but I forget the name. There is also a clutch LSD (Auburn) but may prematurely wear on SCed trucks.
    1UP[QUOTED] likes this.
  12. Aug 10, 2023 at 3:36 PM
    Gungho
    Michael
    2019 Tundra TRD Pro
    Dang gears cost 1000$ while powertrax lsd is on 659$. I can decide should i just get the lsd? Whats the cost of installation?
  13. Aug 10, 2023 at 6:48 PM
    1UP
    1UP Truck Gang
    I'd get the LSD and pick up traction bars. If that doesn't do the trick, add gears.
  14. Aug 11, 2023 at 7:08 AM
    snivilous
    SW UT
    The LSD install should cost the same regardless if you get gears since the entire differential carrier is replaced so it's effectively a fresh install with used gears if you don't replace them.
    Flip side is you have to do the front differential gears which is generally more expensive labor wise than the rear, but that is ultimately where you're saving money.
  15. Aug 11, 2023 at 9:25 PM
    Chad D.
    Chad D. New Member
    Western Oregon
    2018 CrewMax Platinum
    I had my gears and LSD installed about 18 months ago. I believe my labor cost was $1,600 all together.
    I supplied the gears and differential.
    Gungho[OP] and 1UP like this.
  16. Oct 26, 2024 at 9:14 PM
    gjb777
    gjb777 New Member
    Gabriel
    08 Sequoia Big Blue
    Custom paint, wheels, icon suspension, JBA uppers, Katzkin interior, rigid lighting, Kicker System
    Hey boss, I’m on 5.29’s currently, and blower going on soon! You running anything besides the Harrop & smaller pulley? Fuel rails, injectors, or intake bits?
