Harrop Stage 2 Pulley Tensioner Failure
Discussion in 'Performance and Tuning' started by kong24680, Apr 24, 2025.
  1. Apr 24, 2025 at 10:51 PM
    kong24680
    kong24680 [OP] New Member
    I’ve got a 2021 LX570 with a Harrop TVS2650 kit, 650cc injectors, 80mm Harrop pulley, 84mm RCF throttle body, and a custom Yotawerx tune. When the shop finished install of the kit and tuning, the tensioner pulley failed when they were doing some testing. At the time I didn’t think much of it, but after about 700 miles driving on the setup the belt snapped and pulley tensioner failed again. It did fail during a wide open throttle pull in higher RPM. I’m running the Gates K081177 belt provided by Harrop that’s supposed to be compatible with the smaller 80mm pulley.
    Have any of you experienced something like this or would know what could be the source of the issue? I did some digging online and haven’t seen anything about tensioner/belt failures on a similar setup. Any help is greatly appreciated!
  2. Apr 24, 2025 at 11:17 PM
    Ponderosa_Pine
    Ponderosa_Pine
    Northwest
    2021 Tundra DC, 2022 4R, 2007 FJ
    Magnuson Supercharged, Dobinson Lift, 315/70r17 on Rockwarriors, Heftyfab bumper, Dirty Deeds 3” race exhaust
    I have the magnuson 1900. I put on a smaller pulley (used same belt), waited a year then put on a tighter belt. After 1000 miles at least one idler pulley was destroyed (loud whine). Seems related to me that these tighter belts tend to destroy the bearings and or tensioners. I went back to the regular sized belt and have had no issues/no boost loss.
    HulkSmurf14 and Mdl like this.
  3. Apr 25, 2025 at 6:01 AM
    armyoffoo
    armyoffoo Member
    Cypress, TX
    2018 Black TRD Sport CrewMax
    Supercharged with all the trimmings
    Harrop provides 2 idler pulleys (one on water cross-over pipe, and one on a dedicated bracket), the tensioner is stock Toyota. I have just replaced my idler pulleys after 4.5 years because they weren't spinning freely.
    HulkSmurf14 likes this.
  4. Apr 25, 2025 at 7:56 PM
    kong24680
    Unfortunately for me, these failures all occurred with the Harrop supplied Gates K081177 belt. I called both Harrop and Prospeed asking if they’ve seen tensioner/belt failures and neither of them have seen failures like the one I am experiencing. They also both confirmed that I should stick to the supplied belt. Leads me to believe the failures are caused by something else… still having my shop diagnose
