Hard to start 2001 4.7 engine
Discussion in '1st Gen Tundras (2000-2006)' started by Gray Hunter, Apr 7, 2021.
  1. Apr 7, 2021 at 4:47 PM
    Gray Hunter
    Gray Hunter [OP] New Member
    2001 Tundra TRD 4x4 Sr5
    If outside temperature is above 75 degrees, engine will turn over but not crank. Cleaned throttle body, map sensor. Checked cam sensor and replaced engine coolant sensor. When it does start it will sometimes puff out black smoke from tail pipe. Does this sound like ECU problem? This is direction about to go down, plugs wires, fuel rail pressure is good. I know this sounds like a weird issue. Thanks in advance for any advice with this.
    YardBird likes this.
  2. Apr 7, 2021 at 5:07 PM
    Black smoke would be fuel? How many miles? how are the injectors?
  3. Apr 7, 2021 at 5:11 PM
    YardBird
    YardBird Native San Diegan
    Jonesy
    2005 RCLB
  4. Apr 7, 2021 at 5:13 PM
    MS22
    MS22 New Member
    02 Tundra 4x4
    Bad or low batteries can cause some wonky symptoms.
  5. Apr 7, 2021 at 5:23 PM
    Gray Hunter
    The battery is new. Thank you for the welcome! Truck has about 277,000 miles on it now, I got it with 155,000. I had all service done, fluids, timing belt, tune up, rebuilt trans and replaced rear end. I do not think anything has been done to injectors.
  6. Apr 8, 2021 at 4:37 AM
    Professional Hand Model
    Hand Protectors
    We had a member with about 160k miles on his 4.7L do a professional test and cleaning of his injectors. 6 out of 8 were dripping out of Spec.
    I’ve installed Reman’d 12Port Injectors on mine. Highly recco if thats your problem.
    Voss likes this.
  7. Apr 8, 2021 at 5:37 AM
    SouthPaw
    SouthPaw The headlight guy
    2000 Limited 4x4 AC
    When’s the last time the fuel filter was changed?
    Voss likes this.
  8. Apr 8, 2021 at 12:37 PM
    Gray Hunter
    Thanks for the feed back on this issue. Fuel filter is less than 6 months old. We are going to pull the fuel rails and see if the injectors are leaking. Ready to find the cure for this issue, running out of things to check and replace. The truck is sound and runs great except for this issue.
  9. Apr 12, 2021 at 8:36 AM
    peanut
    peanut making uneconomical choices about my truck
    2001 Tundra 4x4 V8 Access cab 222k miles
    Did you check for vacuum leaks everywhere?
    Voss likes this.
  10. Apr 24, 2021 at 5:25 PM
    Gray Hunter
    Recap, new battery, fuel filter, cam shaft sensor, coolant sensor, map & throttle body cleaned, new injectors.....still hard to start when hot outside. Going to replace the coils, to see if that helps. I read the starter relay may cause this problem? About to buy a new truck, dumping money in old truck and not correcting issue. Does anyone have something else to check or change? Thanks for help on this.
    Voss likes this.
  11. Apr 24, 2021 at 5:46 PM
    Voss
    Voss Not a new member
    2003 AC TRD 4x4
    At this point I would take it to a dealer and let them find the issue. Shouldn’t cost you much if anything at all for them to find the issue. Once you know what the issue is, see if you can fix on your own. Best of luck to to bud. With only 277k miles, feel like your issue should be fixable.
    report back so we know what to consider in the future.
  12. Jun 3, 2021 at 3:11 PM
    Gray Hunter
    Turns out the battery was the issue. We finally started testing battery and found it to be the problem. New battery put in and truck starts up like a new truck. Leaving all the parts on as it is running without any issues. Thanks for all who helped with this issue, should be good for another 100k or more.
    torino69, bmf4069, SouthPaw and 3 others like this.
  13. Jun 3, 2021 at 3:13 PM
    Hand Protectors
    AKA New ‘bad’ battery. Seems common these days.
    Voss likes this.
