Hard to control on bad roads after rebuilding front end
Discussion in '1st Gen Tundras (2000-2006)' started by Konniekay91, Dec 27, 2021.
  1. Dec 27, 2021 at 7:42 PM
    Konniekay91
    Konniekay91 [OP] New Member
    Konrad
    2006 Toyota Tundra SR5 Doublecab
    I just rebuilt the front end of my 2006 Gen 1 sr5 DC(not leveled) struts are Bilstein 4600, inner/outer tie rods/ sway linkages, control arms, ball joints and bearings are all still A-OK and I noticed that, in spec, the alignment shows a pretty positive camber in the front. I have it set to .5 or so, and when I look the truck dead on, the positive camber is pretty severe. Now, I don't have any irregular tire wear or anything, I run my pressures 32 front/ 32 Rear and I run a slightly oversized p265/70r17 Cooper AT3 4s. In Tucson a lot of the roads are pretty jacked up, and the truck just throws the wheel left and right. Its hard to control. I'm going to redo the alignment again after the first 500 miles of the parts settling in.
    Any clues as to what it could be? Should I tinker with the alignment? Lower my air pressures?
    (Come to think of it, I also have a left front caliper that's starting to seize up sometimes. And that's next on the list)
  2. Dec 28, 2021 at 8:45 AM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Was it doing this before all of the front end work?
  3. Dec 28, 2021 at 9:11 AM
    Konniekay91
    Konrad
    A little less than it does now. The play and noise on the front end is gone though. So that's a plus I suppose.
  4. Dec 28, 2021 at 9:41 AM
    rock climber
    So, alignment sounds like a part of it, but there's probably more. Do you have your current alignment numbers?
    Also, I'd take a look at the steering rack bushings. Replacing them made a huge difference for me.
  5. Dec 28, 2021 at 9:48 AM
    Konniekay91
    Konrad
    I don't. I was using up the last couple of hours of my shop being open on my day off to do all of the work. I did the alignment quickly and as straight as I can get it before I close the doors. But I know that adjusting it will help.
    But I haven't thought of doing the rack bushings. Good call!
  6. Dec 28, 2021 at 9:52 AM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    I'm confused by this part, were all of those parts replaced?
    If you didn't replace the coils then there is nothing to settle and no reason to wait on getting alignment corrected (assuming all of the above was replaced). You may have caster on the low end. If your camber is that bad you may have got a "toe and go" alignment job where as long as the truck drives straight they think the job is done. I would take it elsewhere.
    Edit
    If you only adjusted the tie rods then a lot of the trouble might be in the camber and caster. I install all my parts but alignment is black magic to me, I take my truck to a good shop for that sort of voodoo.
  7. Dec 28, 2021 at 9:56 AM
    It sounds like there was no real alignment job done. Take it to an alignment shop and have it done properly. Also recheck all of your replacement work to make sure it’s all torqued and seated properly. Should be done with the vehicle weight on the ground, not while it’s on Jacks
    Voss and snivilous like this.
  8. Dec 28, 2021 at 10:13 AM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    It is your alignment, need a real alignment when messing with that stuff up front. Go to a trusted alignment shop, not the dealer or a quick in and out auto shop, they often just set the toe and move on.
    Tundra2, snivilous and Aerindel like this.
  9. Dec 28, 2021 at 3:07 PM
    assassin10000
    assassin10000 New Member
    Andrew
    Northern CA
    '05 SR5 AC
    0 to -0.3 camber
    +2.4 to +3.0 caster
    .08 to .20 total toe in
    dinosaur and Darkness like this.
  10. Jan 1, 2022 at 8:30 AM
    Konniekay91
    Konrad
    So I went underneath, and reassessed all the bushing and everything was intact and no splitting or play, once I hooked it up, the alignment fell in. What I mean by that is that when I initially set it in after installation, all was green and strain .05 toe and .05 camber. Dead set.
    After 600 miles I measured it again and I had a severe toe in of .63 degrees on either side which would explain any erratic steering. It took a few turns of the tie rod. Now it's all smooth as butter. What made me check it was the camber and odd tire wear. Sometimes you'll run into new parts working themselves in, and as a shop we typically recommend a recheck after the first 500 miles for initial break in.
    Long and short of it is, It was the alignment, and all is well.
  11. Jan 6, 2022 at 7:53 AM
    T2ndLife
    T2ndLife New Member
    JD
    '02 4.7L 225K 4WD Ext Cab
    WIP - keeping stock Kenwood DNX9960 GPS Nav/Stereo NexD XD400/4 400W Amp Wood Trim package added 4Runner alloy 17 inch wheels
    @Konniekay91 Other than the Bilsteins, what brand did you use on the other components? Looking to do the same... Anyone else have any preferences? Mevotech, Delphi, TRQ, Moog, etc?
