Firmer shifts after pan drain and fill
Discussion in '2nd Gen Tundras (2007-2013)' started by 1rooster, Mar 10, 2020.
  1. Jul 21, 2020 at 6:51 PM
    #121
    1rooster
    1rooster [OP] New Member
    Tony
    2007 crewmax
    Just an update . It’s been about 6,000 miles and it feels the same. Maybe the “firm”shift was nothing to worry about after all
  2. Jul 26, 2020 at 9:40 AM
    #122
    bleach
    bleach MEME Fiend
    DJ
    Battle Ground, WA
    1991 White Xtra-cab SR5 4X4 V6 5 speed 148K
    I have a little over 137K on my 2007 and after reading all this I don't think I want to mess with my fluid. I don't know the driving habits of the first owner but the 2nd owners were an older couple. Mine shifts really nice. The only issue it has it has a slight lag moving in reverse after it siits for more than a week.
  3. Jul 26, 2020 at 9:58 AM
    #123
    1rooster
    Tony
    2007 crewmax
    Personally I think if you go ahead and drop the pan the first time you will be 100% okay. It really wasn’t that hard and the seal is reusable.
    Last week I pulled a 6k trailer on a 250 mile round trip flawlessly. Tow mode on and in 4th worked great.
  4. Feb 17, 2021 at 2:40 PM
    #124
    1rooster
    Tony
    2007 crewmax
    Just an update. It has been 11k miles since my valve body issues and have had no changes or issues. I have mostly done mostly in town driving and also some moderate heavy towing. Still going strong !FCE44C1C-37A3-498B-A753-225A834C5ACE.jpg
    RJVA and MTRock like this.
  5. Oct 28, 2021 at 5:40 AM
    #125
    mnm567
    mnm567 New Member
    Matthew
    2013 Toyota Tundra Rock Warrior
    Thanks for the update! I found this thread late. Often times people don’t give updates.
    I changed my fluid by flushing the system. I detached a cooler line and over filled the transmission, and repeated the process until I had clean fluid.
    I switched to Amsoil fluid and noticed that the shifting is a little firm and also “bumps” occasionally on rolling acceleration, and also with deceleration.
    After finding your thread, I’ll most likely do nothing. Although I’m a bit worried now because I didn’t drop the pan and do any cleaning.
    I have 84,000 on my 2013 Crewmax and tow a 7000lb camper often.
    Thanks again for sharing your experience!
  6. Oct 28, 2021 at 6:20 AM
    #126
    1rooster
    Tony
    2007 crewmax
    Thanks Mathew. I wish I would have pulled my pan sooner as well, (the detergents in the new fluid may have dissolved any buildup),but that is the past. When I did pull the pan and filter I did not find anything of concern. I’m at 141k now and no changes. I’m still leaning towards a glazed clutch pack because my minor problem still occurs. As long as it is not slipping or any super hard shifts I am happy! My fluid still
    Looks perfect even after a few long road trips pulling several sxs’s. I think next time I will go amsoil as well.
  7. Oct 28, 2021 at 6:23 AM
    #127
    1rooster
    Tony
    2007 crewmax
    As long as you are sure your fluid level is correct I would do nothing unless more problems start to occur.
  8. Oct 28, 2021 at 7:46 AM
    #128
    mnm567
    mnm567 New Member
    Matthew
    Yeah,
    I jumped the pins on the OBDII port and made sure the truck was level. The crazy thing is the varying temperatures there are to check the level at. I feel like everyone has their own opinion as to what the temp range is and how to check it. It seems like its different for different year Tundras. I trusted the shift light indicator that was set from the factory most. Maybe its the wrong procedure.
    1rooster[QUOTED][OP] likes this.
  9. Oct 28, 2021 at 12:58 PM
    #129
    1rooster
    Tony
    2007 crewmax
    I’m pretty sure mine comes on 99 degree. I verified that by pulling my jumper cable and plugging in my ultra gauge then the light came on.
  10. Oct 28, 2021 at 2:53 PM
    #130
    mnm567
    mnm567 New Member
    Matthew
    That’s around the temp I checked it at.
  11. Nov 6, 2021 at 12:44 PM
    #131
    Slick33
    Slick33 New Member
    mverkaik and JSully like this.
  12. Apr 17, 2024 at 8:07 AM
    #132
    SpooledReel
    SpooledReel Insufficient Funds
    RickyP
    Spanish Fort, AL
    2015 Tundra CM Limited 4x4
    Old thread, but did the 4h gear shift ever improve? I am now having a hard shift into 4th gear, almost like a slam into gear. I'm at 116,000 miles. I have done spill and fill 3 times since 60000 miles all with WS. I spilled and filled again with WS yesterday with no noticeable change. Of note, I also greased my zirks with Lucas Red and Tacky 2 weeks ago after getting new tires. I'm running 38psi in the new tires 275/65r20 Nitto Recon Grapplers. The 4th gear jarring started a few days ago.
  13. Apr 17, 2024 at 10:06 AM
    #133
    TundraDude772
    TundraDude772 Shake N’ Bake, Ricky Bobby
    Eric
    FL
    2010 & 2020 SR5
    2010 SR5 CrewMax Silver Sky Metallic 7” BDS/Fox 17x8.5 Method MR705 40x13.50 Toyo M/T Transfer Flow 46 gallon ICI Magnum front bumper PML Transmission Pan Hooke Road 18” bed rack Nature Nest Hard-Shell RTT Ironman 4x4 awning Coachbuilder upgrades SuperPro LCA Bushings Total Chaos UCA’s Energy rack bushings Moog LCA Cams 2020 SR5 Double Cab Voodoo Blue 40/20/40 Front Bench TRD Pro Grille TRD Pro headlights 17x9 Vision 351 285/70 Toyo A/T3 PML Transmission Pan RCI Skidplates eBay bumpers TRD rear sway bar
    I had a similar issue (post #11).
    Last year, when I upgraded to the PML deep pan I decided to change the filter and flush the fluid while everything was taken apart.
    I reluctantly went with the Valvoline Maxlife ATF (red jug) instead of Toyota WS fluid. I also added a bottle of LubeGard Platinum, Synthetic Protectant, and Shudder Fixx.
    I was expecting the problem to become worse, honestly. But it’s been about 5,000 miles since, and I haven’t had a hard shift since
    SpooledReel[QUOTED] likes this.
  14. Apr 17, 2024 at 10:35 AM
    #134
    SpooledReel
    RickyP
    Spanish Fort, AL
    Appreciate the follow up. On the maxlife, was that just a spill and fill or did you completlely change out your fluid?
    So..you added all three... This, this and this?
    https://www.amazon.com/Lubegard-60902-Automatic-Transmission-Protectant/dp/B0007ZAJRM?crid=1PP5LMHFNEGZK&dib=eyJ2IjoiMSJ9.GCq0eq34kvZbZ9YwaJC0Lb2jVDq8J1XGnfTUoEG3MIMjm3Qpg0tdVB7wMpNuKREqRsEqdjsb5-YmD7cXRTVc5KcjJueuMMQXPvVvZgYMLwq0TrjOHDAgNZzpm58Z02yluTqnMCUthnGJ17aAV3lwv-y8sNGireiMamIk910f4Ek7zZ_M82fp5Tv8Yv7t6sIaz4iYW50AOLmTQQB28IsfTdbzs9AMSAjnBOC0MefCPLiku98qFKzaVw83o-zxTZxmtHTLfpEw5r1NBM5c7Y_BbrueY2FbrSWDD17stad3VBw.LxQD7f7ym-ARAgc1jYAm9Bud1LtcJ84cDlXcggr0_XI&dib_tag=se&keywords=lubegard+synthetic+protectant+transmission&qid=1713375174&s=automotive&sprefix=lubegard+syntetic+protectant+transmission%2Cautomotive%2C65&sr=1-1&th=1
    https://www.amazon.com/Lubegard-63010-Platinum-Universal-Protectant/dp/B002MB57UI?crid=1PP5LMHFNEGZK&dib=eyJ2IjoiMSJ9.GCq0eq34kvZbZ9YwaJC0Lb2jVDq8J1XGnfTUoEG3MIMjm3Qpg0tdVB7wMpNuKREqRsEqdjsb5-YmD7cXRTVc5KcjJueuMMQXPvVvZgYMLwq0TrjOHDAgNZzpm58Z02yluTqnMCUthnGJ17aAV3lwv-y8sNGireiMamIk910f4Ek7zZ_M82fp5Tv8Yv7t6sIaz4iYW50AOLmTQQB28IsfTdbzs9AMSAjnBOC0MefCPLiku98qFKzaVw83o-zxTZxmtHTLfpEw5r1NBM5c7Y_BbrueY2FbrSWDD17stad3VBw.LxQD7f7ym-ARAgc1jYAm9Bud1LtcJ84cDlXcggr0_XI&dib_tag=se&keywords=lubegard+synthetic+protectant+transmission&qid=1713375251&s=automotive&sprefix=lubegard+syntetic+protectant+transmission%2Cautomotive%2C65&sr=1-2
    https://www.amazon.com/Lubegard-19610-Tranny-Instant-Shudder/dp/B0002JMLQU?crid=1PP5LMHFNEGZK&dib=eyJ2IjoiMSJ9.GCq0eq34kvZbZ9YwaJC0Lb2jVDq8J1XGnfTUoEG3MIMjm3Qpg0tdVB7wMpNuKREqRsEqdjsb5-YmD7cXRTVc5KcjJueuMMQXPvVvZgYMLwq0TrjOHDAgNZzpm58Z02yluTqnMCUthnGJ17aAV3lwv-y8sNGireiMamIk910f4Ek7zZ_M82fp5Tv8Yv7t6sIaz4iYW50AOLmTQQB28IsfTdbzs9AMSAjnBOC0MefCPLiku98qFKzaVw83o-zxTZxmtHTLfpEw5r1NBM5c7Y_BbrueY2FbrSWDD17stad3VBw.LxQD7f7ym-ARAgc1jYAm9Bud1LtcJ84cDlXcggr0_XI&dib_tag=se&keywords=lubegard+synthetic+protectant+transmission&qid=1713375251&s=automotive&sprefix=lubegard+syntetic+protectant+transmission%2Cautomotive%2C65&sr=1-3&th=1
  15. Apr 17, 2024 at 10:46 AM
    #135
    SpooledReel
    RickyP
    Spanish Fort, AL
    reread and answered my own question on the maxlife
  16. Apr 17, 2024 at 12:55 PM
    #136
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    I guess you could say it was a glorified spill and fill, since I didn’t hook it up to a machine and “flush” all the old out. I’d say I got at least 70% of it, though. Obviously whatever was in the pan, then about a quart out of the valve body when I pulled the filter off; I also disconnected the trans cooler lines at the front of the truck and blew a quart or two out using compressed air.
    Don’t forget to pin your thermostat open if you’re trying to get out as much fluid as possible!!!
    And yes, correct. 15oz bottle of the platinum, 10oz of the protectant, and 2oz of shudder fixx; to be exact.
  17. Apr 17, 2024 at 3:18 PM
    #137
    RockWarriorLover
    RockWarriorLover New Member
    MGM 2013 Rock Warrior
    3 inch lift, Flowmaster catback exhaust, BFGoodrich 35s, Rough Country Bull Bar with LED Light Bar. Fender flares
    So, i have 180k miles, I did a drain and fill. BUT HERES THE CATCH, my check plug is completely rotted out. #1 i forgot to open the thermostat plug. #2. I didnt pull the check plug bc i didnt want it to be stripped out and not be able to put it back in. #3 I ordered the filter and gasket for the filter and pan. BUT my bolts to the pan are so rotted out, Im sure 75 percent of them will snap. I was having some harddd cluncks from 5-6 gear. I have the tow package, and im running 35 inch tires. I did get an oil change and it has helped a lil. I put lubegard in and it did work, But im just wondering what i should do for the fluid level, check plug, and pan to access filter.
    ALSO is runs good cold, but as soon as it gets warm, it does shift harder. Im thinking im low on fluid as the viscosity lessens as it the fluid reduces in volume due to increase in temperature.
  18. Apr 17, 2024 at 4:03 PM
    #138
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    If all the bolts are as rusted/seized as you’re saying they are, just go ahead and plan on replacing the pan and all the hardware, or at the very least have a bolt extractor + tap kit. Because you’re going to have to open the check valve one way or another to ensure proper fluid level, especially if you didn’t pin the thermostat. Just plan on the worst case scenario, and have the tools + parts to handle it. It’s not a huge job even if worse comes to worst.
    I didn’t have a single bolt break or seize on my 2010 with 145k. But my 2020 with 50k that spent a year in the rust belt broke 3 of the pan bolts, even being gentle and applying PB blaster. I was able to extract 2, but one of them didn’t work out but 11/12 bolts was good enough for me and it doesn’t leak.
    I knew I should have saved my OEM transmission pans, I would have gladly given them away for free instead of throwing them in the scrap pile.
    And I thought fluid expanded as it heats? I could be wrong, but either way you definitely need to get the correct amount of fluid in there before something expensive happens.
  19. Jun 19, 2024 at 3:29 PM
    #139
    SpooledReel
    RickyP
    Spanish Fort, AL
    So, I bought a 2 cases of WS fluid and spilled the pan as well as broke loose the hose in the front and pumped in/out both cases with no improvement. Tried adding the Lubeguard with no luck. Took to a reputable transmission shop and had it checked out. I talked to the owner and explained what I had done. He checked diagnostics, levels, running gear, etc and he stated that it was possibly a sticking valve body, but wouldnt know without throwing more money at it. He further stated that it runs and shifts as is, it just shifts excessively hard in 4th gear. So while I cannot stand he hard shift, i cant quite justify a new transmission. Guess I will just drive it til it breaks then throw a new one in. Drives me crazy as I worked so hard to prevent this with spill and fills with always bright pink fluid return.
  20. Jun 21, 2024 at 4:20 PM
    #140
    TundraDude772
    Eric
    FL
    2010 & 2020 SR5
    It sounds like this is a recent issue that has started out of nowhere for you, which is strange given your maintenance schedule.
    Have you tried disconnecting the battery for half a hour? I’ve read the engine/transmission computers “Learn” as you drive, and sometimes a reset can help it refresh.
  21. Jul 21, 2024 at 8:50 PM
    #141
    Tiger85
    Tiger85 New Member
    2025 Mag Gray Platinum i-Force MAX
    Shot from left field but with everything you did and it being somewhat of a gremlin, have you looked at the transmission grounding strap? I didn't know it was a thing but some claim it can cause rough shifts and sound be ready enough to tell if it's still there or not.
    https://www.tundras.com/threads/what-the-hell-is-this.112878/
  22. Aug 1, 2024 at 1:01 PM
    #142
    SpooledReel
    RickyP
    Spanish Fort, AL
    I did try a couple of battery disconnects and the shop did some sort of reset as well with no change.
    I have not looked into this, but i will try it next.
    Another interesting fluke is the truck shifts fine for the first 1-2 miles when i first start it while the temps are down. I don't know if it is related to temperature or pressure? I almost wonder if a thicker ATF fluid, if there is such a thing, would help? Still only the 3rd-4th gear shift is hard.
  23. Aug 2, 2024 at 7:12 AM
    #143
    1rooster
    Tony
    2007 crewmax
    So… I ended up selling the tundra to my brother in law about a year ago. While I had it I put about 30k with no issues. Now at 159,xxx he called me and told me while driving 60mph down a flat road, he had a hard down shift into third and lost 4th, 5th and 6th. Also 1st gear revs out to about 3k before going into second. It is throwing a few codes. I drained a small sample out when he get it back home and the fluid still
    Looks clear cherry red. I’ll keep y’all updated on the outcome. We ordered a few new solenoids and input and output turbine speed censor. Plan on putting them in this weekend
    Coal Dragger likes this.
  24. Aug 2, 2024 at 8:17 AM
    #144
    hagrid
    Spraynard
    Pittsburgh
    K1600GTL ZX-14R
    paynuss stretchers
    I appreciate the update.
    If you happen to ascertain the codes post them here, plz.
  25. Aug 2, 2024 at 9:24 AM
    #145
    1rooster
    Tony
    2007 crewmax
    hagrid likes this.
  26. Aug 2, 2024 at 9:30 AM
    #146
    1rooster
    Tony
    2007 crewmax
    He said it was 100% normal and shifting great, and then the very next second it down shifted and then the check engine, traction control, vsc off flashing.
  27. Aug 2, 2024 at 9:51 AM
    #147
    blackdemon_tt
    blackdemon_tt Battery Slayer
    That big solenoid for P2714 will resolve that issue... I had the same feeling, but mine was uphill, all of a sudden I felt a tug like a downshift, and everyone was passing me, and revs were sky high, about 4 to 5k at 60mph. Grab that O-ring from the filter, since the filter will need to come out. That L shape retainer resides above it.
    Edit: btw, its 1st that's gone, It double shifts into 2nd gear, according to that manual.
  28. Aug 2, 2024 at 10:09 AM
    #148
    1rooster
    Tony
    2007 crewmax
    I sure hope so! He went ahead and got SLT and S1 solenoid just in case. I’ll ohm test and battery test them once we get the pan off. I have also researched where 2714 code can be thrown and 4th 5th and 6th gear lock out if input or output speed sensor goes bad. I’m also gone check resistance on those too.
  29. Aug 2, 2024 at 11:11 AM
    #149
    1rooster
    Tony
    2007 crewmax
    what you mean it’s 1st that’s gone?
  30. Aug 2, 2024 at 12:48 PM
    #150
    SpooledReel
    RickyP
    Spanish Fort, AL
    Just for clarity, your quote of 100% normal…he was saying that your original 3rd to 4th gear had resolved with all of your original work?
