Hard shift from R to D
Discussion in '3rd Gen Tundras (2022+)' started by X42069, Dec 6, 2022.
  1. Dec 6, 2022 at 6:37 AM
    X42069
    X42069 [OP] New Member
    M
    Southwestern Ontario Canada
    23 SR5 CrewMax TRD Off Road 6.5ft box
    Anyone else find their truck shifts really hard from reverse to drive. When I shift into the drive the truck almost lurches forward an inch or so.
    Sorry if this has been posted before
    SWB Tundra likes this.
  2. Dec 6, 2022 at 6:54 AM
    DrZoidberg
    DrZoidberg New Member
    Dave
    SATX
    Tesla MYP
    My TRD pro did it. Hated it. Only thing that would make it less is after cold start, let it idle long enough for rpm’s to drop
  3. Dec 6, 2022 at 6:55 AM
    taschmidt86
    taschmidt86 New Member
    2022 Tundra 1794 W/ TRD Package
    None
    I experienced this off and on for the first 5k or so. And then it just smoothed out. I think its just gears wearing in.
    X42069[QUOTED][OP] likes this.
  4. Dec 6, 2022 at 7:04 AM
    devron11
    devron11 New Member
    Ron
    Denver
    Yes - and I agree with DrZ as to the cause plus keep the foot brake applied for a second or two after the gear lever is shifted. It is more pronounced when engine and trans is stone cold.
    pwpblue and X42069[OP] like this.
  5. Dec 6, 2022 at 7:11 AM
    X42069
    M
    It does it even when warm. I remote start and idle for 10 minutes before driving my daughter to daycare before work. It does it leaving day care as well when the engine is completely warmed up from idling and being driven to daycare.
    This makes me feel a little better. I will be mentioning it at my first oil change
  6. Dec 6, 2022 at 8:59 AM
    MadMaxCanon
    MadMaxCanon New Member
    '21 CM SR5 4x4 6 seater
    Too many, but not enough....
    on my 21 i found that the process of parking the truck really affected how it shifted out of reverse the next time I drove it. If you just slam it in Park and walk away all the weight of the truck is on the tranny. If you shift in neutral, apply the parking brake, then put in park, it shifted really smoothly out of reverse the next time I drove it.
    Kap1 likes this.
  7. Dec 6, 2022 at 9:17 AM
    PERRY1060
    PERRY1060 Hammer Down
    Perry
    Indiana
    Blk on Blk 22 Ltd 4x4
    TRD wheels, skid plate, black fender flares, mud flaps and running boards. Pirelli Scorpion 275/70/20 Allterrain Plus tires
    I’m not sure if this is the same problem but I have noticed if I am rolling when I shift from R to D I will get a lurch or similar movement. Once I made sure I came to a full stop before shifting to drive the problem stopped. My 05 Sequoia was the same way. I think it is because there is no delay or mechanical slop/play when we put it in drive. So if we are rolling it is going to react badly because we are telling the drivetrain to go forward when the vehicle is moving backward. This is specific to after the vehicle is warmed up. A cold start fast idle gear change should lurch some. Maybe think of it this way. If your vehicle is warmed up sitting in neutral, next push on gas a little and then put it in drive or reverse. It’s not going to be a smooth transition. It has been less noticeable on domestic vehicles I have owned I think because they don’t have as tight a tolerance in there design. Thats part of why domestics generally don’t last as long. They are built to a lower tolerance standard. Hope this makes sense mechanically.
    Kap1 likes this.
  8. Dec 6, 2022 at 9:24 AM
    X42069
    M
    I believe the 3rd gens apply the parking break automatically
    I do this everytime and still feel a hard shift. I will reverse. Come to complete stop. Apply full pressure to brakes and then shift to drive. I still feel a big clunk.
    Hoping this doesn't turn into an issue. I love the truck otherwise and am yet to come across any of the more common issues like the drivers side mirror noise
    MadMaxCanon[QUOTED] likes this.
  9. Dec 6, 2022 at 9:59 AM
    Kap1
    Kap1 New Member
    San Francisco, CA
    This does not sound good, definitely take it to dealer. It's probably not supposed to do this.
  10. May 6, 2023 at 6:26 AM
    Bier_Me_1
    Bier_Me_1 New Member
    Shane B.
    2022 Tundra SR5
    Are you still having this issue? I have a 22 sr5 and notice it on my truck. I have about 2,000 miles on mine
  11. Jul 12, 2023 at 8:54 PM
    ToyotaAl
    ToyotaAl New Member
    I notice mine the most when I’m first starting the truck up in the morning. I will let it idle until rpm’s go down and then when I shift it into park, the truck will lurch forward even when parking brake is applied. If I shift into reverse and back out of my driveway and then shift to park there is still a lurch, but not as bad. Then when pressing on the accelerator it takes it a second or two to slip into gear. Is this familiar with anyone else that drives a new gen tundra?
  12. Jul 13, 2023 at 6:26 AM
    devron11
    devron11 New Member
    Ron
    Denver
    There is a free dealer repair available for this per a TSB to reprogram the TCM.
  13. Jul 13, 2023 at 8:10 AM
    ToyotaAl
    ToyotaAl New Member
    Thanks. I know I said shift to park but I meant to say when I shift into drive there is a lurch. Really only happens when it’s been sitting over night or for several hours.
  14. Jul 13, 2023 at 8:43 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
  15. Jul 13, 2023 at 9:12 AM
    ToyotaAl
    ToyotaAl New Member
    They apparently did that TSB awhile ago on mine but I still have that weird lurch when I pop it into drive
  16. Jul 13, 2023 at 9:19 AM
    eddiefromcali
    eddiefromcali New Member
    Eddie
    2022 Tundra Platinum
    100% Stock
  17. Jul 13, 2023 at 9:50 AM
    ToyotaAl
    ToyotaAl New Member
    Hate to shift gears (no pun intended) but has anyone experienced a whooshing/whirling sound coming from the AC when you’re driving? When I’m stopped or just idling it doesn’t do it. Only when accelerating. Almost sounds like something from the engine, but when I turn the whole fan system off it stops as well.
  18. Jul 13, 2023 at 9:52 AM
    Timmy23
    Timmy23 New Member
    OR
    25 1794 MGM Tundra
    None
    110 was done at the same time for the cold start clunk.
  19. May 24, 2024 at 7:04 PM
    Suryu
    Suryu New Member
    2024 SR Crewmax
    Mine does this as well. I notice that it goes away after the initial lurch into drive. But on the first cold start it lurches forward or backwards. Dealer said it’s normal… but idk.
    I was wondering if this was just a truck thing because my Hyundai sonata, Hyundai Santa Fe and Highlander does not do this.
  20. May 24, 2024 at 8:18 PM
    Lee.M
    Lee.M New Member
    TN
    24tundra limited 4x4
    Level/35s
    I had to get the TSB for the 22-23 models done to my 2024. Had the same issue I Cannot recall the TSB hope someone can chime in soon. But it did fix the issue of the lurching and clunking.
  21. May 24, 2024 at 9:02 PM
    *D*
    *D* New Member
    Dimitri
    Rhode Island
    ‘24 DC Long Bed 4x4 SR5
    I have a ‘24 and haven’t experienced anything like this.
    Definitely bring it to the dealer and tell them to investigate.
    If it feels wrong, then it probably is wrong.
    I hope it’s a simple fix.
  22. May 25, 2024 at 5:27 AM
    SWB Tundra
    SWB Tundra New Member
    T
    Cenral Arkansas
    2024 Tundra Platinum 4x4 CM Hybrid
    Yeah, mine does it. But, if I let it warm up a little bit. Its okay.
  23. May 31, 2024 at 9:08 AM
    Suryu
    Suryu New Member
    2024 SR Crewmax
    Went to the dealership and had a technician look at the car, he said that the truck is fine and there won’t be issues with the transmission due to the lurch.
  24. May 31, 2024 at 1:33 PM
    Lee.M
    Lee.M New Member
    TN
    Level/35s
    You mentioned lurching on start up. Like truck lurches forward in park when starting? Or just from shifting from reverse to drive
  25. May 31, 2024 at 2:13 PM
    Suryu
    Suryu New Member
    2024 SR Crewmax
    shifting from reverse to drive. Rocks me more than I imagine being normal. Funny thing is it isn’t as pronounced this morning.
  26. May 31, 2024 at 2:27 PM
    Lee.M
    Lee.M New Member
    TN
    Level/35s
    I swear man i showed my service manager the TSB for the 22-23 model trucks on the clunk and hard shift from reverse to drive. He had his senior tech update my trans and do the neutral recall at the same time. I would back out of my drive way go from reverse to drive truck would jump and clunk into drive. Sounded awful and that TSB fixed it.
  27. Jun 3, 2024 at 3:58 PM
    Suryu
    Suryu New Member
    2024 SR Crewmax
    If you ever remember the tsb done, please let me know!
  28. Jun 3, 2024 at 6:12 PM
    Lee.M
    Lee.M New Member
    TN
    Level/35s
    Looked at my paper work tsb 111 was what was applied to mine. And the neutral recall from short time ago. The reverse to drive jolt was reduced to a normal feeling. If you do not let it warm up the high idle will only amplify the effect.
  29. Jun 6, 2024 at 12:58 PM
    Wyoming
    Wyoming New Member
    2024 White SR5 CM 4x4
    I have had the same "R-D lurch" behavior so I was interested when this thread popped-up. It was most notable after a cold-start. I recently had the "drive forward in neutral" recall completed and it seems to have resolved the "R-D lurch". Hope that helps...
  30. Jun 6, 2024 at 1:26 PM
    DeaG
    DeaG New Member
    SF Bay Area
    2024 Lunar Rock Tundra Limited TRD OR
    I have the same issue on cold starts. Either from P to D or R to D. Figured it was normal and just deal with it.
