Hard panel tonneau that is east to remove?
Discussion in '3rd Gen Tundras (2022+)' started by BoulderGT3, Jul 8, 2023.
  1. Jul 8, 2023 at 6:39 AM
    BoulderGT3
    BoulderGT3 [OP] New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    Looking for a weather tight panel tonneau that is east to take on and off. Any suggestions?
  2. Jul 8, 2023 at 6:54 AM
    Phroggunner6172
    Phroggunner6172 New Member
    2023 MGM Tundra Limited TRD
    Maharisc and BoulderGT3[OP] like this.
  3. Jul 8, 2023 at 7:59 AM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    2023 Celestial Tundra CM TRD OR
    If you want a one piece, non folding tonneau, the undercover se and elite are great options. Super easy to remove and very lightweight. They come with some wall brackets to hang it on a wall when it's off of the truck.
    Some of the models can be ordered color matched as well. They are all abs plastic, not fiberglass like a snuglid, ARE or Leer.
    https://undercoverinfo.com/undercover-elite/2023/toyota/tundra
  4. Jul 8, 2023 at 8:01 AM
    DMackler
    DMackler New Member
    Dustin
    Burleson, Texas
    If by "panel" tonneau, you are referring to a folding cover, take your pick. The Bak options and undercover options can be folded and removed by loosening one screw on each side. The rails will stay in place, but take up next to no room.
    1lowlife likes this.
  5. Jul 8, 2023 at 8:34 AM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
  6. Jul 8, 2023 at 10:29 AM
    osu1978
    osu1978 New Member
    Lomax Tri Fold is light and easy to remove.
    ryanwgregg and BoulderGT3[OP] like this.
  7. Jul 8, 2023 at 10:34 AM
    BoulderGT3
    Glen
    I just looked at Lomax and BAK. It looks like the Lomax is definitely easier to remove. I'd need to have it off probably 1/2 the time.
    ryanwgregg likes this.
  8. Jul 8, 2023 at 9:40 PM
    kimw880
    kimw880 New Member
    will
    22 Tundra
    Once installed the Bak mx4 can be removed from the truck in less than 2 minutes without any tools. If you're fast you could probably do this in a minute. You unscrew two hand knobs that holds the front portion of the cover to the truck rails and the cover can pop off. Not sure how much faster the lomax is.
  9. Jul 8, 2023 at 10:18 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Bak tri fold don't even need to remove, I drove with the cover all the way open leaning against the cap with the build in rods that hold the cover open.
    If you want to see through the back and don't need to carry weight on cover, you could buy the Bak Revolver cover, it roll open and straps hold it open.
  10. Jul 8, 2023 at 10:25 PM
    Hella Krusty
    Hella Krusty New Member
    Get a Toyota OEM......they come off on their own so less work for you
  11. Jul 9, 2023 at 1:28 AM
    Descend
    Descend New Member
    North West
    '23 Tundra TRD Pro MGM
    My Bak is simple to remove but I can't get it to stop leaking.
    mayan likes this.
  12. Jul 9, 2023 at 8:36 PM
    Hella Krusty
    My Toyota OEM is Bone Dry in the box no matter what the weather or pressure washer throws at it.....and it hasnt sailed off the back yet either
  13. Jul 9, 2023 at 9:08 PM
    Bourbonator
    Bourbonator New Member
    North ID
    '23 LE CM 6.5
    It takes less than two minutes to remove the bakflip, so I guess he Lomax only takes one minute!
  14. Jul 9, 2023 at 9:42 PM
    Tom976
    Tom976 New Member
    Tom
    Thats the cover I purchased for my 23. Easy to remove? Yeah but not that light. I will say they panels are nice and thick.
    Nice cover, happy with it so far.
  15. Jul 10, 2023 at 1:48 PM
    BoulderGT3
    Glen
    I watched a couple of videos of it. When you say "not that light", can you handle it by yourself. Also, can you still use the factory track rails when you put the mounting rails on for the Lomax? Thanks
  16. Jul 10, 2023 at 9:32 PM
    smallt0wnmoon
    smallt0wnmoon New Member
    Vermont
    2023 Tundra SR5, MGM
    Weathertech tri fold is super easy to remove. Fold up, unhook carabiner and lift off. Only downside is that it gets VERY hot in the summer. No water leakage either, except around tailgate, but tailgate seal will fix that
  17. Jul 10, 2023 at 9:35 PM
    Tom976
    Tom976 New Member
    Tom
    I can handle it myself yes, does it have some weight? Yes. Its basically 3 1/8" (might be a bit thicker) aluminum panels with some reinforcement.
    I'm used to soft covers, those are super light but offer little security. Cheaper too but last between 3 -5 years.
    When I chose the options (got it from RealTruck) I went for the cover made for use with factory rail kit. Color was black urethane. Looks like the bed spray stuff.
    With a rough texture I cant see scratches and its almost like roofing shingle texture.
  18. Jul 11, 2023 at 2:20 AM
    TWade
    TWade New Member
    Tanner
    2023 Tundra TRD Pro Black on Black
    Lassie likes this.
  19. Jul 11, 2023 at 3:04 AM
    BoulderGT3
    Glen
    Thanks for the information. One last question. Does it rattle? Thanks.
  20. Jul 11, 2023 at 4:29 AM
    eharri3
    eharri3 New Member
    2021 F150 Powerboost
    Biggest deal killer on the Peragon for most is sliding cargo intruding into space it needs when folded, making it impossible to
    Open when you stop prior to getting under there and clearing that space.
  21. Jul 11, 2023 at 4:34 AM
    TWade
    TWade New Member
    Tanner
    I have heard that may be an issue. I cant say I have read anywhere in which it is a confirmed problem (definitely not saying it is not possible). I dont have one myself, but I have the spray in bedliner and honestly, nothing really moves in the bed. And if interested, they are doing a pretty good deal for Primeday. The option to lock it and how easy it removes is pretty killer.
  22. Jul 11, 2023 at 4:58 AM
    centex
    centex New Member
    Different truck but my lomax tri fold is really easy to remove if needed. Fold the first two panels, unhook the carabiner, pull the latch and lift up and off.
    Rb123 and BoulderGT3[OP] like this.
  23. Jul 11, 2023 at 5:17 AM
    eharri3
    eharri3 New Member
    I mean it's out there if you dig that you have to plan the load in your bed around the cover. Maybe more so than with a canister because that last fold starts to dip down and eat away height that you started with as you retract. That seems like an even bigger irritant to me than just losing a consistent 6-12 inches of bed by the cab.
    Many seem to like them so much they accept that and work around it. Doesn't get much mention on youtube as you have to sift through all the channels where people depend on goodwill to get them manufacturer free samples to find people who actually bought them and decided to review with no punches pulled.
    https://hdrams.com/forum/index.php?threads/peragon-bed-cover-versus-retractable-tonneau.11515/
    I'm not crapping all Over them as a bunch of people seem to feel pros outweigh cons and I can't argue with that. Something like a Bak x4 just seems like a better compromise to me. When we hit up our vacation rental we use every inch of the bed. I could probably work with a canister if I absolutely had to but not something that folds down into the cargo area to open after I packed.
  24. Jul 11, 2023 at 8:03 AM
    kimw880
    kimw880 New Member
    will
    22 Tundra
    Not sure about Lomax but the BAK-MX4 is probably 40 lbs or so. Similar to a large bag of dog food in weight. It's just awkward to move b/c of the length/dimensions of the cover when folded. Even with multiple physical disabilities I'm able to this alone. If you are missing an arm or a leg it may be a little harder but otherwise you should still be able to remove the cover from the bed in 1-2 minutes. But with the BAK you probably just need to fold it up to the glass to carry really large items and won't need to remove the cover at all. This would probably be the same for the Lomax. on the BAK there are still the factory rails and sliding clamps that can be used so nothing changes in terms of mounting points.
    The Bak can be folded up all the way up to the glass window and includes a stand feature to hold it up so you access to the entire bed less the 6 inches of space required for the tonneau to remain on the bed with the cover in the full up position. Lomax can't do this.
    Lomax: Full cover, 2/3 cover, 1/3 cover, then off.
    BAK-MX$: Full cover, 2/3 cover, 1/3 cover, 10% bed cover with Tonneau in up position which allows 90% access of the bed to carry stuff taller than the bed height.
  25. Jul 11, 2023 at 10:13 AM
    Tom976
    Tom976 New Member
    Tom
    I drive with the back window down when the weather is nice.... I dont hear a thing over the radio blasting. LOL
    Nope its very solid, dont hear a thing and hope it lasts longer than the truck does.
    Soft covers tend to make noise (rattle) as the wind goes over the soft material. Happened to the cover on my Tacoma. (especially as the cover gets older)
  26. Jul 12, 2023 at 8:06 AM
    jks21687
    jks21687 New Member
    I would stay away from the Lomax cover. Ordered one and the latch was faulty on the passenger side. I went back and forth with customer service and they kept saying it was operating correctly. I didn't order directly from Agri-cover but ended up sending it back and Agri-cover wanted to charge a restocking fee to the dealer which then would have been passed on to me because the cover could have been fixed...even though they told me it was operating correctly.
    Yes it is easy to remove and is probably a decent cover if everything works as advertised. If it doesn't....good luck with getting a resolution with their customer service.
  27. Jul 12, 2023 at 8:30 AM
    SD Surfer
    Bruce
    So Cal
    Boom... :rolleyes:
    Very happy with my MX4 so far.
    Very little water intrusion (Maybe a tiny bit in the corners when you run it through a car wash)
    Two knobs and it's off.
    Seems stout enough to be secure (at least enough to keep honest people out)
    Can carry 400 lbs on top.
    I've always run campers shells before this truck... this is my first tonneau so I have no frame of reference to compare this to anything else, but my research led me to the Bakflip and I'm happy with it.
    Norfolk757 likes this.
  28. Jul 12, 2023 at 9:23 AM
    Tom976
    Tom976 New Member
    Tom
    I liked the features of the mx4 but there were many discussions in the forum about bakflip being the oem vendor for the recalled Toyota covers. There was some back and forth between it being an mx4 or the g2.
    So with that I decided to find another brand cover.
  29. Oct 23, 2023 at 7:01 PM
    CMJT
    CMJT New Member
    2024 Tundra SR5
    Really nice, how was the install?
  30. Oct 23, 2023 at 11:15 PM
    SD Surfer
    Bruce
    So Cal
    Mine was painless! The place I bought it from installed it for me super cheap.
    They're just a few doors down from my office, and I sell them fasteners at basically no markup so he takes care of me.
    He installed the tonneau, ran the drain tubes out the front between bed and cab, and ran power from battery back into the bed for me for like $50
    Everybody I've heard comment about the install has said it's pretty straight forward though, just measure carefully to line it up straight and even and it's a cakewalk. An hour, two at the outside.
