Hard panel bed cover recommendations
Discussion in '3rd Gen Tundras (2022+)' started by BoulderGT3, May 27, 2024.
  1. May 27, 2024 at 11:39 AM
    BoulderGT3
    BoulderGT3 [OP] New Member
    Glen
    2023 1794 4X4 BP/Saddle ADV Steps
    I looked at the buyers guide on the forum but it wasn't very helpful. I'm looking for a 3 or 4 panel. Uses existing tracks and lets me use the tie downs on the track. Folds up and latches to the front secure enough I can drive long distance. The BAK seems to be good quality but no idea on how they hold up. Lastly, I need to be able to get it in a week. Any good experiences fitting one on a gen3? Thanks.
  2. May 27, 2024 at 12:02 PM
    EastTennTundra
    EastTennTundra New Member
    I am currently using the Toptiny cover that I purchased from Amazon. The price is currently $499 with a $40 off coupon.
    It fits perfectly and it's strong. It does want you to have the rails on your truck.
    In my case, it sits snug on the tailgate, so you can't open the tailgate with the side button, etc. You have to pull it open with the handle.
    I have not noticed any leaks.
    It does fold up and secure next to the cabin.
    Made of aluminum and easy to install.
    It's the only one I've spent any time with, so I can't compare it to others.
    https://www.amazon.com/gp/product/B0B5NYH1HR?ie=UTF8&th=1
    pwpblue, kirkb and BoulderGT3[OP] like this.
  3. May 27, 2024 at 12:12 PM
    BoulderGT3
    Glen
    Thanks. A good deal too. Looks like it comes off pretty easy? How does if fold up for travel?
  4. May 27, 2024 at 12:27 PM
    EastTennTundra
    It does fold up very easy.
    There are clamps on each side of the two panels away from the cab. You release the clamp on the third panel and fold it to the middle panel (you cannot stop here. You have to fold these two panels up to the first). Then you release the clamps on the middle panel and fold the two panels on the first panel next to the cab. There are straps that clip in to the first panel to lock the panels together next to the cab (stacked and flat).
    The first panel next to the cab has two clamps that attach to the rails, but unlike the other panels (which are quick release handles), these clamps have a bolt with a large plastic disc you turn to lock that panel in place. To remove the whole cover you would untighten the bolts on the first panel and lift the 3 panels off together while the are secured together.
    It's really easy to do all of this, but as I said, I have no comparison to other covers. I just bought this one and figured I'd use it if it worked, or sell it if it didn't. So far (after about a year) I still have it.
  5. May 27, 2024 at 7:28 PM
    Bnewman077
    Bnewman077 Happy 2023 Owner
    2023 Tundra TRD OR Lunar Rock
    18” Method Wheels, 35x12.5 Toyo AT3, TRD Pro suspension with Westcott preload lift and Icon rear springs
    I’ve been using the Bak MX4 for about a year now and overall I like it. On a recent trip the bracket to hold everything up to the can bent and it lifts away from the cab at highway speed. Comes with foam padding where it folds against the cab so it doesn’t cause damage and still works. I put in a warranty claim to see if it can be fixed but haven’t heard back yet. Overall it is a good cover and I’ve been happy.
    BoulderGT3[OP] likes this.
  6. May 29, 2024 at 11:02 AM
    Bnewman077
    I just spoke with Bak Industries and they have honored the Warranty request and are sending out a replacement cover. Customer service was great and an easy process. I like the cover but would consider their Revolver cover if I were to do it again. I like that it wouldn't block the back window the the bed is full opened.
  7. Jun 1, 2024 at 6:38 PM
    jkd407
    jkd407 New Member
    Jeff
    I just installed a Lomax Tri-fold today. Seems like a quality product and I like the look of it, but can’t give you much feedback yet. I will say that it took about three weeks from order to delivery, so if you need within a week that may rule it out for you.
  8. Jun 2, 2024 at 6:18 AM
    Breathing Borla
    Northern Illinois
    I went with a under cover ultra flex
    really like it
  9. Jun 2, 2024 at 7:06 AM
    BoulderGT3
    Glen
    I appreciate the input. Any way you could send a picture of how it mounts and is it pretty solid when folded forward? Thanks.
  10. Jun 2, 2024 at 7:42 AM
    gj953
    gj953 New Member
    East Coast
    2023 1794 Hybrid TRD OR Blueprint
    I have had the OEM hard cover since I bought the truck in Nov '22, Really like it, have had no issues(no, it hasn't blown off - though I did put red loctite on the nuts on the fastener and it stays dry inside. One bonus feature - I had a break-in in Jan of this year at a hotel in Ashville, NC. They smashed the passenger front window to get in, rummaged thru the entire interior and tried to use a crowbar to get into my console safe and couldn't but did some serious damage to the plastics in the console trying. They also, tried to punch thru the tonneau cover. I found 3 dents in it, near the tailgate... but they didn't get in there either. I had a soft tonneau on my last tundra, and in todays world, am now really glad I have the hard cover.
    DogRunner2 and BoulderGT3[OP] like this.
  11. Jun 2, 2024 at 8:04 AM
    BoulderGT3
    Glen
    What's the deal with RealTruck? I've never used them. Big distributor of all tops? Good Service?
  12. Jun 2, 2024 at 9:04 AM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    2024 Honda Ridgeline Black Edition
    some time ago, Realtruck acquired several brands that supplied truck accessories. Some brands included are Go Rhino, AMP Research, BAK as example. I’ve personally dealt with these three. Realtruck has central sales and customer service, but refers to the brands for technical support. They are very strict with their returns process timeframe. I would say customer support varies, but not as good as before the change (based on my previous experience with these brands). However, I would not hesitate to buy from them. You can go to their web site to see the others. Just my personal experience and opinion.
  13. Jun 2, 2024 at 9:54 AM
    Bnewman077
    I just had to work with them for warranty support on my Bak cover. They didn’t initially respond to my email submission after 10 days so I called. Once I called it was super easy and after a 5min call I had my warranty claim approved and they are replacing my cover.
    I wouldn’t hesitate to buy from them again
    ChucklesToy likes this.
  14. Jun 2, 2024 at 7:54 PM
    jkd407
    jkd407 New Member
    Jeff
    It seems very solid. When the two folding sections are opened there is still a latch holding it to the rails and the bungees holding to the last panel.
  15. Jun 2, 2024 at 8:08 PM
    chavey2
    chavey2 Stormtrooper in Training.
    Christopher
    Austin, TX
    2024 Tundra SR5 Double Cab Std Bed 4x4.
    Just starting
    I gotta say, I cannot recommend the Peragon version. Quality wise, it seems to be okay. Its the functionality that is killing me.
    • Cannot put anything in the front of the bed because it blocks the opening of the cover. I had an ice chest slide up there and I had to drag my old fat axx all the way up there under the cover to get it out. If I had known that, I wouldn't have bought this one.
    • When open, it blocks the front tie downs from usage without complete removal.
    • Easy to remove, but hard to get re-aligned to get back in. I eventually had to bevel off the edges of the front pins to get it to go in.
    • Cannot use stock tie-downs in the rails.
    • And the worst - not waterproof. Everything got soaked with the cover in place. I do a lot of tailgating (sports, not driving) and the 1st time it rained, I lost all my paper plates and napkins even though they were under the cover.
    And then yesterday, it completely came out of the track while attempting to close it. @ChucklesToy got to see it happen 1st hand.
    I'm trying to see if I can return it and get my money back now.
  16. Jun 3, 2024 at 6:35 AM
    BoulderGT3
    Glen
    Thank you.
  17. Jun 4, 2024 at 5:11 AM
    Wayzata_Tundra
    Wayzata_Tundra HOOK EM
    That looks great; ordered a Lomax last week, can't wait
  18. Jun 4, 2024 at 5:29 AM
    Wayzata_Tundra
    was it fairly easy to install?
  19. Jun 4, 2024 at 5:42 AM
    grnwdjsn
    grnwdjsn New Member
    2023 Tundra Limited TRD Offroad
    I have the OEM (which is made by BAK and is almost identical to the MX4) and it leaks like a sieve. I have added so much weather stripping to my bed to try and solve the issue and still get water in the bed. I think it is a combo of the bed design and the cover. The bed has some pretty large gaps around the tail gate.
    SDT likes this.
  20. Jun 4, 2024 at 6:51 AM
    jkd407
    jkd407 New Member
    Jeff
    Yes, very easy with simple hand tools (socket wrench and torque wrench), by myself. Took me roughly 90 minutes but I was going very slowly and meticulously.
  21. Jun 4, 2024 at 7:19 AM
    Wayzata_Tundra
    Perfect! thank you
  22. Jun 4, 2024 at 11:40 AM
    SDT
    SDT New Member
    B
    2022 Limited Tundra Mesquite
    TRD running boards/skid plate
    Same issue, I've had the OEM and switched to the identical MX4 after the recall. BOTH leaked like crazy. I'm not in a high rain state, but my bed is soaked every rain and I've had some stuff ruined. Would love recommendations for more rain-proof options.
  23. Jun 4, 2024 at 12:07 PM
    ChucklesToy
    ChucklesToy Retired
    Chuck
    Georgetown , TX
    Me too. MX4 for sale CHEAP! DiamondBack SE being delivered Monday.
    chavey2 likes this.
  24. Jun 6, 2024 at 8:23 AM
    BLCKBIRD
    BLCKBIRD New Member
    Carlsbad, CA
    Big fan of my BAK MX4. Easy enough to fully take off which was a big factor in my choice. Love that you can also use the third brake light camera with it fully flipped up.
  25. Jun 6, 2024 at 8:49 AM
    Tom976
    Tom976 New Member
    Tom
    I have the Lomax too. Great cover no issues so far so thats a plus.
  26. Sep 16, 2024 at 4:09 AM
    11CMGray
    11CMGray New Member
    Im looking for a new cover for mine, my last tundra had the Bak flip (not sure if it was the mx4)
    I thought it was great and utilized the full flip up to the back window several times. It did let in a small amount of water but some weather stripping would have fixed that.
    Only thing I did not like was I lost the rail system for tie downs though, they did make a kit to relocate it, but for the price i think it should have come with it. From what ive seen there is no rail system relocation for our 3rd gens?
    Ive been looking more towards the Bak revolver, obviously does give full access to the bed but seems more than the traditional folding covers, any pros and cons for this from owners?
  27. Sep 16, 2024 at 6:07 AM
    FireFinder44
    FireFinder44 New Member
    Albany, OR
    2019 Super White Tundra TRD Pro
    Mostly stock TRD Pro
    I bought a Lomax Stance for factory bed rails to replace the Century/Leer fiberglass tonneau that was on it when I bought it. It went on just fine, the only issue I had was not having some surface prep for the bulkhead seal, and had to run into town to get some from an autoparts place. It folds up, and has a couple of things on the roof you have to stick on, and then a couple of bars that clip on to those things on the roof, and prevents the folded cover from resting against the glass or paint. I like it.
    11CMGray likes this.
  28. Sep 16, 2024 at 8:53 AM
    11CMGray
    11CMGray New Member
    Thank you
  29. Sep 16, 2024 at 9:45 AM
    Bnewman077
    I had the Bak MX4 and really liked it. Mine also leaked a little bit but not enough to bother me. I ended having it replaced under warranty because the brackets to hold it full open bent and wouldn't hold against the truck any more. I was able to have them replace it with the Revolver under warranty and I am so glad that I did. I like everything about the revolver more. If you frequently use the full bed, the revolver is much easier and when fully opened you can still see out the back window. I liked the MX4 but would highly recommend the Revolver. For what it's worth, both my MX4 and Revolver came with the relocation brackets for install so that wasn't an issue for me.
  30. Sep 16, 2024 at 9:59 AM
    11CMGray
    11CMGray New Member
    Good info, thanks. I'll probably wait another month and a half to see if there are any black friday deals and get the revolver. Only con I've seen is the fabric/ nylon can detached from the metal in hot climates, I'd typically find one used on fb market but I want to buy new for the warranty just incase as I'm in Florida
