Handloaders?
Discussion in 'Guns & Hunting' started by TRD Pro Rookie, May 25, 2018.
  1. May 25, 2018 at 3:13 PM
    TRD Pro Rookie
    TRD Pro Rookie [OP] New Member
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Any handloaders here? What calibers do you load? How much/often do you load? What press and other equipment do you use?
  2. May 25, 2018 at 6:13 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Yes
    300wm, 30-06, 6.5x55 & 260 mostly
    Not nearly as much as i would like
    Rcbs rockchucker press
    Rcbs chargemaster
    Prostar 190 likes this.
  3. May 25, 2018 at 7:41 PM
    ertlonggun
    ertlonggun New Member
    2013 Dbl cab grey TRD
    TRD air filter TRD air flow accelerator Dirty Deeds budget SS Exhaust Worx wheels Roadmaster active suspension (rear) P-3 brake controller 3” Toyotec lift w/ shackles 35” Nitto Ridge Grapplers
    Yes
    338 Lapua Mag
    300 Win Mag
    7mm Mag
    30-06
    270 Winchester
    6.5x55 Swede
    260 Remington
    25-06
    220 Swift
    223
    Pistol.
    RCBS Rock chucker
    Hornady Lock n Load progress press
    Load more in the summer, but load all year to facilitate my habit.
  4. May 25, 2018 at 7:46 PM
    I have dies for 41 mag, 357 mag, 22-250, 25-06, 30-06, .243, 7X57 Mauser. Pretty much RCBS all the way. Haven't reloaded for over a year but will be getting back into it before hunting season. 30-06
    Prostar 190 and Borgs like this.
  5. May 26, 2018 at 7:45 AM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Obviously it goes without saying here that just because someone reloads a certain caliber does not mean they actually own any guns themselves. I myself have never owned any guns. Guns are bad.
    I reload 223, 243, 308, 300wm, 300 ultra mag, 444 marlin, 8mm Mauser, 7.5 Swiss, 303 British, 38/357, 9mm, 40/10mm, 45acp, 45 colt, 44mag and probably others I can't remember.
    I run a Lyman Tmag 2 turret for precision stuff, a Dillon 550, and a Hornady Lock and Load auto progressive with case and bullet feeders. RCBS Chargemaster, Giraud power trimmer, Giraud Annealer, Dillon primer pocket decrimper,.......
  6. May 26, 2018 at 8:29 AM
    RCBS, Lyman
    Mainly reload for
    204
    223
    And my wildcat AR 6X6.8
    But also have dies for
    6.5 Grendel
    375
    45/70
    6.8 SPC II
  7. May 26, 2018 at 10:19 AM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I'm not sure I have a use for the 204. But anything going 4000 feet per second is sexy.
  8. May 26, 2018 at 10:51 AM
    PMG
    PMG New Member
    Do you guys have any informational websites or youtube vids ( sensoring assess) that you recommend for someone that wants to get into reloading?
  9. May 26, 2018 at 10:54 AM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    Sites:
    Snipershide
    24 hourcampfire
    Long range hunting
    Grab a few reloading manuals to compare data.
  10. May 26, 2018 at 11:17 AM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    All good stuff. For a book, I recommend The ABCs of Reloading. And then a good recope manual like the Lyman Reloading Manual.
    gosolo and PMG like this.
  11. May 26, 2018 at 11:19 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I used to shoot a lot and reload a lot. Less shooting now and my reloading equipment is all in storage.
    Shotgun:
    410, 20g
    Pistol:
    308
    38
    357
    9m
    44 special
    44mag
    40
    Rifle:
    223
    7mm rem mag
    30-06
    270
    6mm rem
    Mostly use RCBS stuff. Chrono loads for speed, developing accuracy. Regularly getting 100yd groups in a dime off the bags on a bench with the AR. Peaceful hours spent reloading, very therapeutic.
  12. May 26, 2018 at 11:25 AM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Agreed. Very enjoyable. Cheap. More accurate.
    gosolo and Black Wolf like this.
  13. May 26, 2018 at 11:53 AM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    I always liked to work my way through various bullets and powders with a new gun and with careful shooting off the bench, I could determine the limitations of the gun. After that, when my shooting was less accurate, I knew it was all me: breathing, heartbeat, excitement, coffee, flinch or too big of a hurry.
  14. May 26, 2018 at 5:04 PM
    Jason808
    Jason808 "Thrust you can Trust"
    2012 Platinum crewmax
    some books and manuals can get you started in a safe direction. But, if you have a good buddy that reloads already. Ask to watch and pick his brians!
    gosolo likes this.
  15. May 27, 2018 at 6:08 PM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    For anyone in the DFW area I'm happy to help setup in reloading.
    gosolo and Hondoman like this.
  16. May 27, 2018 at 7:35 PM
    mudslinger79
    mudslinger79 New Member
    Christopher
    Williamsburg, Va
    2006 Double Cab, Phantom Grey Pearl
    Leveled. 16x8 Pacer 164 wrapped in 295-75-16 General AT2. Flowmaster exhaust. K&N Cold air intake.
    45 ACP and .223 for me. Basic Lee single stage. Nothing fancy. Very, very basic. Slow process, but it occupies my mind very well.
    gosolo likes this.
  17. May 27, 2018 at 8:09 PM
    Cfincke
    San Antonio
    I have a Dillon 550 with every accessory but the case feeder, been loading on one for 10 years or so. Have setups for 300wm, 308, 300blackout, 223, 45acp, 45lc, 38, 9mm.
    mudslinger79 and gosolo like this.
  18. May 27, 2018 at 8:58 PM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I'm guessing you don't load extruded powders in the Dillon powder thrower?
  19. May 28, 2018 at 4:50 AM
    Cfincke
    San Antonio
    You are correct, the only round I use extruded powder is the 300wm using 7828 (now there is 7828 short cut that meters fine). I measure out every round on the RCBS powder dispenser. Takes a while but I only load 20-50 rounds at a time of 300wm. The flake pistol powders give me the most problems in the powder thrower and results in a +/- 0.1gr divination, but occasionally is worse, so I visuallycheck every round before placing the bullet on the case for the stage 3 operation.
  20. May 28, 2018 at 7:58 AM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    I do the same. It's possible to attach the Hornady thrower to the Dillon which has no problem with extruded powders.
  21. Jun 3, 2018 at 2:16 PM
    SMK Shoe
    SMK Shoe Not New Member
    Paul
    Central North Carolina
    2017 Tundra TRD DC
    Step Bars, Rear Swaybar, 2,000 Watt Amp, 2-10" Subs, new door speakers, De-Badged, Hondo vent mounts, Calipers, 6112/5100 shocks, SPC UCA's, Front bumper, Bed Bars, bed rack, Fuel Rims
    .380, 9mm, .38/.357, .40, .44, .45acp, ..454 casul, .22 Br, 6mm Br, 6.5mm BR, 7mm BR, .30 BR, .223, 6mm rem, .270 win, 7mm rem mag, 30/30, 30-06, .308, 300 win mag, 6.5x47 Lapua, .300 BLK OUT, .50 Beauwolf, 25-06, .25 Roberts. That I can think of, sure there are more.
    Equipment. 2x Dillion 650 ( tricked out), 1 RCBS turrent press, 1 Rock chucker, 2 RCBS partner Presses, 2 Lee Hand Presses. 2 Harrell powder measures and enough Sinclair equipment to sink a bass boat.
    I also cast most of the bullets that I shoot. Only jackets I usually shoot are in the 6.5X47 Lapua. Even have my AR's eating lead. Been doing the reloading and casting since before Desert Shield/Storm
    mudslinger79 likes this.
  22. Jun 3, 2018 at 5:22 PM
    Outbound
    Aaron
    Northern Alberta
    I reload (rarely) for 7mm Rem Mag. Mainly just did up some target loads for a fun shoot last year. I have dies for .223, .308, and .303.
    RCBS gear for me: Rockchucker press, Chargemaster Combo, Case trimmeer, Motorized case prep center...the works.
    I'm honestly thinking of selling all my stuff off. I've lost much of my interest in it. I don't mind the actual reloading process but the load work up drives me batty, even though it's shooting. I find it way to tedious. I also haven't shot since July of last year and haven't hunted in 6 years. When I do get back into shooting, it'll probably be with 9mm and .223 both of which I can buy cheaper than load. For long range stuff, at the amount I shoot, I'm better off buying a couple boxes of premium ammo and calling 'er good.
    landphil likes this.
  23. Jun 3, 2018 at 7:42 PM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    Wish you didn't live so far north, I would make you an offer on some of your tools.
    Outbound[QUOTED] likes this.
  24. Jun 24, 2018 at 2:38 PM
    Boosted4runner
    Boosted4runner Join the NRA please.
    WA
    2015 DC MGM TRD Tundra, Kings, 5.7, 2018 front end
    Resi Kings, 35” Trail Grapplers on 18” Methods, ICON Delta Upper Arms, Front-Runner bed rack, Yakima SkyBox16, 2018 honeycomb grill, 2018 LED headlights, plastidipped bumper covers
    This is my setup as well, minus the 550 and annealer (would love the annealer) and run a RCBS single stage for precision.
    The Giraud power trimmer is badass! :)
    Also use the stainless wet tumbling process - one of the best reloading upgrades imo.
  25. Jun 24, 2018 at 3:54 PM
    Antlers
    Antlers New Member
    Alaska
    2018 SR5 TRD Cement
    25-06, 270, 300win, 9.3X62, 9.3X74R, 376Steyr, 375H&H, 416Rem, 450/400NE, 500NE, ....I'm forgetting some. Used to reload for 30-06, 338win, 35Whelen....I'm forgetting some.
  26. Jul 26, 2018 at 7:39 AM
    snarkscarbine
    snarkscarbine New Member
    Alex
    Dallas
    2014 Silver Sky CM Ltd 4x4
    Bilstein 5100s Footwell LEDs Fold-A-Cover g4 elite TRD 18s
    I mainly reload 6mm Dasher and 6.5 Creedmoor. Adding .308 and .224 Valkyrie sometime later this year.
    I have stuff to reload .303, .243, .223, 9mm, etc, and about a zillion 20ga hulls laying around in case I get an itch to reload that for some reason, but I don't shoot any of those much.
    Forster Co-Ax, Chargemaster 1500. Started using short-grain rice to dry tumble, and it's working really well.
  27. Jul 26, 2018 at 12:57 PM
    TRD Pro Rookie
    Rick
    D/FW
    2016 TRD Pro
    Nothing major
    What shot shell reloader do you guys recomnend?
  28. Jul 26, 2018 at 3:44 PM
    Hondoman
    Hondoman New Member
    Jeff
    Dfw Texas
    2015 SR5 CM 4x4
    We always used mec when i was growing up. Not sure if they are good or not anymore.
  29. Jul 26, 2018 at 4:00 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    I load for my .223, wife’s .308, my 7mmRM, and my .338WM. The .338 is the only one it makes sense for on the basis of cost alone. The accuracy gained by custom loading to the rifle is worth it to me though, as is being able to cook up a cartridge unavailable commercially. For example, I load 130gr. Barnes TTSX’s for the wife’s Ruger M77 compact in .308, it’s a great little deer / bear rifle out to 300 yds, and IMHO, that bullet is a perfect match for it’s short barrel.
    I’ve got a Rockchucker kit with a RCBS case trimmer and tumbler to keep my OCD happy, and use Lee dies as I like their neck-sizing dies.
    I haven’t sat down and loaded anything in at least 2 years now though, and this reminds me I should be since I can do this while I wait for my injured hand to heal. Great idea to combat boredom.
  30. Jul 26, 2018 at 4:56 PM
    snarkscarbine
    Alex
    Dallas
    I don't actually load shotgun. I just pick up any high-brass stuff I shoot because I'm a hoarder.... I've heard mecs are great.
