Handling issues
Discussion in 'Wheels & Tires' started by boisetundra22, Nov 19, 2015.
  1. Nov 19, 2015 at 1:41 PM
    boisetundra22
    boisetundra22 [OP] New Member
    Reaching out to the Tundra community for any feedback on handling issues after adding tires and wheels.
    So I upgraded from 285/65R 18 Nitto MTs on the stock wheels to 33x 12.5 20 Toyo RT tires on 20 inch Fuel Wheels and I am not pleased with the way the truck handles. I wanted to see if anyone else was having issues or changes like this. So the issues I am having are stopping I have actually had the truck lock up in a skid in the rain. Granted I do brake pretty heavy but nothing like this has ever happened before. Also while cornering or starting out the tires break free very easily in the rain where before I had to romp on it to get traction control to kick in. Also on cornering I have had the rear end slide a little where I had never had that happen before. I do drive somewhat aggressive but it has made me a little nervous especially in the rain. It handles in the rain like it used to in the snow. What I am wondering if this is just normal for adding wider tires making the stance wider and adding some weight on each corner.
    Just wondering if this is pretty standard when you get wider tires and heavier wheels or if something might be off.
  2. Nov 19, 2015 at 1:46 PM
    Jack Burton
    Jack Burton New Member
    Little China
    2013 DC 5.7L TRD/OR
    Tires, Diamondback HD Tonneau w/ ATV Carrier
    Sorry, I don't have a good answer, but am curious to see where this goes. I'm planning to swap from my current Toyo MTs to RTs when these are worn out next year.
  3. Nov 19, 2015 at 5:17 PM
    15whtrd
    15whtrd Mr. Blonde
    What PSI are you running?
  4. Nov 19, 2015 at 5:32 PM
    15whtrd
    15whtrd Mr. Blonde
    I don't think those are the MS rating tires. They don't have a lot of siping
  5. Nov 19, 2015 at 5:36 PM
    LOTSOFTOYS
    LOTSOFTOYS Toyota Whisperer
    Jace
    Mile high
    2005 Tundra DBL cab
    Remember too, more aggressive tires have less rubber actually on the road. Less rubber means less traction on dry or wet roads
    15whtrd likes this.
  6. Nov 20, 2015 at 7:04 AM
    TruckLife900
    TruckLife900 I'd rather B hunting
    2013 White SR5
    Adding larger (heavier) wheels/tires adds rotational mass and contributes to some of your issues. In theory :homer: wider tires give more traction if the contact patch is greater. However in this case with a rugged terrain tire it's likely you're not increasing the contact patch.
  7. Nov 20, 2015 at 7:30 AM
    dandailey
    dandailey King Tundra
    Dan D
    Newport News Va.
    2015 TRD 4x4 DC Tundra 5.7 Blue Ribbon
    Bakflip Revolver X2 ,Nestahedition Firestalk antenna, TRD dual exhaust, WeatherTech liners, in channel deflectors, 20% tint front, Tundra bed mat.AFE pro dry s filter,SA XDM 3.8 compact 9mm., Wheel to wheel N-Fab 3 steps.Lamin-X yellow on fogs, Bilstein 6112's top setting, BFG KO2's 275/70-18.Pioneer HU, JL RD amp, Focal speakers everywhere.
    MT's may be good for wheeling through a stream , but they all suck on wet asphalt.
  8. Nov 20, 2015 at 9:22 AM
    Jack Burton
    Little China
    2013 DC 5.7L TRD/OR
    Purely in my own anecdotal experience, I've never had traction issues with the Toyo MT's on wet roads. This is the second truck I've ran them on (Taco before) and the factory siping seems to grip really well in the water. I am more concerned about the Toyo RT's with their harder rubber compound which is why I'm trying to get as many opinions/experiences with them as I can before making the shift.
  9. Nov 20, 2015 at 10:10 AM
    boisetundra22
    Current PSI is 35 and its odd to me that my old Nitto MTs were more grippy on wet pavement than Toyo RTs. The differences are wider tires and wider stance and it feels like I am driving on snow instead of wet pavement. I do drive pretty aggressive but I am nervous now about cornering and stopping in wet pavement.
