Hand - Bending Sheet Metal?
Discussion in 'General Tundra Discussion' started by RepeatPete, Dec 10, 2020.
  1. Dec 10, 2020 at 11:28 AM
    RepeatPete
    RepeatPete [OP] New Member
    Pete
    2008 Tundra SR5
    I am finishing up building a high clearance rear bumper and am preparing to cut my bedsides somewhere around this:
    I would love to cut the sheet metal a little lower than that line and then bend it back on itself - anyone done this? I think the straight cut edge looks a little unfinished. Edge trim is an option, but I don't love the idea of water sitting in the edge trim and potentially rusting away the metal.
    My two concerns with bending are that there is a body line running 2-3" along the bottom edge of the bedsides that I'd be bending across, and the paint. I know people use a heat gun to get the paint to be a little more flexible when rolling fenders, but I think I'm bending more than the paint can take.
    I'm a 100% body work newbie - any advice?
  2. Dec 10, 2020 at 11:56 AM
    Cubo55
    Cubo55 New Member
    2020 Tundra TRD Sport
    TRD Exhaust Radium PCV CC
    Make your finishing bed where the line is and then do a 90 degree bend to fold the cut edge facing the frame. Your paint is going to crack and flake off anytime youre makin abend like that. So you will have to sand prep and blend paint in that area.
    2mchfun, gosolo and RepeatPete[OP] like this.
  3. Dec 10, 2020 at 1:14 PM
    Sunnier
    Sunny
    San Diego, CA
    RepeatPete[OP] and 831Tun like this.
  4. Dec 10, 2020 at 2:51 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Might be in my build thread. I picked up new glass today so I'll be doing it again soon. On the 3rd gen there's different angle to deal with. I filled a portion where the bumper end is. Here's how I created a return to the bottom of thebedside cut.jpg cut to add strength.
  5. Dec 10, 2020 at 3:37 PM
    Sunnier
    Sunny
    San Diego, CA
    Well dang, that’s right, all you guys with badass “big Tundras” have 2nd gens. Gotta think of who has a 3rd gen and may have done their own fab’. :monocle:
  6. Dec 10, 2020 at 5:37 PM
    Hightide
    chadington von banks
    Abalama
    Magic School Bus
    Get a pair of these and take your time.
    Sunnier, Darkness and RepeatPete[OP] like this.
  7. Dec 10, 2020 at 6:59 PM
    RepeatPete
    Pete
    2008 Tundra SR5
    Mine is a 2nd gen, but @831Tun is a 3rd gen. Body lines are not that different, though. Thanks for calling out to the helpful people!
    I like that little bend, and probably adds a fair bit of strength. That came out looking really clean!
    That looks like the ticket!
    Thanks @Cubo55 for the first reply, looks like I need to learn how to blend paint now...
  8. Dec 10, 2020 at 7:57 PM
    831Tun
    Warren
    Santa Cruz
    '16 CM limited
    Mine is 3rd gen
    Sunnier[QUOTED] likes this.
  9. Dec 10, 2020 at 8:41 PM
    Sunnier
    Sunny
    San Diego, CA
    I get confused. I’ve spent a lot of time on the 1st gen page where Hand Model has convinced me, apparently, ‘there are only two generations’. :rolleyes:
  10. Dec 10, 2020 at 8:59 PM
    gosolo
    Ray (or maybe Dale)
    NW Oregon
    Some people nit pick this and say that since the only consequential change was some body style differences it’s not a “real” new generation.
  11. Dec 10, 2020 at 9:41 PM
    Darkness
    Darkness Allergic to white
    Luis
    All over SoCal
    The darkest
    It's really dark
    There is, the 2.5 gen guys got ripped off. :poking:
    Sunnier[QUOTED], Tundra2 and gosolo like this.
  12. Dec 11, 2020 at 3:13 AM
    bradleykd
    bradleykd New Member
    Brad
    Kentucky
    2016 Limited-BLACK
    Since you know you are going to have to touch up the paint anyway, I'd make little pie cuts at the seams before you fold it over. Use those little pliers that the previous guy said and a hammer to tap at the bend to keep it crisp. Tack your pie cuts back together after the bend and grind them smooth.
    Probably no body work needed. I'd just blend the paint line with some higher grit sand paper - maybe work your way up to 600 or something, then get you a rattle can from automotivetouchup.com. While you are at the site, check out their how-to videos for feather sanding and blending paint. It won't look perfect when it is perfectly clean after you are done, but give it time to get a little dusty. Where it is on the truck will hardly ever be clean. You won't notice it once there is a little dust on the truck.
  13. Dec 11, 2020 at 3:16 AM
    bradleykd
    Brad
    Kentucky
    2016 Limited-BLACK
    I love this project, by the way. You are doing awesome!
    RepeatPete[OP] and Sunnier like this.
  14. Dec 11, 2020 at 5:45 AM
    Cruzer
    Cruzer Wheeling Full Size
    Cruz
    Sunnyvale, CA
    I’m kinda in the same boat with cutting body panels, thanks for this great tip!
    831Tun and RepeatPete[OP] like this.
  15. Dec 14, 2020 at 12:59 PM
    RepeatPete
    Pete
    2008 Tundra SR5
    Fantastic advice! Thank you!
  16. Dec 14, 2020 at 2:33 PM
    Rubberdown
    Just my opinion. I would say that you need to grind all the paint an inch past where you are going to do the bend. draw your line with the sharpie. Only go to where the bumper kink is in the bed. cut that straight back to the bumper. Take a sheet metal seamer, do a little at a time to get your whole length bent. just 1/4 inch of a bend at a time or something. do the whole thing. Then put yourself a tape line, prime, and then hit it up with some bedliner. You will have a 1 inch stripe of bedliner, and a perfect bend.
    Does all that make sense? you're not going to be able to get a lip behind that bumper or whatever unless you do a little welding which is easy enough to do.
  17. Dec 14, 2020 at 3:00 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Hey Pete, I know you're documenting your bumper build. It would be great to see how you tackle and document this portion of it as well. :D
  18. Dec 15, 2020 at 5:47 AM
    bradleykd
    Brad
    Kentucky
    2016 Limited-BLACK
    No problem. Looking forward to seeing the finished product! Keep your little pie pieces from the outside corners, you're going to need one for the inside corner and the bottom. lol.
    Sunnier likes this.
  19. Dec 15, 2020 at 12:30 PM
    Terndrerrr
    Terndrerrr 923000 miles to go
    Music City
    6UR-FE
    I am one of those people! A mid-gen facelift does not a new generation make. See also: 5th gen 4Runners.
    See also also:
  20. Jan 20, 2021 at 6:56 PM
    RepeatPete
    Pete
    2008 Tundra SR5
    I’m home on paternity leave and had some time where everyone was napping so I decided to just go for it today!
    I laid out some painters tape and marked the ends where I wanted. For reference, 3.25” behind the wheel well lines up with the natural outline bend of the bedside and 11.25” below the taillight lines up with the bottom of my bumper.
    Then I used an old flexible sewing tape measure to make hash marks 1 inch below my original bend line. I connected the dashes and had a cut line.
    I put a 6” cutting disc on my 4.5” angle grinder (it was all I had, and it cuts like butter), and cut on the lower line.
    I made a few pie cuts on the major bends, and used the Harbor Freight 6” metal seamer/bender to bend the edge over 90 degrees.
    The forward pie cut will weld together nicely, but I’ll need a small piece to weld in the rear gap. And this is what I ended up with:
    I really need to finish welding the bumper and get it painted, and that last picture sure makes it look like I need bigger tires! :monocle:
    The only thing I’d change if I were to do this again is to buy the 3” metal bending pliers, not the 6”. There’s not a whole lot of edge, and the bends are tight.
    junior, MTRock, jewsNbrews and 2 others like this.
  21. Jan 20, 2021 at 7:32 PM
    Cruzer
    Cruz
    Sunnyvale, CA
    Did the paint crack at the bends?
  22. Jan 20, 2021 at 8:57 PM
    TXTundra2722
    2015 Black Tundra
    Definitely more to worry about bending it, just cut it off and add rubber liner
    Terndrerrr, RepeatPete[OP] and MTRock like this.
  23. Jan 20, 2021 at 9:31 PM
    RepeatPete
    Pete
    2008 Tundra SR5
    It did. I figured it would and already ordered the paint so I didn’t bend a little at a time or use any heat. Not sure if either of those things would have made a difference.
    The bigger section (washed out in the picture) I picked at, but you can see the thin crack at the bend line in the middle of the picture.
  24. Jan 20, 2021 at 9:33 PM
    RepeatPete
    Pete
    2008 Tundra SR5
    Definitely true. I like the more finished look of a bend, and wanted to add a little structural rigidity as well as a place to remount the support bracket.
    Those wheels and the 37 Coopers look amazing btw!
    TXTundra2722[QUOTED] likes this.
