Halogen to LED so worth it!!! $50 and worth every penny!
Discussion in 'Lighting' started by tennisfreak, May 26, 2020.
  1. May 26, 2020 at 7:25 AM
    tennisfreak
    tennisfreak [OP] New Member
    My 2019 Tundra had the stupid ugly low output stock halogen headlights.
    Always baffled me how you get awesome LED drl's but halogens for the actual headlamps!!???
    Anyways been cruising the forums and the internet for a long time now trying to find a replacement option.
    Absolutely did not want to buy entire new headlight housings as it was too much money.
    Saw a few led kits that had resistors or some kind of harness/wiring required.
    Almost pulled the trigger on this but the cost of some of these was upwards of $100.
    Then I saw this on Amazon for $50 and user reviews claimed they worked fine without a harness or resistor.
    Decided to roll the dice and try it.
    Works perfect!! Plug and play, literally.
    Beam pattern is perfect and road visibility at night is improved so much.
    https://www.amazon.com/gp/product/B07TQLK6SH/ref=ppx_yo_dt_b_asin_title_o02_s00?ie=UTF8&psc=1
    biebs96 likes this.
  2. Jun 16, 2020 at 6:57 PM
    Crashnrondo
    Crashnrondo New Member
    Ron
    Wisconsin
    How are you liking these after a few weeks? Did you have to re-aim your lights?
    Thanks
  3. Jun 19, 2020 at 5:42 PM
    tennisfreak
    I love these!!!
    They offered easily a 3x improvement in night time visibility on top of the pure white light.
    The beam pattern is great and I did not have to adjust my headlights. I have not had a single person flash at me indicating they are too high either.
    The high beam pattern isnt as good as stock but since my normal lights are so good now I dont really find the need to use the high beams anymore.
    I love these so much I bought the same brand for my fog lights and will be installing them tomorrow!
  4. Jun 20, 2020 at 2:31 PM
    Crashnrondo
    Ron
    Wisconsin
    Thanks for the update! Bummer about the high beam though, I use mine a bunch out in the sticks trying to avoid deer.
    Geo4x4 likes this.
  5. Aug 2, 2020 at 7:00 PM
    20SilverTundra
    20SilverTundra New Member
    Edinburg, TX
    2020 Silver Tundra TSS 4x4
    Good deal. Were they easy to install?
  6. Aug 2, 2020 at 7:49 PM
    BrandonL812
    BrandonL812 New Member
    Brandon
    2021 Tundra Platinum
    If you can remove the stock one, you can install these. There's nothing to worry about them. They are plug n play type bulb. Direct replacement.
  7. Aug 2, 2020 at 7:53 PM
    BravoDeltaRomeo
    Bruce
    MB Canada
    2019 Cavalry Blue Tundra CM
    You have to take the grille off. After that, it should be easy peasy.
  8. Aug 10, 2020 at 3:09 PM
    james33440
    james33440 New Member
    James
    2010 Tundra Double Cab
    Magnaflow Exhaust
    Can you post some pics or video clips of the output?
  9. Aug 10, 2020 at 5:05 PM
    lehminh
    lehminh New Member
    2016 Tundra SR5 CrewMax 5.7L 2WD Front Bench Seats
    Do they interfere with radio reception? I read that LED headlights sometimes interpreted with reception.
  10. Aug 10, 2020 at 5:40 PM
    BrandonL812
    Brandon
    None that i notice. I have led bulbs in 3 cars and havent notice any interference.
  11. Aug 11, 2020 at 6:29 PM
    lassiter1979
    lassiter1979 New Member
    Donnie
    NC
    2020 Tundra SR5 Crewmax 4x4 in Silver Sky Metallic with XSP Package
    3" front lift, 1" rear lift; BFG KO2 295/60R20; color matched front grille and hood bulge
    Ordered these, they arrived tonight at sunset. Didn't want to wait til tomorrow to install so ventured out into the 350% humidity night to do it. Got entire front end removed (including fender well molding) and headlight assembly out only to find that AMZ shipped me wrong item. :annoyed:
    BrandonL812 likes this.
  12. Aug 11, 2020 at 6:47 PM
    BrandonL812
    Brandon
    well, dang diggity dog, that just suck big time. I can only imagine the frustration. But atleast you can take the front end off super quick next time, right? not all is lost.
