halogen to led replacement
Discussion in 'Lighting' started by guccigarcia, Oct 8, 2024.
  1. Oct 8, 2024 at 12:34 PM
    guccigarcia
    guccigarcia [OP] New Member
    Cristian
    Elizabeth, Colorado
    2017 QS Tundra SR5
    have a 2017 sr5. Is it possible to just buy led bulbs and change out the halogen bulbs without needing to buy whole new led units for the headlights and fog lights?
  2. Oct 8, 2024 at 12:48 PM
    frichco228
    frichco228 Valued Member
    2016 Crewmax 4WD, TRD Offroad
    It is possible to just replace the bulbs but you probably wont be happy with the results. And some LED bulbs will have hyperflash issues and need resistors. Then there is the fact that the halogen housings you have are not meant for LED bulbs, so the light output pattern will not be right.
    Best bang for the buck is to switch to the factory TRD Pro LED headlights, and you will need the harness from @iHacker
    It is a great upgrade and worth the money.
    BIGUGLY likes this.
  3. Oct 8, 2024 at 1:02 PM
    guccigarcia
    Cristian
    Elizabeth, Colorado
    2017 QS Tundra SR5
    Does that go for just headlights or both head and fog?
  4. Oct 8, 2024 at 1:12 PM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    The hyperflash applies only to turn signal lights - steer clear of putting non-OEM LEDs there and that issue won't exist. Some of the better brands have designed their LEDs to work in conjunction with halogen reflectors - the bulb just needs to be oriented (rotated) to take advantage of those and all is better than before.
  5. Oct 8, 2024 at 1:12 PM
    frichco228
    That is the headlights. I did the same swap.
    For the fogs, you can swap for factory LEDs too or there are nice aftermarket led fogs. Or just do bulbs for the fogs, they usually fare better with LED bulb replacement vs for the headlights when it comes to issues or bad light pattern.
    When I installed the LED headlights, I just swapped some LED bulbs into the stock fog light housings and have had good luck. I used auxbeam, they have been fine and match the color of the headlights and light pattern is good. Just use quality bulbs vs something off ebay.
  6. Oct 8, 2024 at 1:18 PM
    guccigarcia
    Cristian
    Elizabeth, Colorado
    2017 QS Tundra SR5
  7. Oct 8, 2024 at 1:20 PM
    guccigarcia
    Cristian
    Elizabeth, Colorado
    2017 QS Tundra SR5
    If I try replacing the bulb for the headlight it would just be for the beam not the turn signals. Figured this could hold me over till i save up for the whole swap later on
  8. Oct 8, 2024 at 1:32 PM
    Rodtheviking
    Rodtheviking New Member
    Vancouver, WA
    Sequoia
