Halogen bulb
Discussion in 'General Tundra Discussion' started by 1Tundra5, Dec 8, 2024.
  1. Dec 8, 2024 at 5:27 PM
    1Tundra5
    1Tundra5 [OP] New Member
    Junior
    2015 White SR5
    Is there a halogen bulb that’s really bright? I think the LED bulbs I installed is causing hyperflash, when I turn the turn signals on and it’s driving me crazy. I’m about to go back to halogen but looking for a good one.
    Parrothead_DFW likes this.
  2. Dec 8, 2024 at 5:59 PM
    You need a resistor. If you want good quality and bright leds for turn signals, many of us have the Vleds V6 Tritons.
    1Tundra5[QUOTED][OP] likes this.
  3. Dec 9, 2024 at 2:27 AM
    1Tundra5
    Junior
    2015 White SR5
    Sorry, I forgot to add that I already have those. Do you think they went out?
    Or can they go bad? Didn’t have them that long, before they started hyperflashing. Almost a year. Don’t think that’s that long for a resistor to go bad, but I’m not at all an expert
  4. Dec 9, 2024 at 2:31 AM
    They are the V6 Tritons with the black box resistor? Front or rear? Is the front and rear signals all led?
  5. Dec 9, 2024 at 2:54 AM
    1Tundra5
    Junior
    2015 White SR5
    Sorry for not being clear. I already have some resistors. Everything was fine for a while, then one randomly started hyperflashing then it was okay, then the other side did it, but then it worked fine. Now both left and right headlight c ring hyperflash when using turn signals. Instead of it being sequential, it’s like a rapid blink; now. It’s only the fronts that I’ve changed. I swapped the regular SR5 headlights (non DRL) housing to some that have the DRL and have the sequential turn signal. I took out the halogen bulb that came with the new headlights and installed a Lastfit LED bulb. Hope this is more clear
    thinking about just going back to halogen because not sure how much more I can take knowing something is not working like it should. :annoyed:
  6. Dec 9, 2024 at 3:36 AM
    Johnsonman
    Johnsonman New Member
    Austin
    Sequoia
    I use LEDs everywhere Except the turnsignals. Yet if you want some of those SuperBright LEDs has them - not cheap.
    1Tundra5[OP] likes this.
  7. Dec 19, 2024 at 7:24 PM
    kbahus
    kbahus New Member
    MI
    2015 MGM Tundra Limited Crewmax
    I am using Vosla brand halogens in my Camry. They are impressive but it’s an H11 bulb in a totally different housing so I can’t fully compare. I tried the LED route and went back to halogens, worth it for me. Vosla is a legit European bulb.
    They have these in an H4: https://www.ebay.com/itm/176359088570?_skw=vosla+h4&itmmeta=01JFH19G5XAHKXQ8WN7TTE0PFJ&itmprp=enc%3AAQAJAAAAwHoV3kP08IDx+KZ9MfhVJKlzBAYDwqhqqmXAFZd4l9A5PC%2FlVCp5xqxtg1ik6ZnayIcIm3FLa07et6GSJg5HI41tQWEtJyKg9biyFOwyXrUE+TmZ3nsCJs+4QZNB7CQgqCDlX--SbWdkaK2R2VE0098wC+os6wVMF8Acvmquz53Yvf5N9+SWoXs+v9PDIIVPNAwIXQUYZ9Q4TAVPMeFmIBZNPPrCrC8RkirGR5AFnBmUZZmqCvGzddM0+Q3cpknBEg%3D%3D%7Ctkp%3ABlBMUJSDpqH8ZA
