Halo light Addition to running lights
Discussion in 'Lighting' started by JerryB4701, Aug 5, 2019.
  1. Aug 5, 2019 at 1:57 PM
    JerryB4701
    JerryB4701 [OP] New Member
    Jerry
    2007 Tundra crew max
    Led headlights with halo rings and led running lights
    i installed new headlight assemblies into my 2007 Tundra crewman today. The assembly has Harlow rings and LED upper running lights always on. While connecting to the front side running light drivers side I inadvertently ground my positive lead and lost power to both side lights. I cannot find a schematic online for these running lights! I checked every fuse in the engine compartment and reviewed fuses below dash on drivers side per the service Manuel. I can find no blown fuse in engine compartment and no reference to fuse for running lights on page 584 of owners Manuel. Is there a relay I could have damaged. Without the schematic I am really in the dark. Help in getting the schematic or insight into the circuit would be most appreciated.
  2. Aug 5, 2019 at 6:13 PM
    JerryB4701
    Jerry
    I got the Halos working but the led lights although part of the same connection are not lit
  3. Aug 5, 2019 at 6:39 PM
    Welcome from NY.
