Half my engine died, P0300, 301, 303, 305, 307, P0016, P0017
Discussion in '2nd Gen Tundras (2007-2013)' started by KissMyAxe1, Jul 19, 2021.
  1. Jul 19, 2021 at 9:59 PM
    KissMyAxe1
    KissMyAxe1 [OP] New Member
    Utah
    2008 Black Tundra SR5 Crewmax
    Lots of codes for basically bank 1 of the engine, all cylinders misfiring on that side, both A and B camshaft sensors saying problems. It ran fine last week, started it up this weekend and it was idleing rough and all these codes popped up. I'm guessing either a rodent got in there and chewed through a ground wire on that side, or the timing chain skipped a tooth. Thoughts? Places you might look first? (Also, is that the drivers side of the engine?)
    I just got done replacing head gaskets on my GF's subaru, and I'm not really financially keen on doing another overhaul quite so soon. If I can't find any wires that look chewed up or loose, any other thoughts on issues? Or if I have to replace the timing chain, what else should I consider replacing while in there? It does have almost 280k miles, the timing chain seems to rattle when first staring up, so I think it could be safe to assume it's looser than it should be.
  2. Jul 19, 2021 at 10:33 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Driver side is odd numbers cylinders
    KissMyAxe1[OP] likes this.
  3. Jul 19, 2021 at 10:34 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    Check that side wires first
  4. Jul 19, 2021 at 10:46 PM
    empty_lord
    Indiana, Chicagoland
    05 rollover special
    Which engine you got? The camshaft correlation would have me worried about timing having skipped, or a failing oil control valve if it’s a 5.7
    inspecting wires near the cam sensor would be the first step
  5. Jul 20, 2021 at 7:04 AM
    KissMyAxe1
    Utah
    Its the 5.7. I'm really hoping its not a timing chain issue, but I kind of feel like it is.. I don't knowbmuch about oil control valves, ill have to look that up.
  6. Jul 20, 2021 at 7:47 AM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    78E9572C-7401-46E8-83F8-FB013FE51F24.jpg The chain don’t cost that much, but the labor is very intensive.E2763A76-ECEE-4960-810F-5A731F196F8D.jpg
  7. Jul 22, 2021 at 6:31 PM
    Dalandshark
    Dalandshark Infected with 5G
    Northwest
    2007 Tundra SR5 5.7 Longbed
    Eibach Level LIft
    I would look at things common to that side of the engine, like the fuel bank. Sure could be timing thing but if you didn’t hear anything unusual before it threw codes I bet it’s wiring related.
    Have you figured it out yet @KissMyAxe1 ?
  8. Jul 22, 2021 at 6:49 PM
    KissMyAxe1
    Utah
    Not yet, haven't had much of a chance to look through the wiring. I started it remotely, so I heard it fire up, and nothing unusual, but I was in the house, so I could've missed something. It doesn't sound bad, but I can definitely hear it's not running like its normal self. A quick glance under the hood and I didn't see anything out of place. But I haven't looked at any of the hard spots, like behind the engine or underneath. Could be a wire loose or something back there. Theres some spider webs in there. Long overdue for a detail, inside and out.
  9. Jul 22, 2021 at 6:51 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
    If not just take the drive side valves cover off and see if the chain is lose
  10. Jul 22, 2021 at 8:45 PM
    KissMyAxe1
    Utah
    Ooh, that's a good idea!
  11. Jul 24, 2021 at 10:45 AM
    KissMyAxe1
    Utah
    I'm not seeing any wire damage anywhere. No trace of critters camping out in the engine. So I took the valve cover off, probably could use new spark plugs, and for having just about 280k miles, I'd say things look pretty good in there. I'm no expert, but the chain seems really loose. I'm pushing on it with a pry bar, but it takes very little effort to move the chain around, even pull it up a bit. Like the tensioners are totally worn out. I'm thinking its very possible the chain skipped a tooth.
    TheBeast likes this.
  12. Jul 24, 2021 at 12:19 PM
    empty_lord
    05 rollover special
    Failed tensioner
  13. Jul 24, 2021 at 12:46 PM
    Winning8
    Winning8 New Member
    Da Bay Area
    2019 MGM DC 4x4 SR5
  14. Aug 21, 2021 at 2:17 PM
    KissMyAxe1
    Utah
    Finally had some time to tear into this, got the timing chain off. All the tensioners feel super loose, but especially the drivers side tensioner on the main chain. The tensioners for the cam gears also felt really loose. I'm getting everything all cleaned up, get the timing reset and the chains on. I did check in the spark plug tubes, the valves never hit the pistons, thankfully. Everything looks pretty alright in there.
    You can see the old drivers side chain guide is missing a fair amount of the plastic on there. I found the top piece, but I'm missing the rest of that, so who knows what happened to it.. lol Maybe the rest will turn up as I'm cleaning things out.
    You can see the tensioner is not holding any pressure on the chain guide, but even the cam gears had a similar problem, all very loose!
    Organizing the timing components.
    MTRock and Winning8 like this.
