H11 LED Fogs Stopped working
Discussion in 'Lighting' started by DossEfx, Sep 21, 2019.
  1. Sep 21, 2019 at 9:30 AM
    DossEfx
    DossEfx [OP] New Member
    Hi guys I really need your help... I was trying to do an LED conversion for headlights and fog lights. The headlight conversion to LED bulbs went just fine and they work fine now ,however, when I replace the fog lights with LED H11 bulbs they worked for about a week, now they don't work and the Amber indicators do not work when I turn on the headlights I tried replacing the LED H11 fog lights with the original bulb and the originals do not work now, I checked all fuses and they're good. Also usually the LED strip lights under the headlights would get dimmer when in park... That no longer happens....HELP!! 2017 XSPX
  2. Sep 21, 2019 at 9:44 AM
    robz
    robz New Member
    Rob
    2015 Platinum 2WD
    Full interior LED lights. Bed cover. OEM LED Headlights and Fog lights
    did you check your relays?
  3. Sep 22, 2019 at 7:09 AM
    DossEfx
    No, going to check those... Thanks!
