GROUP BUY ON SONY 6 CHANNEL AMP WITH BUILT IN DSP
Discussion in 'Deals & Group Buys' started by james@tech12volts, Feb 13, 2020.
Thread Status:
Not open for further replies.
  1. Feb 13, 2020 at 1:46 PM
    james@tech12volts
    james@tech12volts [OP] tech12volts.com INNOVATIONS IN AUDIO ! Vendor
    james
    OK so i have been testing 2 of these amps for a couple of months now and I am impressed. Who would be interested in group buy for one if i could save you 75 dollars from the posted price in this link? I need 10 confirmed purchases to be able to do this . The amp will run your entire system plus subs . and you can Bluetooth music straight to it also which is super clean. If you want one please email me . I can set you up with all parts you need also including amp rack , harnesses and so on . It will not work with the factory jbl head unit unless you do a dsr1 also. Again 75 dollars off from the price posted on this link . email me tech12volt@gmail.com Please do not send me a PM here . Thanks
    https://www.sony.com/electronics/car-amplifiers/xm-gs6dsp
    update this a go https://www.shop.tech12volts.com/product.sc?productId=583&categoryId=137
    ManoTundra likes this.
  2. Feb 13, 2020 at 4:00 PM
    bmann7
    bmann7 Silver Sky Platinum Pro
    WA
    2019 SSM Tundra Crewmax Platinum
    See signature line
    DSR1 ??
  3. Feb 13, 2020 at 4:03 PM
    james@tech12volts
    james
    idatalink dsr1 processor if you have the factory jbl system only
  4. Feb 13, 2020 at 8:42 PM
    james@tech12volts
    james
    No interest?
  5. Feb 13, 2020 at 10:24 PM
    InfernoPRO
    InfernoPRO Technicolor BASTRD
    Scott
    Sacramento
    2015 Inferno TRD PRO
    Sent you an email!
  6. Feb 14, 2020 at 12:26 AM
    SouthWestGA
    SouthWestGA New Member
    Dang JBL
    JBL should stand for “just bad luck”
  7. Feb 14, 2020 at 8:25 AM
    LogCabins
    LogCabins Professional Procrastinator
    'Merica
    2017 TRD Pro
    Email sent
  8. Feb 14, 2020 at 9:06 AM
    james@tech12volts
    james
    have not seen it.
  9. Feb 14, 2020 at 9:07 AM
    james@tech12volts
    james
  10. Feb 14, 2020 at 9:12 AM
    shawn474
    shawn474 Lego connoisseur
    MoCo, Maryland
    James,
    I currently have the taco tunes plug and play harness and amp. If I were to switch over to this amp, could I use the taco tunes plug and play harness and amp rack to connect this amp? Just trying to see what I would need to switch to this amplifier.
  11. Feb 14, 2020 at 9:20 AM
    james@tech12volts
    james
    You could but I wouldnt . A car audio amp should never be mounted to metal. The harness not sure. never used one of theirs but we use a loc with this amp and I think they use high level inputs
  12. Feb 14, 2020 at 9:25 AM
    purplenova
    purplenova Not a new member
    Tom
    Ohio
    2016 Tundra Crewmax SR5
    James - Whats the reasoning behind not using metal amp rack for mounting?
  13. Feb 14, 2020 at 9:29 AM
    james@tech12volts
    james
    Do not bolt your amplifier directly to your car's metal chassis — that's inviting noise problems, like ground loops which hum or buzz. You could use rubber grommets around the mounting screws to isolate the case.
    Which is exactly what mounting it to a metal amp rack is doing .
  14. Feb 14, 2020 at 9:39 AM
    purplenova
    Tom
    Ohio
    I actually have that other guys mounting rack with my kenwood amp and Audiocontrol LOC mounted to it.
    Looks like Im going to lowes this weekend to get some rubber grommets.
    Thank you Sir !
  15. Feb 14, 2020 at 9:48 AM
    InfernoPRO
    Scott
    Sacramento
    Hmm, tried again. Your email is volt or volts?
  16. Feb 14, 2020 at 12:19 PM
    james@tech12volts
    james
  17. Feb 14, 2020 at 12:24 PM
    shawn474
    MoCo, Maryland
    Me too!!!!
    purplenova[QUOTED] likes this.
  18. Feb 14, 2020 at 3:58 PM
    james@tech12volts
    james
    so i have this amp on shop bench right now . its playing some old components and jl 10w6v3 through bluetooth on my phone . no head unit at all and this thing is cool as hell!!!!!!!!!!!!!!!!!! I will get a video of it in a little bit. My power supply is small but this thing does killer !! I am extremely impressed with it as a straight bluetooth amplifier . With the sony app you can turn it up and down
    ManoTundra, LogCabins and purplenova like this.
  19. Feb 19, 2020 at 5:16 AM
    LogCabins
    'Merica
    2017 TRD Pro
    Bumping this up in the case some of you are on the fence about audio upgrade....killer deal, from hands down the BEST vendor!
    Anxiously awaiting the arrival of mine, along with the JL dual 10s and custom ported box from James :headbang::goingcrazy:
  20. Feb 19, 2020 at 5:34 AM
    Ob1
    Ob1 New Member
    Wow, great deal on an awesome amp. As usual, deals like this only pop up when I'm done upgrading.
  21. Feb 19, 2020 at 6:45 AM
    LogCabins
    'Merica
    2017 TRD Pro
    Would love to see the video of it.....if you get a chance :)
  22. Feb 20, 2020 at 1:58 PM
    james@tech12volts
    james
    I am trying to get it to download
    LogCabins likes this.
  23. Feb 20, 2020 at 2:55 PM
    LogCabins
    'Merica
    2017 TRD Pro
    The email file you sent was like a 2 second clip....wonder if it has to be posted to YouTube then link it :confused:
  24. Feb 21, 2020 at 9:47 AM
    james@tech12volts
    james
  25. Feb 21, 2020 at 9:53 AM
    LogCabins
    'Merica
    2017 TRD Pro
  26. Feb 28, 2020 at 7:48 AM
    LogCabins
    'Merica
    2017 TRD Pro
    If anyone has purchased this amp... this pic may help (Non-JBL w/ LOC) this is the LOC -> RCA -> Sony AMP Line In Harness connection
    purplenova likes this.
  27. Mar 4, 2020 at 8:28 AM
    LogCabins
    'Merica
    2017 TRD Pro
    Just posting to post I guess, but was bored and figured I could maybe help the next guy...for a NON-JBL keeping your stock HU, here is a quick "easy" reference for your wiring. See pic I posted above on how the LOC will be wired. I must say this AMP is awesome and I am loving it so far!
  28. Mar 4, 2020 at 8:33 AM
    Blueribbon504
    Blueribbon504 New Member
    Blake
    2015 Blue Ribbon Tundra SR5 TSS
    Can this amp replace the stock amp under the passenger seat?
  29. Mar 4, 2020 at 8:37 AM
    LogCabins
    'Merica
    2017 TRD Pro
    That's exactly what it does....any amp can replace the factory amp as long as you have the correct harness to convert your factory signal from stock HU to RCA outputs...also differences in if you are JBL or NON-JBL...are you keeping stock HU or going with aftermarket (kenwwod, alpine, pioneer, etc...)
  30. Mar 4, 2020 at 8:42 AM
    Blueribbon504
    Blake
    keeping stock at the moment but eventually I am going to replace it. NON-JBL
Thread Status:
