Ground Wire?
Discussion in 'General Tundra Discussion' started by rodl12, Dec 1, 2023.
  1. Dec 1, 2023 at 6:07 AM
    rodl12
    rodl12 [OP] New Member
    Rod
    South Jersey
    2017 Tundra SR5 Double Cab
    I was under my truck greasing the transfer case drive shaft u-joints and I saw this broken ground wire. Can anyone tell me what it is suposed to connect to? TIA IMG_6764.jpg
  2. Dec 1, 2023 at 6:12 AM
    BlueRibbon4x4
    Geno
    2015 Blue Ribbon 4x4
    It’s in the picture, right behind it dude!
  3. Dec 1, 2023 at 6:14 AM
    BlueRibbon4x4
    Geno
  4. Dec 1, 2023 at 6:17 AM
    texasrho83
    texasrho83 Old Member
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  5. Dec 1, 2023 at 6:18 AM
    Just need to order a new one and reconnect it here
  6. Dec 1, 2023 at 6:24 AM
    texasrho83
    Charles
    Conroe TX
    2016 DC MGM 4x4
    See build link
  7. Dec 1, 2023 at 7:08 AM
    rodl12
    Rod
    South Jersey
    Sometimes smonthing is rght in front of you and you don't see it. But in my defense I did look for it when I was under the truck and couldn't see anything. Maybe the camera exposed it. What is it a ground for and where can I get one to replace this one?
    BlueRibbon4x4[QUOTED] likes this.
  8. Dec 1, 2023 at 7:16 AM
    BlueRibbon4x4 likes this.
  9. Dec 1, 2023 at 7:19 AM
    rodl12
    Rod
    South Jersey
  10. Dec 1, 2023 at 7:35 AM
    If 10” of ground strap will reach, then yes.
  11. Dec 1, 2023 at 1:07 PM
    BlueRibbon4x4
    Geno
  12. Dec 2, 2023 at 4:39 AM
    rodl12
    Rod
    South Jersey
    It measures around 7 or 8 inches.
  13. Dec 2, 2023 at 6:43 AM
    BlueRibbon4x4
    Geno
    That ground is a popular one that needs replacement due to damage. It can make your transfer case actuator act funny, it was a recommended to me to look for a damaged one when my actuator was not working.
  14. Dec 2, 2023 at 8:07 AM
    rodl12
    Rod
    South Jersey
    I do have a problem with my actuator that may be attributed to a bad ground. Sometimes when I turn off the 4wd nut the light stays on so I have to shut off my truck and restart it for it to go out.
  15. Dec 2, 2023 at 8:27 AM
    Replace and report back!
  16. Dec 2, 2023 at 8:33 AM
    rodl12
    Rod
    South Jersey
    Yes Sir!
  17. Dec 2, 2023 at 9:02 AM
    BlueRibbon4x4
    Geno
    Yeah this would be awesome to know if it resolves any issues.
    KNABORES likes this.
  18. Dec 2, 2023 at 9:16 AM
    More of an excited request, wasn’t yelling at you:rofl::rofl:
    many come with issues, and after discussing possible solutions, never report back to the hive mind for confirmation of problem resolution. Help the next guy out!
  19. Dec 2, 2023 at 12:55 PM
    rodl12
    Rod
    South Jersey
    That's okay I do understand but I might be the exception. I'm a firm believer if we all share we all get better.
  20. Dec 2, 2023 at 5:17 PM
    Jowett
    Jowett New Member
    North Adams, MA
    2011 Regular cab long bed 5.7 Work Truck Package
    Many on the way.
    Dealer $9 - $13 90980-A7012
    Be cautious when undoing the body mounted stud.
  21. Dec 3, 2023 at 4:20 AM
    rodl12
    Rod
    South Jersey
    What should I look out for?
  22. Dec 3, 2023 at 4:21 AM
    Corroded bolt breaking. If it does, you can drill it out and replace with similar sized self tapper.
    rodl12[QUOTED][OP] likes this.
  23. Dec 3, 2023 at 4:29 AM
    rodl12
    Rod
    South Jersey
    Thanks, I'll spray it then before I try and remove it.
  24. Dec 3, 2023 at 5:14 AM
    Zebruaj
    Zebruaj New Member
    MN
    08 CM SR5
    I should probably replace mine too. It's been gone for who knows how long (and I've known it needs to be replaced).
  25. Dec 3, 2023 at 6:26 AM
    Jowett
    Jowett New Member
    North Adams, MA
    Many on the way.
    The M6 stud that welded to the body is the tricky one. Scrub the rust from the exposed section of stud and the hose it down with penetrating oil. Worst case is that it breaks off, then another location with a longer strap can be utilized.
    rodl12[OP] likes this.
  26. Dec 3, 2023 at 6:30 AM
    rodl12
    Rod
    South Jersey
    That's my plan!
  27. Dec 4, 2023 at 10:58 AM
    rodl12
    Rod
    South Jersey
    I repaced my ground strap today and as of now I have no problem switching in and out of 4wd with the acturator staying on as previously mentioned. I' don't know if anything else this may have affected but hopefully it is resolved.
    KNABORES and Zebruaj like this.
  28. Dec 4, 2023 at 11:03 AM
    Glad to hear this fixed your problem and thanks for letting us know.
  29. Dec 4, 2023 at 12:09 PM
    rodl12
    Rod
    South Jersey
    Glad for the help I get here and vice versa.
  30. Dec 4, 2023 at 12:11 PM
    This will be added to the “my 4x4 actuator isn’t working right” algorithm.
