Ground for Head Unit
Discussion in 'Audio & Video' started by mistert, Apr 23, 2020.
  1. Apr 23, 2020 at 6:28 AM
    mistert
    mistert [OP] New Member
    Michael
    '16 Tundra TSS Offroad
    Rack with LED lights, carbon fiber wrap, bumper with winch, rear bumper, lift, and Moto Metal tires.
    I am getting alternator whine coming through the speakers and unplugging the RCAs doesn’t make it go away.
    I have 3 harnesses coming from the Metra wire kit for the head unit, Axxess steering wheel controls, and another for the back camera harness adapter. I was advised to ground the head unit to the chassis. Where is the best place to do this? I don’t see any good places with the radio removed unless I just ground it to the back of the stereo. I have an Alpine ILX-W650.
    BTW, I have moved the grounds from the amp to another location which did nothing. RCAs are run opposite side of power and ground. I have a set of RCA ground loop isolators that I connected to a 4 channel JL Audio amp that did nothing.
    I believe the noise is coming from the ground from the head unit because I have it and the adapter grounds all going to a single ground of the Metra wire harness. Is there a place in the dash that would be a good grounding point?
  2. Apr 23, 2020 at 6:43 AM
    spdrcer26
    spdrcer26 New Member
    Bakersfield, CA
    2017 Crewmax
    Make sure on your ground from your amp that it is connected to raw metal on your chassis if there is paint grind it away- I had the same problem and this is where my issue was-
  3. Apr 23, 2020 at 9:24 AM
    mistert
    Michael
    Yes I sanded the ground site down where I have my amps grounded. The issue is near the head unit. I think if I can find a good ground site, it will eliminate the issue. I think it’s from having so many adapters connected.
