Ground Connection
Discussion in 'General Tundra Discussion' started by kurtwp, Jul 13, 2017.
  1. Jul 13, 2017 at 2:13 PM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    2016 Tundra Limited TRD 4x4 Off Road DC
    I can use the bolt highlighted as a place for grounding. This is behind the driver door kick panel.
    Kurt
  2. Jul 13, 2017 at 3:34 PM
    Over the LINE
    Over the LINE New Member
    New Orleans
    2016 Limited CM 4x4 2025 SR5 CM 4 x 4
    Can you?, I don't see why not. Basically any time you see a bolt with wires attached to the metal body of the truck, it is a ground. I grounded to the same place for my dash switches and used the same type spot under the hood for all my lighting relays.
    dcsleeper408 likes this.
  3. Jul 13, 2017 at 4:20 PM
    1UPPER
    1UPPER Not A New Member
    TEXAS
    Flux capacitor!
    What are you trying to ground? How long is your grounding wire?
  4. Jul 13, 2017 at 6:59 PM
    PMG
    PMG New Member
    Yes
  5. Jul 14, 2017 at 4:40 AM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    I am just grounding a 4w CB radio from under the seat . The radio wires that came with it reach the nut.
    Yes a CB to keep the other passengers in the Tundra distracted from their cell phones. Don't need them sucking all the
    data during a long trip.
    Maybe the kids can annoy a ORT to the point I can shoot a remake of Dennis Wearver's Duel.
    Kurt
  6. Jul 14, 2017 at 4:58 AM
    Tundraplatinum
    Tundraplatinum New Member
    2016 Platinum CM
    That's a great ground to use just make sure you tighten it up good. Looks like main ground location for dash so if it gets loose your truck will act possessed
    NewImprovedRon likes this.
  7. Jul 14, 2017 at 5:11 AM
    1UPPER
    TEXAS
    Flux capacitor!
    Yes sir you should be good to ground your CB on that point. I was just making sure you weren't running a long wire for something like a stereo amp.
  8. Jul 14, 2017 at 5:36 AM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    @1UPPER Well I finally made a decision on the ham rig I am going to buy. Its the Kenwood TM-V71 which is 50watts. That I will be connecting directly to the battery using a 20amp fuse. I figure 10ga wire should be fine to handle the draw. Maybe I'll drop the fuse down to 15. Suggestions?
  9. Jul 17, 2017 at 2:13 PM
    kurtwp
    kurtwp [OP] What
    Kurt
    Charlotte, NC
    well I checked the manufacture web site and it has this for reference:
    Current Drain
    Transmit VHF HI Less than 13.0A
    MID Less than 5.5A
    LOW Less than 4.0A
    UHF HI Less than 13.0A
    MID Less than 6.5A
    LOW Less than 5.0A
    Receive Less than 1.2A (at 2W audio output)
    Kurt
  10. Feb 2, 2023 at 5:52 AM
    Big Gray
    Big Gray New Member
    4X4
    Hey,
    Looking for a good grounding location under hood passenger side for Firestik FG4-648-B?
  11. Feb 2, 2023 at 6:24 AM
    There is a ground terminal on the fender near the air filter box.
  12. Feb 2, 2023 at 6:25 AM
    The seat bolts can be uses as a ground as well.
  13. Sep 16, 2024 at 8:38 AM
    BarkBeetleCC
    BarkBeetleCC New Member
    Having issues with Brake lights on trailer. All other lights work. Use tester and no connection for brake signal. Had it come on while cycling hazards with brake depressed. Shut off hazards and release brake- then won’t come back on.
    checked fuses, they all look good.
    Just need to find the grounds for this circuit.
    Any help is super appreciated!
