Grocery Getter
Discussion in '2.5 Gen Builds (2014-2021)' started by Mountains49, Apr 4, 2018.
  1. Apr 4, 2018 at 8:38 PM
    Mountains49
    Mountains49 [OP] New Member
    2018 White Platinum
    2018 Platinum
    Suspension/Tires/Wheels
    - Icon 3.0 RR CDCV Front Coilovers
    - Icon Billet UCA w/ Delta Joint
    - Icon RXT Leaf Springs
    - Icon Omega RR Rear Shocks
    - BFG K02 35/12.5/20
    - XD135 Grenade OR 20x9 +18
    - Cab Mount Chop
    - ABS Guards @sdhq_offroad
    Exterior
    - Line-X Bedliner
    - BAK Industries Revolver X4 Tonneau Cover
    - Color Match Mirror Caps and Door Handles
    - AMP Research Steps
    - Toyota Heavy Duty Bed Mat
    - Antenna Source 21" Stock Style Antenna
    - BAMuffler X-Pipe Cat Back (Medium) w/ TRD Tailpipes @dirtydeeds
    - aFe Super Stock Pro Dry S CAI
    - Hood Center Satin Black Wrap
    - Roof Satin Black Wrap (Cab and ARE Cap)
    - Rigid Industries A-Series Low Power LED Lights (Cool White/Black housing) - bed lights
    - Oznium Waterproof Switch - bed lights
    - Rigid Industries A-Series Low Power LED Lights (Cool White/White housing) - replaced Amp Research Step lights
    - V-Led Exterior LED Lights
    - A.R.E. Z-Series Cap
    - ADD Stealth Fighter Front Bumper
    - 40" OnX6 Dual Control Amber/White @Baja Designs
    - 40" S8 Amber Driving Combo @Baja Designs
    - Switch Pro’s 9100
    - Engine/Shifter Panel Mounts @sdhq_offroad
    - Hood Bulge Light Bar Mount @sdhq_offroad
    - RCI Engine/LCA Skids - Raw Aluminum
    - Bed Stiffeners @TOTAL CHAOS
    - OEM Color Match Fender Flares
    Interior
    - Driver Side Oh-Shit Handle
    - V-Led Interior LED Lights
    - TRD Pro Shift Knob - Black
    - Steering Wheel Controls Satin Black Wrap
    - Window Tint - 20% Ceramic Front/50% Ceramic Rear
    - Doors/Rear Cab/Rear Floor Sound Deadener - Dynamat Extreme
    - ESP Long Box Storage
    - Compustar Remote Start
    - CZD Auto Custom Steering Wheel
    Future
    - AR Headers w/ SAI
    - Custom Tune
    - Nitto Ridge Grappler 295/65/20
    - Nitro 5.29 Gears w/ REM Polish
    - Auburn or PowerTrax Grip Pro LSD
    - BD Lights (S1/S2/Squadrons)
  2. Apr 4, 2018 at 8:42 PM
    agentcox000
    agentcox000 "Skin that smoke wagon and see what happens"
    Corey
    Buckeye, AZ
    '16 White CM 4WD
    See Signature
    Sweet ride man!
  3. Apr 4, 2018 at 8:52 PM
    Tracker
    Tracker New Member
    Shane
    Colorado, Denver Burbs
    2016 Silver Tundra SR5 Lifted
    Nice rig, Welcome from Colorado
  4. Apr 4, 2018 at 8:53 PM
    LastCanadianExit
    LastCanadianExit The dude abides...
    Bucks County, PA
    2018 Platinum
    ReadyLift 8" Lift Fuel Trophy Wheels Yokohama 37s
    That’s some grocery getter! Love it. Something I aspire to get to for sure.
  5. Apr 4, 2018 at 8:54 PM
    Grumpy Uncle
    Pat
    CO
    Welcome from CO. Nice truck
  6. Apr 4, 2018 at 8:57 PM
    Nike21
    Nike21 New Member
    2018 SR5 CrewMax TSS 4X4 Black Beast
    Welcome from TX!! Sweet ride!!
  7. Apr 4, 2018 at 8:58 PM
    Ely010606
    Ely010606 New Member
    SPARKS, NV
    2017 QS SR5 CM TRD 4x4
    Very, Very nice ride, and Welcome from So Cal
  8. Apr 4, 2018 at 9:00 PM
    OceanSkyWolf
    OceanSkyWolf New Member
    2017 MGM CM
    Where’d you order your bed cover from?
  9. Apr 4, 2018 at 9:07 PM
    TheBeast The Beach
    very nice !
  10. Apr 4, 2018 at 9:08 PM
    blue16
    blue16 New Member
    steve
    Mesa AZ
    2016 tundra
    Very nice
  11. Apr 4, 2018 at 9:18 PM
    94slowbra
    94slowbra New Member
    john
    new orleans
    2016 TRD pro
    Sweet set up! Curious, how does it ride with the 20s? Most recommend a 17" or 18" wheel for the best ride. You have a pretty serious set up there so I'm wondering how it feels? Thanks
  12. Apr 4, 2018 at 9:22 PM
    porkitt
    porkitt New Member
    Ian
    Tundra Pro Cement
    DAP Tune ESP Storage RCI Skids Icon Rebound ABS Guards AVS Vent Visor FRAC Harness 50 Cal/Antenna X BFG KO2 HID Extra Light Bar White Knuckle Off Road Sliders BAK Industries Revolver X2 Oh Shit Handles Pop and Lock LED Internal and Reverse Lights LED Footwell lights Tuffy Storage Console organizers Viper Alarm and Remote Start
    Welcome from SoCal! I see you buy in bulk too!
  13. Apr 4, 2018 at 9:25 PM
    Mountains49
    2018 White Platinum
    Although I'm very happy with how everything is and has turned out I'm having some suspension issues similar to @joonbug and @boardude - rear passenger shock contact with brake caliper bolt. I'm working with OK4WD in NJ and @Icon_Adrian to get this sorted out. Have poly bushings in place at the moment to prevent it from rotating.
    Also hearing a metallic popping/clanking noise from the rear passenger side when turning or when that corner is loading/unloading. Not sure if it's the leafs or what. Got them greased but still there's noise. There's a decent amount (3/4" or so) of side to side play in the leaf just below the main. Is that normal?
    Lastly (hopefully), having some adjustment issues with the Front driver side coilover. Max preload spec is 1.25" measurable thread and this side is at about 1.75". Front passenger side is at about 0.75" and the truck is sitting level side to side (+/- 1/4"). Even with driver weight and the large fuel tank, it doesn't seem like it would need to be adjusted that much (especially out of manufacturer spec.).
    Driver Side:
    Passenger Side:
    Any help/insight would be greatly appreciated. Thanks.
    1rufftrdpro likes this.
  14. Apr 4, 2018 at 9:28 PM
    Mountains49
    2018 White Platinum
    Got hooked up with a great deal through AutoAnything @eccracer104
    eccracer104 likes this.
  15. Apr 4, 2018 at 9:41 PM
    Mountains49
    2018 White Platinum
    Thank you. I love it (hopefully even more once I get all the issues ironed out). It probably does ride a little more firm that those running 17's or 18's. I was on the fence about going with an 18 or 20. Honestly, the reason I went with the 20's is because I got a little (perhaps overly?) excited about this big brake kit by SOS Performance that requires 20+.
  16. Apr 4, 2018 at 11:55 PM
    831Tun
    831Tun heartless Bastrd
    Warren
    Santa Cruz
    '16 CM limited
    Looking good. I hope you get the Icon issues resolved, so far their customer service has been top notch.
  17. Apr 5, 2018 at 1:20 AM
    Casper3
    Casper3 New Member
    Jay
    CT/OH
    2017 Super White 5.7 SR5 TRD off road
    Welcome from Ohio, nice rig! :thumbsup:
  18. Apr 5, 2018 at 2:34 AM
    Welcome from Ohio nice truck!
  19. Apr 5, 2018 at 4:06 AM
    Welcome from CO!
  20. Apr 5, 2018 at 4:42 AM
    Hermel
    Hermel New Member
    Mark
    Virginia Beach
    ‘15 White DC TRD Pro
    Welcome from VA! Nice truck! My truck wants to be like yours when it grows up
  21. Apr 5, 2018 at 4:44 AM
    atrinh15
    atrinh15 New Member
    495-93 area
    2018 PLATNIUM White CM
    Ready lift 3/2 Fuel Mavericks 22x9.5 Nitti Terra Grappler G2 - 285/55/22 K/N air filter TRD sway bar SS Fisher plow Mesh grill painted to match Rear bumper painted white
    Love it. Looks nasty. Subd
    Welcome from Mass
  22. Apr 5, 2018 at 5:03 AM
    seniramsu
    seniramsu Pro Runnin
    Nate
    VA
    2017 TRD Pro Tundra Wht
    Welcome from NC!!! Truck looks great
  23. Apr 5, 2018 at 6:16 AM
    nk1794
    nk1794 Always torque to spec
    San Jose, CA
    Awesome truck. Welcome
  24. Apr 5, 2018 at 6:19 AM
    Welcome from Texas
  25. Apr 5, 2018 at 6:23 AM
    Mountains49
    2018 White Platinum
    Thank you for all of the compliments and welcome messages! Cheers!
  26. Apr 5, 2018 at 7:26 AM
    whatsthehatch
    whatsthehatch New Member
    2017 Tundra CM SR5 4x4
    Love the honesty.
  27. Apr 5, 2018 at 7:41 AM
    TXMiamiFan
    Jose
    2016 White Crew Max TRD
    Groceries? F that! Go to Home Depot.
    Welcome from CO.
    boardude and nk1794 like this.
  28. Apr 5, 2018 at 8:44 AM
    boardude
    boardude I am Batman
    Kris
    Tucson, AZ
    [YODAGAN]
    2015 Inferno Ex-Pro
    Hopefully you get those rears resolved soon. I know they took care of Joon.
    I cranked my driver's side about a half inch higher than the passenger side to account for the lean. I'm a 2015 so I have the smaller tank.
    You need more pics of your truck lol. Your truck is too nice to only have a couple for us to look at. Those wheels look amazing against that white!!
    joonbug likes this.
  29. Apr 5, 2018 at 10:15 AM
    PLC721
    PLC721 New Member
    Patrick
    Chandler, AZ
    2018 Ram 2500 Cummins Laramie
    IG: PLC721
    Beautiful truck man! I hope Icon gets these issues worked out for you!
  30. Apr 10, 2018 at 8:30 AM
    Mountains49
    2018 White Platinum
    So, I finally got a few responses from @Icon_Adrian regarding the suspension issues.
    Rear Suspension: Temporary shocks will be sent out so I can send mine in for repair and then re-swap when they're done (same as @joonbug). Awesome!
    Still no resolution to the noise I'm hearing in the rear passenger area (popping/clanking noise). Apparently the design of our trucks has the leaf packs slightly boat tailed or triangulated. The side to side motion of the leafs under the main was said to be, per Adrian, normal. Icon is ok with this so they could squeak out every bit of travel with their new RXT pack. Thoughts? @boardude @joonbug have you seen or noticed that your RXT's walk side to side?
    Front Suspension: The front driver side coilover is adjusted (1.75") outside of Icon spec (1.25"), (passenger side is at 0.75"). Adrian said that this is ok as long as it's only a daily driver and you don't do any offroading. Right. He also recommended that if I did desire to go offroad to back it down to 1" and I'd just have to deal with the lean - that most all trucks aren't level even from factory. He also said that this system is not a lift kit, that it's a performance suspension system, and it's primary intent is to do high(er) speed desert runs. If that's the case wouldn't you want your truck to sit as level as possible? Additionally, he said that if it's adjusted to where it is now and something breaks that it won't be covered under warranty because, surprise, it's adjusted outside of manufacturer spec.
    Future plans for the build include a front bumper with lights and sound dampening in the cab, both of which will add a decent amount of weight. If I'm already out of spec completely stock, where do I go when I add that? The intent in choosing this system and investing this kind of money was to have a pretty much do anything truck/set up.
    It's awesome that Icon is going to offer temp shocks and repair the rears.
    But, I feel like Icon pushed this system out the door a little too quick and some of the other answers were very CYA in nature.
    Icon_Adrian and joonbug like this.
