Grinding When Braking and Turning Right
Discussion in '1st Gen Tundras (2000-2006)' started by hero2zero, Nov 3, 2021.
  1. Nov 3, 2021 at 6:18 AM
    hero2zero
    hero2zero [OP] New Member
    Colorado Springs, CO
    2002 Tundra SR5 AC TRD, Thunder Gray Metallic
    Strange occurrence on my 02 TRD. I recently had a problem with the ABS kicking on when below 10 mph and braking and turning. I may have solved the issue after finding that the right side speed sensor was not seated correctly. I replaced the UCAs, UBJs, LBJs, LCAs and upgraded the brakes to 13WL within the last 2-3 months. Now, when I brake when turning right, I get a grinding noise--like something is stuck between the pads and rotors--but, there is not. I've removed the pads (and rear drums) to check and checked the dust shields for rubbing. Everything seems to check out. I also bled the brakes (RR, LR, LSPV, RF, LF).
    For additional info, I have a 2" leveling kit, 265/70/18 wheels with 1.5" spacers. There is no rubbing that I can identify, but something is grinding when I brake when turning right--not left (*head scratcher*). Any ideas before I take it to a pro mechanic?
    JAXABOI likes this.
  2. Nov 3, 2021 at 9:06 AM
    So if your turning right and let off the brake the grinding stops?
  3. Nov 3, 2021 at 9:08 AM
    hero2zero
    Yes. Grinding sound only occurs when I apply the brakes. There's no grinding when I am turning left or right without braking.
  4. Nov 3, 2021 at 10:45 AM
    AZBoatHauler
    So.Arizona
    I assume the grinding is only from one side and not both? Which side?
  5. Nov 3, 2021 at 10:47 AM
    hero2zero
    Sounds like it's coming from the right side, but I'm not entirely sure. Today I'm going to put a GoPro on it and see if I can capture the issue.
    AZBoatHauler likes this.
  6. Nov 3, 2021 at 12:25 PM
    Black@Blue19
    Black@Blue19 Old Salt
    Ken
    SE Texas
    Might have a rock lodged in there that you missed?? Find an open area and put it in reverse a few times and apply brakes. That’s what I have, my other was the shield but you said that checked out also. Double check the brakes?? Good luck.
    15whtrd likes this.
  7. Nov 3, 2021 at 1:40 PM
    hero2zero
    Here's a short video clip of the noise. I can't tell where it's coming from based on the clip. Maybe some of you have heard this noise before...?
  8. Nov 4, 2021 at 12:56 PM
    rock climber
    rock climber New Member
    2001 Sequoia 4X4, 2000 AC 4X4
    Could it be the tire hitting the mudflap? Sounds like tire rubbing something to me
  9. Nov 4, 2021 at 3:38 PM
    hero2zero
    No mudflaps--well, the bottom part of the front flaps are removed. I just disassembled both fronts including the calipers, pads, and rotors. No evidence of rubbing, grinding, etc. Nothing stuck. Dust shields have good clearance.
  10. Nov 4, 2021 at 3:40 PM
    15whtrd
    15whtrd Mr. Blonde
    Make sure you didn’t bend the dust shields.
