Grinding sound
Discussion in '1st Gen Tundras (2000-2006)' started by toyotapete, Mar 24, 2017.
  1. Mar 24, 2017 at 6:43 AM
    toyotapete
    toyotapete [OP] New Member
    2004 Tundra extended cab 4x4
    7'6" snow way plow
    I have a 2004 Tundra 4x4 with 176000 miles on it.
    I am hearing a grinding noise when I turn the steering wheel either way. I checked the steering fluid and that is ok. Is there a separate belt that runs the PS pump or is that run off the serpentine belt? My serpentine belt was fairly recently changed. Maybe a bad pump? If so is that a major job/expense? Its been a busy week at work so I haven't really got under that hood to investigate. Will do so tomorrow.
  2. Mar 24, 2017 at 9:26 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    2014 Toyota Tundra TRD
    I know my PS pump started going at 177k on my 2000 but has hung in there. Definitely no grinding issues though. Is the PS fluid clear or cloudy? I'd also look around your front suspension and tires to ensure something didn't get jammed up in there.
  3. Mar 24, 2017 at 9:30 AM
    toyotapete
    7'6" snow way plow
    Thanks, Im thinking it could also be a tie rod end or dry ball joints. Will investigate further this weekend
  4. Mar 24, 2017 at 9:39 AM
    FirstGenTundra
    FirstGenTundra R2R
    Daniel
    Wyoming
    I think that would probably be a more likely source. Good luck and hope it's not an expensive repair.
  5. Apr 5, 2017 at 6:34 AM
    toyotapete
    7'6" snow way plow
    Issue was dry upper ball joints. No fittings. I pumped some grease in with a pointed grease gun fitting and all went quiet. replacing uppers and lowers next week.
