Grinding sound/feel on front end
Discussion in '2nd Gen Tundras (2007-2013)' started by ColoradoTJ, Aug 8, 2016.
  1. Aug 8, 2016 at 4:48 PM
    ColoradoTJ [OP] Certified tow LEO Staff Member
    Lately I have been hearing a metal on metal, or bad bearing sound, or something like rubbing. This did come after my struts were installed, and not sure if it has to do with needing a differential drop kit or not.
    Today I did take off my front wheels, pulled the brake pads out to see if I have one dragging, cleaned and re-lubed the necessary brake parts, and on the drivers side removed the caliper and rotor to see if it is just hitting the backing plate.
    The rotor was rubbing the backing plate a little, but now it is not. I may have to paint the BP and then actually see if the rub is gone.
    Last night one of my best friends turned 28 yrs old, and on the way home from his party I euthanized a house cat with the drivers front going 40 mph. That made me do the work today, and bend the backing plate back out.
    Supervisor
    Ideas?
  2. Aug 8, 2016 at 5:12 PM
    Mike Tread lightly.
    south carolina
    With the backing plate pushed away does it still make the noise? To me those marks are a sign of disc and back plate touching.
    Mmmm I don't see a jack stand... Safety first...
  3. Aug 8, 2016 at 5:16 PM
    I could not duplicate the noise with my hands, but after about 15 mph it starts, sometimes not. Weird.
    Maybe I should paint the backing plate to ensure there is no rubbing.
    There is a jack stand under the frame, but good reminder for those that trust hydraulics (I do not).
    NewImprovedRon and Law323 like this.
  4. Aug 8, 2016 at 5:23 PM
    Mike Tread lightly.
    south carolina
    Paint it bright color see what happens.
    Double check your caliper it's not freezing up on you...
    ColoradoTJ[OP] likes this.
  5. Aug 8, 2016 at 5:29 PM
    Yeah, think that is the next stop for me. Paint time.
    Caliper has been checked. My supervisor pushed down on the brake pedal without pads and all the caliper pistons came out like normal.
    Wondering about the front diff?
  6. Aug 8, 2016 at 5:35 PM
    Mike Tread lightly.
    south carolina
    Did the pistons retract after letting off pedal?
    If it was the diff it would be more like a growling sound not metal to metal as you are talking about.
    When was the last time the spider (ujoints) got grease on front driveshaft and rear to rule that out.
  7. Aug 8, 2016 at 5:42 PM
    Brake calipers worked as normal.
    Well, I could say it is a growl. Maybe I can take a sound clip.
    The driveshaft gets lubed every other oil change, or 10k miles.
  8. Aug 8, 2016 at 5:50 PM
    Mike Tread lightly.
    south carolina
    If it's a growling sound then you look into diff's... When was the oil checked last in the pumpkin? And I will assume your CV and driveshafts are not are strange angles from a lift correct?
  9. Aug 8, 2016 at 5:58 PM
    The diff fluids are swapped out every 25k.
    Now this is what I am wondering about drive shaft angles. I'll go take a shot of the angle.
  10. Aug 8, 2016 at 6:06 PM
    I also got a measurement of the front lift.
    Stock was 36 5/8 and now it is 37 3/8.
    So I went up under 1".
  11. Aug 8, 2016 at 6:16 PM
    Mike Tread lightly.
    south carolina
    Your CV looks fine from what i see and driveshaft is about the same angle then?
  12. Aug 8, 2016 at 6:22 PM
    That is what I thought, but it is good to have a second opinion. Maybe I'm nuts.
    When I swap tires, and move up to a 275/70/18, I plan on taking the shocks up a little more. That is why I ordered the diff drop.
    I think the proper way to troubleshoot this is to start with the easy. Paint.
    Law323 likes this.
  13. Aug 8, 2016 at 6:35 PM
    Mike Tread lightly.
    south carolina
    Try this too. We use chrome paint for a mirror shine. Now anything touches it it's going to be dull.. we even did it to a driveshaft once in our shop and found the angle at 45 mph was touching the other joint at 15 degrees.
  14. Aug 8, 2016 at 6:53 PM
    I even think there is some in my garage.
    What a PITA, but I would rather find out the front diff is going south before 100K miles.
  15. Aug 8, 2016 at 6:57 PM
    zcarpenter92
    Zach
    NE Colorado
    2008 Desert Sand 5.7L DC
    In sig
    My front diff made a grinding/rubbing sound when it went. Luckily it happened right after I bought the thing, so it was covered on the 3 month/3600 mile warranty. Otherwise it would've been $1700 out of my pocket.
  16. Aug 8, 2016 at 7:09 PM
    This is what I am afraid of. 100,002 miles and a FO at the dealership.
    This would not surprise me one bit though. I towed 300 continuous miles in a really tough blizzard. This is how we started from Cortez, CO:
    This was the start before Wolf Creek Pass:
    Mid way we had to take an hour to chip off ice after La Veta Pass:
    I have also used 4wd with the camper, the flatbed trailer...etc.
    This load was in 4Low for a while....
    AB145BE9-9ADD-45DD-BFF6-D4014438DB40_zps_2f4a6913cf6e43f7e199dfcc6c266c3f6402ef9c.jpg
    If this is the case, the other half said to go get a 1 ton, but she has been very impressed with how this truck has handled what we do with it. I said they can replace it and we can go another 60K and then sell it.
    driverdog likes this.
  17. Aug 8, 2016 at 7:17 PM
    Mike Tread lightly.
    south carolina
    If you do this, I'm not at fault, for death or pregnancy or both.. , but you can trace down faster..
    Jack vehicle on four jack stands so wheels are off the ground.. have the wife in her stiletto heels and mini skirt, use the heels as height mind you to get in the truck and drive the truck around while you under the truck looking for this sound.
  18. Aug 8, 2016 at 7:20 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    Mine went at 67,000 something miles, I thought it was kind of early for a diff to go but oh well.
  19. Aug 8, 2016 at 7:21 PM
    I am at 78K.
  20. Aug 8, 2016 at 7:26 PM
    Mike Tread lightly.
    south carolina
    That's the problem with ADD system. Even tho 4wheel drive in not engaged it still wears out components... Wish they would bring back manual hubs...
  21. Aug 8, 2016 at 7:27 PM
    Mike Tread lightly.
    south carolina
    That's too early man... Way to early.
  22. Aug 8, 2016 at 7:27 PM
    I know people with 4 point lifts...but the heals and mini skirt is a go!
    NewImprovedRon likes this.
  23. Aug 8, 2016 at 7:29 PM
    Mike Tread lightly.
    south carolina
    Always here to help.... Remember we need pics....lol
  24. Aug 8, 2016 at 7:30 PM
    zcarpenter92
    Zach
    NE Colorado
    In sig
    What exactly causes that? Someone shifting into 4Hi at full speed all the time or what?
  25. Aug 8, 2016 at 7:33 PM
    Mike Tread lightly.
    south carolina
    When it's in the air you I'll need to engage 4wheel drive... If not nothing will turn in the front.
  26. Aug 8, 2016 at 7:39 PM
    Mike Tread lightly.
    south carolina
    Could be many things. To be honest. From bad bearings to pinion gear mesh to tight or loose, to contamination in oil, or diff was simply not spec right from the supplier missed qc..,
    Traction control shouldn't allow a unsafe engage in 4wheel at high speeds. If it does that's a over site.
  27. Aug 8, 2016 at 11:37 PM
    2cID
    2cID New Member
    16 crewmax 4x4
    Car seat covers
    There's also a tool called a chassis ear, great for chasing gremlins/nvh problems
  28. Aug 9, 2016 at 7:01 AM
    I tried getting a sound clip of issue today. My iPhone just picks up all the road noise.
    I am also going to swap the front and rear tire to see if that moves the sound.
  29. Aug 9, 2016 at 7:23 AM
    Mike Tread lightly.
    south carolina
    In James Earl Jones voice( come to the power of the dark side) Android...
    2cID and ColoradoTJ[QUOTED][OP] like this.
  30. Aug 9, 2016 at 7:39 AM
    Been down that road. Like phones that work. Lol.
    This shot is for you @Mike , the Jack stand you normally cannot see.
    The front and rear tires have been swapped.
    Need to find this issue guys. My neighbor has a Raptor and shakes his head as he drives by much as I have been under it lately. He even stopped yesterday and mentioned if I had a ford this wouldn't happen. :mad::rolleyes:
