Grinding noise!!! HELP NEEDED!!!!
Discussion in '2nd Gen Tundras (2007-2013)' started by mikeyhinson, Nov 18, 2018.
  1. Nov 18, 2018 at 3:37 PM
    mikeyhinson
    mikeyhinson [OP] New Member
    mikey
    2010 toyota tundra
    lifted on forces 4wd
    The noise is coming from under the truck and it isn't the rear end. When I let off the gas doing any speed over 45 there's almost like a gear grinding sound. As soon as I get back onto the gas the noise goes away. The tranny seems fine and doesn't shift weird. Anybody had the same issue or have any ideas on whats going on?? Thanks in advance
  2. Nov 18, 2018 at 3:43 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Check u-joints and carrier bearing.
    417Tundra, kparrow and ColoradoTJ like this.
  3. Nov 18, 2018 at 3:58 PM
    mikeyhinson
    mikey
    2010 toyota tundra
    U joints and carrier bearing are new
  4. Nov 18, 2018 at 4:03 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Were they replaced trying to solve this issue?
    How / when did this begin? Same time as the lift by any chance?
    How are you sure it isn’t the rear diff? Not argueing, just wanting to know.
    ColoradoTJ likes this.
  5. Nov 18, 2018 at 4:04 PM
    Do you have 4wd?
    While going straight, engage 4wd. Does sound go away?
    landphil and OR18TRD like this.
  6. Nov 18, 2018 at 4:05 PM
    Bschaper84
    Bschaper84 New Member
    Las Vegas
    2017 Tundra Crewmax SR5 Inferno
    8 Inch ready lift. 20 inch moto metal wheels 37 mudders. Led interior lights and bed lights as well as 3rd brake light. Led back up lights and license plate lights. 20% tint all windows and 50%front window
    Have the output shaft on tranny checked and the connection at the rearend.... also wheel bearings
  7. Nov 18, 2018 at 4:08 PM
    mikeyhinson
    mikey
    2010 toyota tundra
    Carrier bearing and u joints were replaced when I lifted the truck just because I wanted to make sure everything was solid. The noise started about a month ago. Lifted the truck about 2 years ago. Yes it is 4wd. I went through and rebuilt the whole rear end thinking that might of been where the noise was coming from. Transfer case oil I changed about a month ago and it looked brand new(no shavings or anything).
  8. Nov 18, 2018 at 4:08 PM
    mikeyhinson
    mikey
    2010 toyota tundra
    yes its 4wd and sound does not go away in 4wd
  9. Nov 18, 2018 at 4:09 PM
    mikeyhinson
    mikey
    2010 toyota tundra
    wheel bearings are new and that would be the shaft going into the transfer case correct? U joint at the rear end is tight
  10. Nov 18, 2018 at 4:10 PM
    mikeyhinson
    mikey
    2010 toyota tundra
    yes everything is up to par
    OR18TRD[QUOTED] likes this.
  11. Nov 18, 2018 at 4:15 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Does downshifting the transmission to a lower gear change the noise, make it louder, quieter...??
  12. Nov 18, 2018 at 4:16 PM
    There is a TSB on the front differential, needle bushing failing (drivers side, right were half shaft goes into housing). Mine started failing around 50k miles, but it was obvious around 60k that something was seriously wrong.
    Toyota found the problem, suggested I do the ECGS bushing, they would not warranty, would install for 600.00, and take an afternoon to perform the task.
    I told them to pound sand, handed them my Toyotacare card, paid 75.00 deductible and they put in a new front diff for 2400.00.
    There was more to this story on the troubleshooting, and a wheel bearing was replaced (I told them it was fine, checked with inferred camera), didn’t fix problem. Toyota wasted 1000.00 on that and I paid a 75.00 copay.
    dcsleeper408 and OR18TRD like this.
  13. Nov 18, 2018 at 4:17 PM
    mikeyhinson
    mikey
    2010 toyota tundra
    once the truck gets under about 35 mph the noise goes away
  14. Nov 18, 2018 at 4:18 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    So 4th or 5th at 50 mph the noise is no different than 6th?
  15. Nov 18, 2018 at 4:18 PM
    mikeyhinson
    mikey
    2010 toyota tundra
    was yours making the same noise as mine?
  16. Nov 18, 2018 at 4:18 PM
    mikeyhinson
    mikey
    2010 toyota tundra
    correct
    landphil[QUOTED] likes this.
  17. Nov 18, 2018 at 4:20 PM
    timsp8
    NY
    I had the front diff issue. Also feels like a tire is out of balance or driving over rumble strips. Do you have that?
  18. Nov 18, 2018 at 4:21 PM
    mikeyhinson
    mikey
    2010 toyota tundra
    My issue is when its both in 4wd and 2wd so I don't think it would be the front diff
  19. Nov 18, 2018 at 4:23 PM
    timsp8
    NY
    I skimmed over that. Yeah if it doesn’t go away in 4wd it’s not the TSB issue. Trans fluid been changed? Low? Torque converter? I got the code for the torque converter just before I traded in my 2010.
  20. Nov 18, 2018 at 4:26 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
    Since the u-joints and carrier bearing are almost 2 years old, you can’t assume they are good. If you haven’t already, I’d at least make sure all 4 bearing caps of each u-joint purge grease, check for any play, and unbolt the carrier bearing from the crossmember and spin it around the shaft listening for any roughness.
  21. Nov 18, 2018 at 4:26 PM
    mikeyhinson
    mikey
    2010 toyota tundra
    trans fluid has been changed and is full. Not sure about the torque converter
  22. Nov 18, 2018 at 4:27 PM
    mikeyhinson
    mikey
    2010 toyota tundra
    ive been back under there and checked and regreased everything. Carrier bearing doesn't feel any different since the day I put it on
  23. Nov 18, 2018 at 4:29 PM
    timsp8
    NY
    I think if your transmission was going out you’d get a CEL. Mine went out at 59k, and every time I cleared a CEL a new one with a different code came on. Can you strap a camera with mic under the truck somewhere to narrow it down?
  24. Nov 18, 2018 at 4:36 PM
    mikeyhinson
    mikey
    2010 toyota tundra
    I strapped my gopro right under the transfer case and it was coming from right where it was mounted. Has anyone ever rebuilt there transfer cae?
  25. Nov 18, 2018 at 4:39 PM
    Not on a Tundra, but on Jeeps. Not overly difficult, and from the sounds of it, you’re not going to have an issue with this.
  26. Nov 18, 2018 at 4:40 PM
    mikeyhinson
    mikey
    2010 toyota tundra
    Im trying to find a rebuild kit for it but am having no luck
  27. Nov 18, 2018 at 4:44 PM
    landphil
    Phil
    BC, Canada
    ‘08 TRD doublecab
  28. Nov 18, 2018 at 4:50 PM
  29. Nov 19, 2018 at 9:40 PM
    Dr_Al
    Dr_Al New Member
    Al
    There's no rebuilt kit for them. In fact there's not much of anything Toyota will sell you for the transfer case. You could have a bad bearing inside it, which is something you can buy.
    I think mine has a stretched chain inside it (can't buy it) so I bought a used one from a junkyard. It's been too cold to do (may even wait until next spring) but looking at it my plan is to remove the front driveshaft and the flange for it. Then I'm going to split the transfer case in place. The front half of the case is also the rear mount for the engine/ transmission so there shouldn't be an issue supporting the engine while doing it. The transfer case guts should come out with the rear half of the case. From there I would look for a bad bearing. I'm thinking this is going to be an all day job. If this is your daily driver then I would buy new bearings and seals and just change them. Also have gear oil and gasket sealer. It looks like parts of the exhaust will need to be removed and the rear driveshaft. The rear driveshaft will also have to be partly removed. That might mean removing the center carrier bearing.
    Maybe you can do this with just jacks and brawn but I have a 2 post lift, tall jack stands, and a transmission jack. I don't think I would try it without at least a transmission jack and even then you'll need to make a way to hold the transfer case since the rear crossmember is in the way (which makes removing the transfer case whole much harder).
  30. Nov 26, 2018 at 6:14 AM
    mikeyhinson
    mikey
    2010 toyota tundra
    Thanks for the info. Just gonna have to tear her open and see what I find. What kind of noise is yours making with a loose chain?
